Peugeot 207 ABS pump
Hi, I wondered if someone could help me please.
I own a 2007 Peugeot 207cc with a faulty ABS pump. I have been trying to find a used one but have been told I haven’t got the correct serial no. The one I have been providing starts ‘1009’ but have been told that I need the one starting with ‘96’. My mechanic rechecked the pump but could not find any other serial no’s so I contacted Peugeot & the only part number they could provide for the pump was 4541Z3. I have searched using this part number & have found matches but I’m not sure just cos the part number is the same that the pump will work in my car.
Any assistance/ guidance would be very much appreciated. Shaz
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Re: Peugeot 207 ABS pump
Hello, and to the Forum. Might I suggest, as a first step, you post up the vehicle VIN (which will, for security reasons, be obscured so only Moderators can read it), so that a Moderator can look up your vehicle and let you know the correct part number for the ABS pump for your car (it may turn out Peugeot is correct with that part number).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Put your VIN number (from the outside lower passenger windscreen - in the cut out) here - it begins VF3**************[VIN obfuscated, can be read by forum staff]. The ABS pump consists of an electronic control unit (ECU) and the hydraulic block. Depending on what is wrong you can either replace the whole unit or keep the ECU part and just replace the block. If your replace with another unit it will need coding to ensure the parameters are correct for your vehicle. If you retain the your existing ECU and just replace the block then it won't need coding.Shaz61 wrote: ↑16 Sep 2019, 16:14 Hi, I wondered if someone could help me please.
One I have your VIN I can check the correct PSA part number.
Hi Marc, thanks for replying. I thought I had posted my vin no. to James but it doesn’t look as if it’s gone through so Being a newbie I may have made a mistake. My VIN is VF3**************[VIN obfuscated, can be read by forum staff].
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
He can't read it - only staff can.
So the parts are no longer available new from Peugeot - but there are 2:
Item 1 in the diagram:
4541 Z3 or
4541 Z4
The difference being one is pre-configured to the vehicle and the other is configured afterwards - but I've supplied both.
4541 Z3 or
4541 Z4
- Donor 2023
- x 3008
Please accept my apologies; what I should have said is for you to post your VIN HERE in the thread, not as a PM to forum members.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Skull
- My Cars: Citroën Xantia XII HDi
Citroën sAXo XII
Missing AX 1.4D Echo - x 225
Shaz
Can I butt-in and ask if the same would apply to my 2000 Xantia HDi - I intend to swap mine with a second-hand ABS block & ECU set ?
GiveMeABreakGiveMeABreak wrote: ↑16 Sep 2019, 17:41 ..... If your replace with another unit it will need coding to ensure the parameters are correct for your vehicle. If you retain your existing ECU and just replace the block then it won't need coding.
On my 4th Citroën Xantia (X2 HDi (110))
Citroën sAXo Memphis Mk II
Gone
Xsara HDi VTR Coupe / Saxo 1.1i / BX 1.9 d / 4 x AX's (1.4D /1.5D)
2 x 406 (1.9 TD Estate/2.1 TD Saloon) 405 1.9 D Estate 306 1.9 XTDT Hatch
Gone
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, as long as you are replacing the exact same ABS block then the ECU is removable and swappable. Pop your VIN up so I can double check your model.
- Skull
Citroën sAXo XII
GiveMeABreak Cheers
So a second-hand ABS block & ECU set both off the same scrap car would need coding Unless I use the original ABS block
Electrickery isn't my favourite subject ....
Gone
Gone
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, if there’s nothing wrong with your ECU best to keep,it then you can just attach it to the new block and refit,
454142 is the block part number.
- Skull
Citroën sAXo XII
Thanks a lot for confirming that Marc. If I run into trouble I'll send you a PM to avoid embarrassing myself
Gone
Gone
Hi Marc, apologies for not getting back sooner.
Thanks for the information unfortunately my mechanic has advised me that I need the whole unit changed so I assume that whichever part I buy will need coded (Z3 or Z4).
In my earlier post I was looking for the serial number starting ‘96’ for my unit as I was told if I could match this number with one on a used pump I wouldn’t need to have it coded. Is there anyway of tracing this number for my unit or am I just wasting everyone’s time trying to find it.
Thanks again for your help with this problem.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Those manufacturer numbers will likely only be listed on your actual ABS unit itself - you may need to clean the area of the casing to see it or the label if present.
The part numbers I have issued are correct so if you search on ‘Peugeot 4541Z3’ or Z4 you should find parts that may also have the 96 number. You just need to compare it to yours to make sure it is the same.
I’m surprised that your mechanic hadn’t been able to diagnose whether it is the ABS ECU or the actual ABS hydraulic block that is faulty though.... however if you are going second hand, you may find more of the units are supplied whole. But use the ‘4541Z3’ for searching as that would be the preconfigured one for your car.
Thanks Marc, I’ve already asked my mechanic to check for the label but unfortunately it’s no longer there..
As to what the problem is my mechanic has just told me it’s a problem with a sensor in the valve block causing an issue with the ECU.
It’s been an ongoing saga for quite awhile & has left me with a car I can’t drive cos it won’t pass the MOT so I really appreciate the time you have taken to help me with this problem.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, no worries - good luck and keep us posted.
