High pressure fuel pump - can be repaired ?
cipi
Unread post by cipi »
Hello everyone,
My HPFP seems to be almost dead so now I'm looking to find an used one or to find a service that is able to repair it, can someone help me with the article code the high pressure fuel pump ? My car is a Citroen C4 from 2010, VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks in advance!
x 6950
Re: High pressure fuel pump - can be repaired ?
There's nothing requiring that the high pressure fuel pump needs coding - it is just a replacement, along with the high pressure fuel hose (18) that must also be replaced at the same time:
cipi
Thank you very much for your input, highly appreciated :) All the best!
cipi
Hello again,
I'm now searching for an used HPFP and they are asking me the part number which should be on my high pressure fuel pump and since I'm not sure I can remove the fuel pump by myself is there any other way I can find the part number of my HPFP ?
Thanks!
civvie
x 20
Unread post by civvie »
Someone should pop along soon to suggest a donation to the forum, as the forum is now charged for part numbers from PSA the donation would allow you to access part number info for 2 years. With this part number you would be ready to go.
Steve
C5 2.2hdi auto until I sell it (sold it) now have Peugeot 3008 1.6HDI (Now sold)
Had the jab a couple of days ago. Feb 21
x 6950
Hi Cipi, yes we can assist you with the correct parts numbers, but do ask you to upgrade your membership. This will cover you for future part number requests for up to 2 years though, so great value. Details below with more info and links:
A response to your question by a Forum Admin requiring Parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Parts Information and VIN Numbers Click Here
x 1487
Unread post by xantia_v6 »
I don't think that the Citroen part number is stamped on the pump, so knowing the Citroen number may not help to identify a used pump.
Pump replacement is quite easy after removing the air intake pipes.
