Xantia Parts Request
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 81
I've got a part number request too when you have a moment.
For M728 GDL, VIN to be added to signature at some point today.
Cooling system hoses:-
a) The one that runs across top of cam cover and drops into the back of the fuel filter housing and down behind first glow plug. It has a T-piece in it up top.
b) One at rear of engine (probably got to be worth doing whilst cylinder head is off...
May want other cooling system ones but don't know as yet.
c) the breather from the cam cover (think it goes to oil filler?)
d) diesel supply pipe that comes up from back of engine to fuel pump (from memory - car not with me at mo)
- Donor 2023
Re: Xantia Parts Request
Now added VIN, Marc.
However, please be aware it is a mackle-up of the first part of N707 MGP and the actual last 8 digits of M728 GDL...
Hope it works. Let me know. If not, I'll have to trouble my mate to check it.
If its number 3 you need im afraid its no longer available from Citroen Part no 1351X7
what is the other pipe you need?
- Donor 2023
Hi wheeler.
I managed to split a tiny bit of it where it kicks back towards the cambelt. Should be alright... Fingers crossed.
Looking at that diagram, I am guessing it's no. 4 but I would need to look at it next time I am with the car.
No. 1 would be worth doing I think.
4 is the heater matrix pipes, no longer available either im afraid.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Ok, I have the VIN - which is different. If you need this let me know and I'll email it to you.
As for the parts I take it you have the info you need from Wheeler now - if not let me know.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Roger, Ive got cooling pipes from dismantled cars, unless your looking for new, I may be able to find them amoungst the stuff..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- quintet
- Donor 2023
- My Cars: 2.0 hdi Peugeot 307
- x 41
I think I've got pipe No4 but i bought it for my 1.9td (without ac) & I'm not sure what other vehicles/engines it will fit. I think i posted a photo of it on the "for sale" thread for my own car.
Music keeps me going.
- Donor 2023
Thanks guys.
Once I have assessed the condition of the cylinder bores and head, I'll be in touch.
- Donor 2023
Hi Quintet,
I haven't fully assessed my heater matrix pipework as yet but how much are you looking for for pipe No.4 please?
I'll upload a photo of mine. My mate reckons it has a problem but I think the stains are from when I flushed the engine with spirit vinegar as I left the top bleed cap off for probably an hour and just kept adding hot water to the expansion tank.
- Donor 2023
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
I would advise leaving the heater matrix connector alone, as they are usually well stuck in place, and there is a chance of breaking the connector or matrix when you try to separate them.
- Donor 2023
I would dearly love to but I am 100% I could smell vinegar in the car after I flushed it so needs must! Heater matrix needs replacing methinks. Trust me! I really don't want to do the job because it is a 10 hour job unless anyone knows any useful shortcuts? I did it on Sylv's ZX and the damned thing went again 18 months later... It's sat on the drive for 8 years!
Agreed, if it was me id leave it alone too unless i was prepared to change the matrix, they can and do snap. If i wanted to flush it I would remove the hoses at the engine end & do it that way. Your choice of course.
- Donor 2023
See above Wheeler.
I think the matrix is holed.
I know I can't face doing it with the cylinder head back in place. Just having this amount of access makes me think it will save at least two hours. It was horrendous on the ZX to change. Getting access to the cover plate was nigh on impossible. BoL says you should remove the rocker cover for better access!
