No Satellites Issue
Moderator: GiveMeABreak
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: No Satellites Issue
No worries, the head unit is easy to take out, you just need the 4 flat blade keys to remove it. Might be worth doing to a) check the blue GPS connector isn’t loose, or b) to bypass the GPS cable to rule that out.
Last night on motorway where there were no buildings I got 4 satellites so I’m defo now thinking antenna will test with temp and return a verdict in a few weeks
Final update new antenna has arrived instant 8 satellites this is the antenna https://www.ebay.co.uk/itm/Clarion-all- ... 6946453006
Plugs into the plug in the roof lining so no radio out going to order new sharks fin just for originality thanx for all the help and advice Marc
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No worries - at least the head unit wasn't toast and an aerial or 2 is a lot less expensive!
- My Cars: Now:
C5 X7 HDi 240 Exclusive Tourer
ZOE 22kwh Intense
Before:
C4 1,6 Coupe Automatic
C5 X7 HDi136 Exclusive Sedan A
Xantia HDi110 Berline
Xantia 1,8SX Berline - x 28
I just noticed that I have this issue too. Position on map was wrong, and no height available. Did factory reset and after that there´s no position on map at all. Earlier this week MyWay rebooted once while I was driving to work. It restarted quickly and radio worked fine after that. Might be somehow fried HU I´m afraid...
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Don't forget that after a reset, or restart, it can take driving around for 3 miles to get correct positioning:
From the last page:
viewtopic.php?p=615684#p615684
...and make sure you've done the mod to uncheck synchronise date / time with GPS option.
From the last page:
- My Cars: Now:
ZOE 22kwh Intense
Before:
I did drive about 20km after reset. It´s not even possible to synchronise with GPS, it´s grayed out (and it wasn´t checked earlier).
I guess it´s the Joying way then... BTW, what is the part number for that "empty box" that is installed in the place of radio with SMEG? I tried to look at it in the service.citroen, but couldn´t find.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
There's a combination of different side fascia plug modules (volume + / -) etc that replace the ones that are there in the central console and a combination of cubby hole and push to open / close storage.
- My Cars: Now:
ZOE 22kwh Intense
Before:
it´s 98120802ZD I guess.
- My Cars: Now:
ZOE 22kwh Intense
Before:
GPS came back after 2 weeks on a longer journey (after 100km constant driving). Today radio died and only cd-player works.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Citroen c4II 1,6Hdi 68kw 2011
RNEG navigation, currently not working satellites. No NM/v also. Compas and radio are OK.
This happened after I washed my car it that automatic washing machines at the gas station.
My antenna has 2 wires. Antena base Number is: PSA 9666567580-01
I restarted the ECU, nothing.
what to do?*
Mayybe to update RNEG software? Can somebody send my files in inbox or email?
Should I buy this: https://www.olx.ba/artikal/35725277/aut ... fakra-gt5/
what to do?*
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Updating the firmware is not recommended whilst there is a fault with the system as that may leave it in a worse condition and hinder troubleshooting.
Your biggest clue is what you have already mentioned - water. If this has got into the aerial base unit, it will have got into the electronics and probably is shorting or causing interference. You may be able to get in via the headlining at the rear light and investigate dry it out.
Thank you Marc.GiveMeABreak wrote: ↑03 Feb 2021, 15:35 Updating the firmware is not recommended whilst there is a fault with the system as that may leave it in a worse condition and hinder troubleshooting.
I already did that and check for water leakage at the roof, and didn't see water there. Maybe it is a faulty base and antenna. This is my original antenna: https://s9.pik.ba/galerija/poruke_uploa ... b620f2.jpg
I just ordered used one for 25euros from another C4 with a navigation system, this one (same connectors as my C4): https://s9.pik.ba/galerija/poruke_uploa ... 950abb.jpg
Will inform you what happened when make a replacement.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, the circuitry is inside under the 4 screws of the base.
Depending on your options there may also be aerial equipment in the tailgate, the amplifier and screen printed aerial if relevant to your car.
