Hi all.
I have a 2.2 2007 Citroen relay. Does anyone know where I can find a fuse/relay diagram?
I need to find the fuel pump relay and the only diagrams I can find don't match.
The fuse box under the bonnet has a diagram inside the box but where it says the relays should be there's nothing. The lid must be a generic part so my relays are located somewhere else.
Citroen relay fuel issue
- x 1746
Re: Citroen relay fuel issue
Hi, and welcome to the forum.
If you could post your VIN (which will appear masked, except to forum staff), it will help us post the correct diagrams.
Stuwie93
VF7**************[VIN obfuscated, can be read by forum staff]. Thanks for the quick reply
Stuwie93
Does anyone know the location of the relay? I see there's one on the inside of the wing behind the headlight but other than that can't see any obvious ones
- x 1056
whats the last 8 digits of the VIN?
It will be in the under bonnet fusebox behind the LH headlamp.
Relay T10
The last 8 digits of the VIN will confirm.
Relay T10
Stuwie93
11087974 o okay. So it's just one of the smaller relays. I was expecting a big one on its own.
- x 1056
I have updated the previous picture, the position is the same but it may be marked as either R7 or T10.
Stuwie93
Top stuff. Thank you so much
Stuwie93
Do you have the full list. I've got it working but would like to make sure all the others are okay whilst I'm in there.
Stuwie93
Could you tell me what R4/t17 is for? I've temporarily used the relay from there. Been for a drive and the van seems fine so either it's not important or something wasn't working before there either
- x 1056
R1-R12 are on the last pic I posted.
relayuser372328
- New User
is this the same for a 2015 citroen relay? I have a 2015 and have been struggling to find where to locate the fuel pump relay so i can wire in an anti theft kill switch
