Belt tensioner bracket
- (Donor 2021)
- My Cars: 2003 Citroen xsara picasso
Hi i have a 2003 Citroen xsara picasso 1.8 petrol. The one tensioner bracket has broke i have no power steering. It looks like its under neath the engine mounting it looks like it is bolted under it. Does anyone know what this is called
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Belt tensioner bracket
That's the right engine mounting bracket.
- (Donor 2021)
I know its an engine mounting but there is a bracket that fits underneat that holds it belt tensioner. Ordering a new engine mounting doesn't have the fitting for the belt tensioner so i assume its another fitting that goes under neath the engine mounting but i dont know the name of the part
- My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl - x 1003
Just seems to be called alternator bracket, this looks like it: https://www.xdalys.lt/en/alternator-bra ... ther-parts
Clearly visible on this engine on e-bay: Xsara engine
- (Donor 2021)
Part
Anyone know of a website where i can get this part from or what it is even called. Ive tried ebay and europarts but no luck. I have a 2003 Citroen xsara picasso 1.8 16v petrol engine
Reason: Topics merged to avoid duplication
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Part
We can help with official parts, but require a member donation for this service - but it will cover you for up to 2 years of official parts info and parts diagrams. Details below if you want to upgrade your membership:
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum. |
To Upgrade Your Membership & Donate Click Here For Further Information About Vehicle Parts and VIN Numbers Click Here |
- (Donor 2021)
Re: Part
Ive just made a donationGiveMeABreak wrote: ↑24 Sep 2021, 15:03 We can help with official parts, but require a member donation for this service - but it will cover you for up to 2 years of official parts info and parts diagrams. Details below if you want to upgrade your membership:
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum. To Upgrade Your Membership & Donate Click Here
Thanks, post up the VIN (which will obscure itself) and we'll look up the part. It is the engine mount, most likely not available from Citroen anymore, but we can see what else it fits so you can search breakers. Where abouts is it actually broken?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
As there's only one 1.8 Petrol in the Xsara Picasso range, it should be the following, but VIN would be good to confirm please:
Item (9) Part: 1807J3 - ENGINE MOUNTING BRACKET (Right) £119.83
Item (10) Part: 1844A7 - BUFFER £37.58
Item (11) Part: 184477 - ENGINE ELASTIC MOUNTING BRACKT (Right) £98.77
Item (20) Part: 184699 - ENGINE MOUNTING BRACKET (Right) £159.79
All these are showing as currently available from Citroen as of today and include UK VAT.
- (Donor 2021)
I have marked in the pic where the bit is broken it has caused the belt to come off so i got no power steering.
The vin is VF7**************[VIN obfuscated, can be read by forum staff]
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, confirmed - this is the correct information for your Xsara Picasso - all parts available from Citroen using the part numbers I provided above.
You've added a few more pictures since the original - are we still talking about the same thing:
These are the alternator fixings which resemble the part in the previous pictures:
Item (2) is the Alternator Bracket and has been replaced with 2 new parts:
5706K5 (bracket) + 5751E4 (Retractor Roller) - you need both
£84.66 for the bracket and £56.30 for the roller.
Presume it is the tensioner to the right in that picture? It's not at all clear, it might be bolted to the engine bracket Marc listed, or it might be bolted to the block... You are going to need to get the bracket off to have a look at it to determine whether it's repairable or not.
Although if you look here: https://www.eurocarcare.net/mountings/e ... acket.html there are 2 threded bosses at the bottom which match the positions of the bolts on the tensioner, so I think it is on this mounting bracket.
