Xantia Parts Request
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
I've got a part number request too when you have a moment.
For M728 GDL, VIN to be added to signature at some point today.
Cooling system hoses:-
a) The one that runs across top of cam cover and drops into the back of the fuel filter housing and down behind first glow plug. It has a T-piece in it up top.
b) One at rear of engine (probably got to be worth doing whilst cylinder head is off...
May want other cooling system ones but don't know as yet.
c) the breather from the cam cover (think it goes to oil filler?)
d) diesel supply pipe that comes up from back of engine to fuel pump (from memory - car not with me at mo)
Rhothgar
(Donor 2026)
x 221
Re: Xantia Parts Request
Now added VIN, Marc.
However, please be aware it is a mackle-up of the first part of N707 MGP and the actual last 8 digits of M728 GDL...
Hope it works. Let me know. If not, I'll have to trouble my mate to check it.
x 1055
Unread post by wheeler »
If its number 3 you need im afraid its no longer available from Citroen Part no 1351X7
what is the other pipe you need?
Rhothgar
(Donor 2026)
x 221
Hi wheeler.
I managed to split a tiny bit of it where it kicks back towards the cambelt. Should be alright... Fingers crossed.
Looking at that diagram, I am guessing it's no. 4 but I would need to look at it next time I am with the car.
No. 1 would be worth doing I think.
x 1055
4 is the heater matrix pipes, no longer available either im afraid.
x 6945
Rhothgar wrote: 27 Aug 2021, 18:58 Now added VIN, Marc.
Ok, I have the VIN - which is different. If you need this let me know and I'll email it to you.
As for the parts I take it you have the info you need from Wheeler now - if not let me know.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Roger, Ive got cooling pipes from dismantled cars, unless your looking for new, I may be able to find them amoungst the stuff..
A very sad...
1994 XM 2.1 d auto
quintet
x 44
Unread post by quintet »
I think I've got pipe No4 but i bought it for my 1.9td (without ac) & I'm not sure what other vehicles/engines it will fit. I think i posted a photo of it on the "for sale" thread for my own car.
Music keeps me going.
Rhothgar
(Donor 2026)
x 221
Thanks guys.
Once I have assessed the condition of the cylinder bores and head, I'll be in touch.
Rhothgar
(Donor 2026)
x 221
quintet wrote: 28 Aug 2021, 12:09 I think I've got pipe No4 but i bought it for my 1.9td (without ac) & I'm not sure what other vehicles/engines it will fit. I think i posted a photo of it on the "for sale" thread for my own car.
Hi Quintet,
I haven't fully assessed my heater matrix pipework as yet but how much are you looking for for pipe No.4 please?
I'll upload a photo of mine. My mate reckons it has a problem but I think the stains are from when I flushed the engine with spirit vinegar as I left the top bleed cap off for probably an hour and just kept adding hot water to the expansion tank.
Rhothgar
(Donor 2026)
x 221
Photo of my pipe. Pretty it’s fine but...
x 1463
Unread post by xantia_v6 »
I would advise leaving the heater matrix connector alone, as they are usually well stuck in place, and there is a chance of breaking the connector or matrix when you try to separate them.
Rhothgar
(Donor 2026)
x 221
xantia_v6 wrote: 08 Sep 2021, 11:10 I would advise leaving the heater matrix connector alone, as they are usually well stuck in place, and there is a chance of breaking the connector or matrix when you try to separate them.
I would dearly love to but I am 100% I could smell vinegar in the car after I flushed it so needs must! Heater matrix needs replacing methinks. Trust me! I really don't want to do the job because it is a 10 hour job unless anyone knows any useful shortcuts? I did it on Sylv's ZX and the damned thing went again 18 months later... It's sat on the drive for 8 years!
x 1055
Agreed, if it was me id leave it alone too unless i was prepared to change the matrix, they can and do snap. If i wanted to flush it I would remove the hoses at the engine end & do it that way. Your choice of course.
Rhothgar
(Donor 2026)
x 221
wheeler wrote: 08 Sep 2021, 12:40
See above Wheeler.
I think the matrix is holed.
I know I can't face doing it with the cylinder head back in place. Just having this amount of access makes me think it will save at least two hours. It was horrendous on the ZX to change. Getting access to the cover plate was nigh on impossible. BoL says you should remove the rocker cover for better access!
