C8 Gear Selector
- (Donor 2021)
- My Cars: Citroen C8 (Charlie), Renault Trafic Camper (René)
C8 Gear Selector
Hi All,
I have a 2008 C8 173 2.2HDi Auto which refuses to go into park. My garage says it needs a new gear selector and I sourced one from France Auto (part no. 1400176480) but apparently it is the wrong one so I have had to return it. If I supply my VIN, could anyone please advise the correct part number so I can start my search again?
Thanks in advance
Thanks in advance
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: C8 Gear Selector
Hi Peter
Staff can assist with live parts data, but we do ask for a Forum donation of £10 as PSA now charge for this data now, which will cover you for up to 2 years of parts requests and parts diagrams.
If you want to go ahead, just follow the info and links below to automatically upgrade your membership and then pop your VIN up (automatically masked on post submission) and I'll be able to help you.
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
- (Donor 2021)
OK Marc, understood - donation now made!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi Peter, no worries and thanks for the donation. Just pop your VIN up for me and I'll sort this out for you.
- (Donor 2021)
Hi Marc, VIN no. is VF7**************[VIN obfuscated, can be read by forum staff]
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, so the gear selector is item (1) which also includes the selector unit (A) and the control cable (2). The Citroen part number for this combo is: 2400GJ, but is no longer available from Citroen.
However, if it is the control cable alone you need (item (2)), then that is available.
1608888480 is the control cable alone £130.63
1440160380 is the sheath retainer for the above £32.10
Prices from Citroen today and VAT inclusive.
Both are usually needed together
I did find a genuine new control cable alone (1608888480) on ebay here for £72:
https://www.ebay.co.uk/p/15028105581
- (Donor 2021)
Hello Marc - it's the selector I need apparently - so I'll set up an Ebay alert. Thank you for your help, much appreciated
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I would double check that - as it often can be the cable itself.....
- Locked user account
- My Cars: A brilliant C8 2.2 HDi 173
- x 37
I don’t want to put a downer on this but there are only about 160 2.2 173 autos registered in the uk, plus a similar number of 807s. That’s not far off how many were sold originally.
So, I would have thought therefore that there’s only a very slim chance of finding it on EBay and I guess a LHD will be different.
Good luck though, from a fellow 173hp C8 owner who absolutely loves his car !
Julian Leyton (RIP) 2023
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The left hand drive version of the AM6 selector unit is indeed a different part as Julian mentions, but the underlying control cable is the same for both.
Also if searching 2nd hand the mk2 Fiat Ulysse is essentially a C8/807.
- x 37
I’m certainly not sure about this but I have a feeling that Fiat didn’t use the twin turbo 170/173 hp engine in the Ulysse.
- (Donor 2021)
Thanks for all the responses. As Julian suspected, I was unable to find the part. However, my local independent mechanic 'modified' for me and it happily goes into park now.
