C8 Gear Selector
Peter Morgan
(Donor 2021)
C8 Gear Selector
Unread post by Peter Morgan »
Hi All,
I have a 2008 C8 173 2.2HDi Auto which refuses to go into park. My garage says it needs a new gear selector and I sourced one from France Auto (part no. 1400176480) but apparently it is the wrong one so I have had to return it. If I supply my VIN, could anyone please advise the correct part number so I can start my search again?
Thanks in advance
x 6958
Re: C8 Gear Selector
Hi Peter
Staff can assist with live parts data, but we do ask for a Forum donation of £10 as PSA now charge for this data now, which will cover you for up to 2 years of parts requests and parts diagrams.
If you want to go ahead, just follow the info and links below to automatically upgrade your membership and then pop your VIN up (automatically masked on post submission) and I'll be able to help you.
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
Peter Morgan
(Donor 2021)
OK Marc, understood - donation now made!
x 6958
Hi Peter, no worries and thanks for the donation. Just pop your VIN up for me and I'll sort this out for you.
Peter Morgan
(Donor 2021)
Hi Marc, VIN no. is VF7**************[VIN obfuscated, can be read by forum staff]
x 6958
Ok, so the gear selector is item (1) which also includes the selector unit (A) and the control cable (2). The Citroen part number for this combo is: 2400GJ, but is no longer available from Citroen.
However, if it is the control cable alone you need (item (2)), then that is available.
1608888480 is the control cable alone £130.63
1440160380 is the sheath retainer for the above £32.10
Prices from Citroen today and VAT inclusive.
Both are usually needed together
I did find a genuine new control cable alone (1608888480) on ebay here for £72:
https://www.ebay.co.uk/p/15028105581
Peter Morgan
(Donor 2021)
Hello Marc - it's the selector I need apparently - so I'll set up an Ebay alert. Thank you for your help, much appreciated
x 6958
I would double check that - as it often can be the cable itself.....
jml
Locked user account
x 37
Unread post by jml »
I don’t want to put a downer on this but there are only about 160 2.2 173 autos registered in the uk, plus a similar number of 807s. That’s not far off how many were sold originally.
So, I would have thought therefore that there’s only a very slim chance of finding it on EBay and I guess a LHD will be different.
Good luck though, from a fellow 173hp C8 owner who absolutely loves his car !
Julian Leyton (RIP) 2023
x 6958
The left hand drive version of the AM6 selector unit is indeed a different part as Julian mentions, but the underlying control cable is the same for both.
x 1044
Unread post by wheeler »
Also if searching 2nd hand the mk2 Fiat Ulysse is essentially a C8/807.
jml
Locked user account
x 37
I’m certainly not sure about this but I have a feeling that Fiat didn’t use the twin turbo 170/173 hp engine in the Ulysse.
Peter Morgan
(Donor 2021)
Thanks for all the responses. As Julian suspected, I was unable to find the part. However, my local independent mechanic 'modified' for me and it happily goes into park now.
