Citroen C4 Grand Picasso (2013)
thatguysc
Unread post by thatguysc »
Morning all,
I'm looking for some advice because I am getting conflicting information from garages.
My car failed it's MOT the other day with a few issues which have no been resolved. However, it failed on the "positioning lights" not working on both sides at the front of the car.
Can someone please explain to me where these positioning lights are?
Thanks in advance
For reference it looks like this Image
x 6945
Re: Citroen C4 Grand Picasso (2013)
Well it should be down to the MOT people to tell you which ones and point them out to you as their terminology is not always correct.
Headlamps - obvious enough if these are working for Low and high beam, or not and the same for the DRLs, Fog Lamps and sidelights.
The only exception is if you have Xenon Directional Headlamps - but if these are not working bulb-wise it will still be obvious. They only check that the bulbs are working and that the beam pattern is correct, not the directional function - and you can temporarily turn this feature off for the MOT anyway if you have these fitted, should you wish.
So if you think ALL the lamps and bulbs are working, then you need to go back and get them to explain - you have paid for a test and are entitled to know what they have found a problem with.
If your LED DRLS are not working then this will likely be a fail as they were required on cars from about 2011 on I think.
The DRLs I have highlighted in Yellow and marked in Red:
x 5673
They are what used to be called parking lights or sidelights.
It looks as though those are part of the headlight assembly, assuming that the lights below the DRLs are foglights.
Check your handbook for the fuses as it is unlikely that both will fail at once although that can't be ruled out. Do the tail lights work - these should be on at the same time.
They could be easy to change or very awkward. C5 ones weren't too bad but the rest were a bit of a nightmare.
thatguysc
Thanks for the replies.
So I have done a full scan of all the lights and the only ones that do nothing are the ones highlighted in the image below
but on further inspection under the bonnet, these lights are attached to plastic clips and have no cables running into them at all
x 6945
It might help if you pop your VIN up here (it will be masked on submission) and then I can see the exact lights you are referring to once we have the exact model. However if this the Mark I C4 Picasso 2013, then the side lights shown use H6W-6 W bulbs:
These things:
The power for these may be supplied by the lamp housing itself like on the rears, so you won't necessarily see any wiring. The plastic holder requires a quarter turn anti-clockwise to remove.
It's all in the manual.
thatguysc
Thank you for the help.
Yes you're dead right. I can now see exactly what you mean by the housing providing power.
I have replaced both bulbs with no luck. The contacts look pretty clean.
Is there a fuse for these? I did have a look in the manual but nothing stands out for these bulbs.
Sorry and I appreciate all the help offered
thatguysc
What it does say in the manual that when LED lamps are fitted (which they are are, above the fog lights) the filament bulbs for the side lamps in the front lamp units are not used
x 6945
Ok, so there is your answer then - take that back to the bloke who did the MOT and show him - and they should not charge you anything further than what you have paid and make sure that they correct the earlier MOT comments on the failure - otherwise it will be recorded as such on the MOT records for all to see. It's not your fault the bloke didn't do his homework properly.
If he doesn't sort it - report the centre / make a complaint.
thatguysc
Can't thank you enough for your help
x 6945
Good luck - let us know how you got on :-D
myfirstpicasso
Unread post by myfirstpicasso »
thatguysc wrote: 13 Dec 2020, 12:03 Thanks for the replies.
So you are telling me i just paid 12$ for a pair of H6W bulbs that are never used ?
Are these stand / side / parking light never used when DLRs are installed or not used when DLRs are activated ?
Why did Citroen not use a dummy cap instead of the installed bulb holder + H6W bulb ? > this sounds crazy
x 6945
It is possible that the sidelamps are were not fitted with bulbs, although the holders should still be there.
These are the 2 lamp types and they are illustrated as being present for both types, but specs. change and this model year was the last before the replacement came out, so they rarely go back and update handbooks.
At the end of the day, if you have DRLs they're not needed, but if you have the holders and want to fit them, knock yourself out - with the caveat below:
I should add that if the sidelamps are fitted, you have fitted bulbs and they are not working, then yes, it is likely they are not configured to work with the DRLs activated (which are much better in any case). I hope you kept your receipt :-D
