C4 2010 2.0 Hdi issues help needed.
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi all
Having a few minor issues with my new to me C4 in my sig.
First one is i have a leak, which is part of number 2 so will explain.
I have a leak of fluid that is appearing itself on the front drivers side crossmember just in front of the front wheel, it looks at first glance to be engine oil when you put your finger on the drip on the subframe, but my gut feeling is that it is hydraulic oil as it dries on the floor in a similar way to LHM, a dark stain but not the way engine oil does.
I have a similar issue to others with the 2.0 HDi engine with the dipstick being broken, it was not on inspection when viewing the car prior to purchase so am in a position where i cannot rule out an engine oil leak.
Coupled with this i have an issue with the dashboard oil level check which is coming up as "Oil Level Invalid " so did a Lexia session and it is reporting a fault with the oil level but cannot remember the code.
Now i think the leak is Brake fluid related as the pedal travel is way too much and does not seem to have resistance, a bit like the brake bleeding process without the resistance if that makes sense yet the fluid level seems to be within the marks.
So can anyone tell me the part number for the oil dipstick, hoping it is the same as used on my C5 as i can interchange them to manually check levels as a first step.
Next question is i have looked at what i believe is the oil level sensor on the sump, is that a simple unscrew and replace, i get the feeling the sensor is faulty but still reporting ?
Colin
x 6954
Re: C4 2010 2.0 Hdi issues help needed.
Ok, so here you are:
(07) is the Engine Oil Gauge 1131K6 £20.02
(09) is the Dipstick (614 long) 1174G9 (Replacement Part) £20.02
(11) is the Engine Oil Pressure Switch 1131C5 for reference £19.75
admiral51
(Donor 2026)
x 391
Thanks Marc
Would i be correct in saying that part #7 is the one that is responsible for the on dash message about oil level that has a plug socket on the end of it, sorry for non mechanical terms :)
The dipstick #9 ( not referring to me this time ) is the updated version i guess so both parts for £40 + vat from Citroen is something i can live with, all i need to do now is work out what and where the leak is :)
Colin
x 8058
Yes you would be correct about no 7 Colin. Assuming your plug is fitting properly on the existing one? :)
x 6954
Yes that's the one.
citroenguy
(Donor 2021)
x 75
Unread post by citroenguy »
The leak could be power steering fluid.
The pump and reservoir is in front of the RF wheel
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
admiral51
(Donor 2026)
x 391
Thanks for the replies, quick update :)
It appears the leak is in fact coolant and is coming from the water pump :(
I have a receipt saying the cambelt/water pump had been done so more than a little bit miffed but depending on quality of parts used etc at least it is not something very expensive like ABS block/ brake servo etc etc :).
Warranty i have is not worth the paper it is written on, not when i have to take it back to them to sort it so gonna cost me around £400 to get it re done but worth it for peace of mind.
Colin
admiral51
(Donor 2026)
x 391
I also have another 2 leaks deep joy #-o
1 is from the N/S drive shaft and is gearbox oil related, believe it is just a seal but needs doing.
The other is engine oil and appears to be coming from the back of the engine high up so will be getting sorted at the same time, and just for good measure having the oil changed and oil/fuel/air filters done.
Apart from these little inexpensive issues really happy with the car :rofl2:
Colin
admiral51
(Donor 2026)
x 391
Can anyone confirm that the dipstick is the same part number for both the C4 and the C5 in my Vin list please as the C4 is booked in tomorrow and typically the dipstick was not delivered today to Citroen, although the level switch was, so would like to have a complete one in the C4 when it goes in tomorrow.
Thanks in advance
Colin
x 1056
Unread post by wheeler »
Yes, they are both the same part no 1174G9
admiral51
(Donor 2026)
x 391
Thanks i did do some surfing and came up with the conclusion they were but best to ask the experts here :)
Colin
admiral51
(Donor 2026)
x 391
Okay not sure its a "lemon" but it is getting used to being warm and dry in a garage that has 4 post lifts and pits :(
Would it be possible to have the part number and cost for the front springs on said C4 from Citroen, going to have to get a pair but o/s/f has broken and not a happy bunny lol
Colin
admiral51
(Donor 2026)
x 391
Well i think although it is Babylon Red in colour it is defo lemon ( Money Pit ) in disguise :)
Really need some advice on a way forward now.
All other work has been undertaken both front springs and the filter changes and the oil level sensor fitted as i requested and the cost is ok as i needed the service parts done and the springs are just one of those things so another £350 put into the car.
However both drive shaft seals are leaking and i get the feeling that i am going to have to go down an expensive route.
My trusted garage are telling me they cannot get the seals on there own, yet to discuss with them how to change them if they could get them but logic states the box needs to be removed to fit them if they could get them.
So if i have to pay to get the box removed and then sent somewhere for the seals to be replaced and then refitted would i be better off just getting a reconditioned box to swap it with ?
No point going for a 2nd hand box with a warranty not worth the paper its written on and whilst its out just as well do a clutch change.
Open to suggestions but its gonna cost either way round and the leaks are just weeps at the moment but need to get it sorted sooner rather than later.
No point going back to where i got it from as it would cost me so much in time and hassle and to be honest i wouldn't trust them to sort it anyway.
Yep gonna keep it apart from a few minor issues its a cracking car when it gets out the workshop :rofl2: :rofl2:
Colin
x 1056
The right seal comes on its own 1675689680 £21.74 +vat
The left seal 9822498280 £47.05 + vat & comes in a little housing.
What makes you think you need to remove the box to change the seals??
The one than cone with the housing is held on with 4 bolts & sealed with RTV.
admiral51
(Donor 2026)
x 391
You are an absolute legend, i am going on advice that the seals are not available hence the question about swapping the box for a recon one.
I assume the parts and prices are from Citroen and are still available.
Colin
