I'll amend that bit about the Hydraulic clutch Mike - I should of said it's about the clutch fork mods.
From build dates 6748 (01/05/1995) to 7113 (30/04/1996)
Clutch: All types except for: Turbo CT , 2.1 Turbo D
"push" type clutch : 1.6i, 1.8i, 1.8i 16V, 1.9D vehicles.
"pull" type clutch : 2.0i, 2.0i 16V vehicles, 1.9D Turbo D.
Clutch: Turbo CT, 2.1 Turbo D
"Pull" type clutch.
Hydraulic clutch control: Type XM.
Pre-filling of hydraulic fluid, this type of control, tight and without maintenance, enables the automatic adjustment of the clutch pedal movement.
The clutch pedal movement isn’t adjustable.
The clutch control consists of:
Hydraulics reservoir - Bulkhead (engine side). The tank supplies the fluid needed for the control’s functioning
A transmitter cylinder controlled by the clutch pedal
A receiver cylinder, fastened on the clutch housing, enabling the change of position of the fork
A transmitter-receiver connection ensured by hydraulic channeling
In the case of failure, the clutch control has to be changed completely.
This is the mod:
Applicable to ML5T and BVM5 boxes since build date: 6951 (20/11/1995)
Vehicle application:
XANTIA Turbo CT
XANTIA 2.1 Turbo D
The mounting for the slave cylinder is built into the gearbox.
(1) Gearbox.
(2) Slave cylinder.
(3) Support.
(4) Piston rod.
(a) Location of the gearbox identification number.
Part removed: Slave cylinder mounting (3).
Modified parts:
Gearbox: The slave cylinder (2) fixing boss is thicker by 19 mm
Clutch control: The slave cylinder(4) push rod (2) is 12 mm longer (107 mm, instead of 95 mm)
| Gearbox reference |
| Vehicle | New | Old |
| XANTIA Turbo CT | 20 LE 15 | 20 LE 06 |
| XANTIA 2.1 Turbo D | 20 LE 14 | 20 LE 00 |
Clutch Control
The length of the push rod distinguishes the new slave cylinders from the old ones: (107 mm, instead of 95 mm).
Clutch Control
The old slave cylinder is no longer available from the Replacement Parts Division.
The new slave cylinder, together with 2 push rods, is available from the Replacement Parts Division.
Replacing an old slave cylinder with a new one:
- Fit the slave cylinder with the long push rod to the vehicle
- Press the clutch pedal to break the pins holding the push rod
- Remove the slave cylinder
- Replace the long push rod with the short push rod
- Refit the slave cylinder
Gearbox
Only the new parts will be available from the Replacement Parts Division once stocks have been exhausted.
The long push rod ( 107 mm) is available from the Replacement Parts Division.
Replacing an old gearbox with a new gearbox:
- Remove the slave cylinder mounting
- Fit the slave cylinder with a long push rod ( 107 mm)
Going back to the judder, these can be some of the causes - as defined by LUK clutches (note this is generic info and not specific to PSA vehicles), but may be useful nonetheless:
Possible Causes of Clutch Judder
Incorrect grease on splines:
- Grease containing solids has been used
| Tangential strap bent:
- Incorrect driven practice
-> Tow starting in 1st or 2nd gear
- Incorrect storage
-> Dropping the clutch prior to fitting
- Clutch not bolted up evenly and sequentially
Diaphragm spring fingers bent:
- Incorrect fitting
-> Diaphragm fingers bent during fitting
| Facing contaminated with grease:
- Surplus grease not removed
-> Grease has been thrown out on to the facing material
Wear marks on release bearing inner bore:
- Incorrect grade of grease or no grease used
- Damaged or worn gearbox snout
| Facing worn on flywheel side:
- Flywheel not replaced
- Contact surface on the flywheel not re-machined
Damaged hub splines:
- Incorrect fitting
-> Gearbox input shaft and hub splines not correctly aligned
prior to fitting
-> Driven plate not centered
- Incorrect driven plate
| Release bearing worn:
- Release fork worn
- Release system damaged
Release bearing incorrectly lubricated:
- Use of a solids based lubricant
| Worn gearbox snout:
- Release bearing worn
Push rod wear mark off centre:
- Damaged release system
-> Bearing worn
-> Guide bush worn
| Flywheel scored:
- Flywheel not re-machined/renewed
Tangential strap damaged:
- Excessive free play in the drive joints
| Damaged bearing lugs:
| Facing contaminated on the inner
portion:
- Damaged oil seal
- Excessive grease used on the splines
