What is this for?
Romtag
x 8
What is this for?
Unread post by Romtag »
Whilst doing some maintenance on the 807 I came across two zipped tied wires at the front of the car.
I've attached pictures of coding for them in the hope that you lovely FCF boffins can tell me what they are.
Secretly hoping it's the plugs for the front parking sensors 🤔
Mark
Owner of a 2013 308 SW
x 6945
Re: What is this for?
Unfortunately not, those are the wiring connectors for the front fog lights.
See on the Diagram item (1) - this is the harness in your picture. Harness (2) below that is for the front obstacle detection.
Romtag
x 8
Thanks Marc!
I will have to get under the car to trace the wiring for the sensors then.
Thanks again 👍
Mark
x 6945
You may not have it - but it's a possibility - before they got tight!
Romtag
x 8
I have the sensors but they don't engage.. it's the nordwest model and I think you checked and said I should have them. The sensor ECU has both sets of wires (front and back) but they just don't work.. no errors either .... Annoying!
Mark
x 6945
Ah yes, of course, with so many issues I can't always remember on the spot :lol:
So my feelings (and apologies if I've said this before or you've already done this), are to check with PP2000 / Diagbox if the system has been disabled in the BSI. Some people have been known to do this if they don't want to replace a faulty sensor. If memory serves I think you already checked the loom out at the rear. I don't see it being a fuse as this 20A fuse also controls the Audio / Display / Alarm Sliding Door control unit etc.
Romtag
x 8
Yeah.. nearly £1200 into repairs and maintenance costs so far....
Including, new left wing mirror, new air-conditioning pipes, new coolant pipes, full service.
Had towbar fitted bit because of hacked wiring that's also been complicated to finish!
Where and what is the best route to go down with PP, I know I need hardware and software.
See lots of stuff on eBay and Ali Express but not comfortable without understanding more...
Mark
x 6945
I and many members bought mine from Easydiagnostics - link here for a member discount:
viewtopic.php?t=60112
You need a laptop yourself preferably with Windows 7 and it must be a 32 bit version of the operating system as PP2000 won't work on 64 bit operating systems natively.
The hardware is a VCI, that should be a good quality full chip revision C clone. The software is modified to work for us on the aftermarket so ins not sanctioned or officially available from PSA. If you do get one, update it to version 7.58 only and you should be fine.
x 1055
Unread post by wheeler »
Are your reverse lights working as they should?
Romtag
x 8
wheeler wrote: 08 Jul 2021, 18:08 Are your reverse lights working as they should?
We'll, yesterday everything stopped working, but as the mechanic untangled it all they started working again. Why do you ask?
Mark
x 1055
The reverse light switch is used to trigger the parking sensors on, if the reverse lights are working ok this means the reverse switch is working.
x 3296
The other thing the reverse switch can do is to tell the cabin ventilation system to switch over to recycle (from taking in outside air), so it does not draw in exhaust fumes as you reverse over them.
Romtag
x 8
wheeler wrote: 08 Jul 2021, 20:23 The reverse light switch is used to trigger the parking sensors on, if the reverse lights are working ok this means the reverse switch is working.
Aaah yes the reverse parking sensor are fine, it's just the front ones.. to all extents the car doesn't see them.
I don't know anyone with PP locally so can't investigate further, other than checking the wiring loom.
Mark
Romtag
x 8
Hell Razor5543 wrote: 08 Jul 2021, 20:37 The other thing the reverse switch can do is to tell the cabin ventilation system to switch over to recycle (from taking in outside air), so it does not draw in exhaust fumes as you reverse over them.
Really? That's surprisingly smart for Peugeot! 😂
Mark
x 3296
Romtag wrote: 08 Jul 2021, 21:07
There are some Forum members who have the Lexia equipment and may be able to help out. Please be aware that some of these members have 'gone quiet' do may not respond to a PM. Here is a link to the map;
https://www.frenchcarforum.co.uk/forum/ ... hp?t=56452
