405 manual transmission fluid
Post Reply
RONDO
My Cars: Own:
1995 Peugeot 405 GL SR 1.8l Signature "Style" - petrol
2009 Peugeot 407 SW 2.2l Twin turbo diesel
Post by RONDO »
First post ... saying hello to everyone! 8-)
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 3008
Re: 405 manual transmission fluid
Post by Hell Razor5543 »
Hi, and :welc: to the Forum.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
slackgarry
Donor 2023
My Cars: Black 2008 C1, 1KR-FE Engine. aka the GoKart
Post by slackgarry »
Welcome. You have come to the right place..
Kind regards
SlackGarry
Black 2008 C1, Petrol, 1KR-FE Engine. aka the GoKart
405chap101
My Cars: A sheddy 1992 Peugeot 405 GRDT estate
x 3
Post by 405chap101 »
Ooh, you've got a late base model!
GoceKU
My Cars: Peugeot 607 2,7 HDI 150Kw
Peugeot 405 SR
Peugeot 405 GLD
Peugeot 405 Mi16x4
Peugeot 405 RWD
Peugeot 605 SRdt
Peugeot 605 V6 3.0 auto
Peugeot 605 2.1td
Peugeot 605 Sri
Peugeot 206 1.4i
Renault R19
Ranault Megane Coupe
Renault clio
Lada Niva 1600
Fiat 600
Post by GoceKU »
Total 75w80 is what i use in my BE3 gearboxes
Pug_XUD_KeenAmateur
(Donor 2018)
My Cars: 405 naD Est
x 232
Post by Pug_XUD_KeenAmateur »
just given my 'new' box 75W 80 today, having found the attached while I was sorting out my documents.
Puxa
My Cars: 1996 XM 2.5TD Exclusive hatch RHD
and lots of Rovers before that: 1935 Ten, 1947 Sixteen, 1960 P5 3-litre, 1966 P6 2000, 1972 P6 2000TC, and 1975 P6B 3500S
x 1752
Post by white exec »
Correct oil is 75W-80 gear oil GL-4.
The Total item is Transmission 8 Gear oil, which is the above spec. Available at any Peu/Cit parts counter as well.
Important to use GL-4, and not GL-5 (or 4/5). GL-4 contains the correct friction additives for the synchromesh to operate correctly.
RONDO
My Cars: Own:
Post by RONDO »
Greetings from France and thank you all for the welcome and the advice.
Took 4 months to register the 405!!!! Glitch in the French system - amazing.
I recently had the BE3 trans fluid changed by a local garage - IGOL 75w80; can't confirm if it was GL-4 but will eventually put the Gear 8 in it as 'white exec' recommended.
Trans shifts smoothly now and I have discovered that I had been a little too aggressive in changing gears which caused
slight consternation in the synchromesh ranks; nothing major. I've now learned to change the gears swiftly, directly and gently. Next fluid change will be done by yours truly.
I've racked up 8K kilometers on 5w-40 Shell Helix Ultra fully synthetic oil; which seems to be doing just fine. No leaks, sounds the same as before and keeps running smoothly.
There is now a total of 68K kilometers on the clock - it's just a pup!
By the way ... White Exec ... did you want me to pm you?
I've also noticed that the springs in the transmission gates are still very solid and actually reminded me that I unintentionally pushing the gear stick at a slight diagonal forward when
changing the forward gears, causing the slight crunch on the syncros. Having driven some ancient Ford and Kenworth fuel tankers and floating the gears; I should have known
better.
Many thanks to you all again,
RONDO
Post Reply
