Find the answer in the FCF..
Re: Find the answer in the FCF..
Just found out that the Hungry Horse Chain have a pub called the "LoDekka" bit of a link back to the Bristol Lodekka which made its way to be a cafe at the Chainbridge Honey Farm :-D Bit more delving and the Bristol Bus Building heritage started off in Brislington!
Brislington old tram depot
Geof Sheppard / CC BY-SA (https://creativecommons.org/licenses/by-sa/4.0)
x 2938
One of my lady customers had a butcher's business around Bristol, she had one of her shops in Brislington
x 8144
This may get a few cogs turning. What was the problem with this:
BFTF
BFTF
All the sevens on the likes Mick!
Looks like I may have to delve into a dark area of the forum I have never ventured into before......I just about understood coathangers for aerials... :-D
x 8144
Excuse a little celebration of the triple seven:
BFTW
BFTW
mickthemaverick wrote: 02 Jun 2020, 21:35 This may get a few cogs turning. What was the problem with this:
Well I found the post Mick
Spoiler: show
mickthemaverick wrote: 14 May 2019, 21:58 Image of the one I ordered:
[urlImage][/url]
Well Marc reckoned this....
Update: In light of what Paul has said, I can now see that the aerial you have purchased is for a MK II C5. These have completely different Head Units and Telematic Units, so is not designed for the earlier model.
mickthemaverick wrote: 18 May 2019, 15:20 The replacement head unit arrived today, having been coded prior to despatch, and I installed it immediately to find full radio service is restored!! So I can now confirm that the MK1 4 cable aerial can be replaced with the MK2 3 cable unit and both radio and sat nav work correctly. Don't know about the phone interface because it is not fitted to my car. However I hope that bit of info proves useful to other MK1 owners with aerial problems. I'm off to cruise the countryside and listen to the Cup Final!! :) :) :)
Well I think that covers it. Where does the coathanger connect?
x 8144
The secondary story here is that a few weeks ago, before lockdown, I noticed a deterioration in the AM radio signal. I found another 3 tail aerial on ebay and ordered it. I also found and bought a new head unit because the screen had begun to flicker and when both arrived I put them in the boot and the performance improved overnight. I think I posted that up at the time! Anyhow two weeks ago the AM began to deteriorate again so last week I decided to replace the antenna. When I pulled down the roof lining I discovered that the 3 tail aerial I had bought only had 1 plug the same as the car. I immediately came indoors and searched for the correct replacement. Luckily I found an original 4 tail aerial and ordered it immediately. I then went back to the car and reconnected the existing aerial while I await the replacement. Guess what.......it has been perfect since then so when the replacement 4 tail arrives I will have the dilemma of do I leave it alone as it is working or do I swap it out for the correct part which I should have fitted a year ago? :? :? :? :-D :-D
ReFind the answer in the FCF..Q9
bobins wrote: 03 Jun 2020, 17:52 If it wasn't the Rapier, then it was probably the Minx.
You can see whay they called it the Alpine as it shares so many similarities with its namesake the Sunbeam Alpine - they both had 4 wheels, they both had some doors....ummmmm there must be more similarities than that ? :rofl2:
Find the answer on the FCF Q8
Bobins Mentioned the "Sunbeam Alpine" today in our whatsthisthen? In different incarnations in 2 iconic Movies it has been mentioned on the FCF.....What are the two Movies :?:
x 8144
TOH
Spoiler: show
Get Carter and Dr No ?
mickthemaverick wrote: 03 Jun 2020, 19:09 TOH
Spoiler: show
Have a little paddle Mick not difficult to find although I did expect you to come up with your number 2 which is right. I think I did a post ages ago about a bit of misidentification of that one. As for your number 1 the film and the car and the location were a touch more glamourous. However saying that check with IMCDB and I wouldnt be surprised if you found a version of the alpine in your number1.
regards Neil
and it does in a major way as it turns out. So both correct.
See if you can find the glamourous one though!
x 8144
My number one definitely had one in it. The girl that rescued Jack from his London Buddies did so in the alpine and then she was locked in the boot when it was shunted into the river!! However I have reason to believe you are looking for
Spoiler: show
To Catch a Thief
as your number one?
Spoiler: show
BFTF
BFTF
mickthemaverick wrote: 03 Jun 2020, 20:05 My number one was definitely in it. The girl that rescued Jack from his London Buddies did so in the alpine and then she was locked in the boot when it was shunted into the river!!
I re-edited my post Mick as The Alpine in Get Carter was a three star rated ca r[*][*][*] Vehicle used by a character or in a car chase!
so right answer for 1 and 2, but heres the glamour one....Grace Kelly and Cary Grant as you have just posted while i was typing!
NewcastleFalcon wrote: 27 Feb 2016, 10:21 A previous incarnation of the Sunbeam Alpine with Grace Kelly and Cary Grant
..and the BBC made a little Faux-pas when introducing an item on Aston Martin building a new model in South Wales, against a background of JB driving a Sunbeam Alpine in Dr No.
NewcastleFalcon wrote: 27 Feb 2016, 09:36 From the BBC Report........"Its Bond's Favorite motoring brand and now a new model is to be built in South Wales"......so which model is it?......(picture below...not the new model)....no further clues....(just yet :) )
Find the answer on the FCF Q9
What is the name of the Pub described by an FCF Member as the highest and most remote pub in Southern England :?: and where had they walked to earlier that day. :?:
