MyDS App
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5712
Re: MyDS App
I assume you've followed all the instructions and the video here?:
https://dsautomobiles.my-customerportal ... uage=en_GB
Re: MyDS App
Yes followed to the letter and the service says activated under my services on the app. But on the Home Screen of App nothing new appears and we get a little message “ state at -/—“ at top.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: MyDS App
Ok and did you activate and register it and pair with the key as per this? Their videos are all over the shop, but looking at your screen it is not displaying the status (date / time) is missing on the App, which is indicative of the App not being connected to the vehicle or not being able to communicate. So if it has been paired and registered with your smartphone (and assuming your smart phone is supported) could it be the WiFi signal / connection?
Re: MyDS App
Yes it was step 3 sitting in the car with key and phone to pair which made the service go green "service activated". I have connected my car to my home wifi, work wifi and mobile hotspot and all say connected but still no joy. If I got into Connected Services via the console in the car is just get a red exclamation mark and information telling me about the MyDS app.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: MyDS App
Ok, so that sounds like it hasn't been activated from their end. Similar services on my Connected Nav system require me to log into the App and then to select the relevant service and enable it from there - even the free ones have to be enabled before they become active. So I would suggest logging into your app, ensuring the VIN is correct and then checking through the available services and checking to ensure they are enabled from there first.
I had this on my connected services live TMC and other info. Although it is free for 3 years, it hadn't been dealer-enabled, so once I registered on the app submitted VIN and the rest of it, I then had to select the service from the App. and activate it. Then it had the start and end of the contract date shown and shortly afterwards became available on the Connected Nav system in the car.
It's very similar to the Risk Zones (Speed Camera Alerts Service) - this is subscription only - and if you activate the 'Risk Areas' feature on the Connected Nav, without actually subscribing, you will just get a Red Exclamation mark on the screen (mine shows a red triangle with exclamation mark in the middle). So I just went into options and turned that off to get rid of it.
Re: MyDS App
I have just spoken with DS Support and it is definitely activated, it just doesn't work. I have followed all their instructions, deleted the paired phone and done the pairing again. But nothing, just doesn't work so I think there is something wrong somewhere, I am using the VIN which they provided on the paperwork, where do I find it on the vehicle to double check?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: MyDS App
Your VIN is on your vehicle log book (V5C) and should also be stamped on your lower passenger windscreen corner - there is a cut out that allows the VIN to show through.
What Make and model of phone are you using? I'll check it up on the compatibility tables.
Re: MyDS App
IPhone 11 IOS 14.3
Re: MyDS App
I have checked and the VIN is spot on
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: MyDS App
Ok, so typically, Nextgen (who provide the info portal for PSA) are behind again with the phones. The iPhone 11 is not listed and the latest phone they have is the XS Max and the latest IOS version listed is 13.1.3!
I shouldn't expect there to be any issues with the iPhone 11 or IOS 14* though to be honest, although sometimes they can include a later Bluetooth profile or update that can have some connectivity issues.
If you had an earlier iPhone, it would be useful to try that and then if it worked you would know it was the later phone or IOS version.
I know this can be a right pain. If you don't have any luck then it will have to be a dealer issue - but I know some of them are less clued up on these than the customer, so be aware
Re: MyDS App
Thanks for the info , I think I have a iPhone 7 spare I will have a look later and report back.
Re: MyDS App
I have now tested this using a iPhone 6 IOS 13.2.3 with exactly the same result. Leaving me thinking this must be an issue out of my control.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: MyDS App
I agree, so at least you can tell them that you have followed all the logical steps to resolve it from your end, including using a compatible phone as per their list too.
Best of luck resolving it - but do let us know how you get on as I'm sure it will be of interest to others.
- New User
- My Cars: DS 3 Crossback E-Tense
Re: MyDS App
Hi actongate, I have a 71 plate DS 3 E-Tense and have exactly the same issue with the remote control app, did you manage to get it resolved as I'm stumped.
thanks
Steve
thanks
Steve
