No Satellites Issue
Dazzaneal
No Satellites Issue
I have an x7 where the serial numbers menu says heading illegal serial number and no satellite signal help lol
- x 6948
Re: Replacement Radio Citroen C5
I'm assuming you have an RNEG (MyWay) or RT6 (eMyWay) system - pop up your VIN for confirmation.
Regarding the message - that is not a message you will have received normally -you have obviously gone into the system menu to troubleshoot your satellite issue and discovered the serial number message. This is normal! They all have this and should be ignored - customers are not meant to access this particular menu. I would also not change anything there or you could render the unit inoperable.
Once we know what system you have via the VIN I may be able to help further.
Dazzaneal
I have pm’d you my vin
- x 6948
Re: No Satellites Issue
It's ok, the VIN is automatically masked here in the public forums anyway - only staff can read them, but I have it now.
So as you have the MyWay system, I've moved this thread into the correct section.
- x 6948
What versions of firmware are you running on your MyWay and what is the current mapping version you are using?
Also, how many satellites are showing as visible - it will need a minimum of 4 to work properly. You can find this out by starting the car, wait for the system to start up, then hold the SETUP button in until the menu appears. Scroll through the options until it shows you the number of visible satellites.
If there are a low number, then I would be suspicious of the GPS aerial. Water ingress through the aerial base can cause issues.
This issue has been cured by doing a proper reset of the Car's ECUs. It may not work in all cases, but has been known to resolve many satellite issues. Follow this procedure exactly and don't skimp on the timings:
Dazzaneal
Ok on a side had a look at the base of my antenna and there is only 1 wire coming from there
Dazzaneal
Latest maps and firmware
Dazzaneal
Could I have the part number and price of a new antenna base please
- x 6948
Ok I can do that - but do try the battery disconnect and reconnect procedure I linked to first - it's the official procedure to reset the system and has to be done to ensure the system is cleanly restarted, because the unit continues to be powered when the ignition is switched off.
Aerial cable assembly part number: 6561QZ. Price £84.86 inc. VAT
Aerial Base Unit part number: 6561RE, Price £50.38 inc. VAT
- You must then take it for a drive of at least 3 miles to allow the GPS system to calibrate itself (staying static will not work).
- If there are still insufficient satellites, then the next test is to connect a third party GPS antenna into the back of the head unit in place of the GPS antenna. Then take it for another 3 mile drive and see if that resolves the satellites not visible. This test rules out the aerial or base unit!
- If it is still not showing satellites after this test, then the unit will likely need replacing as the tuner is probably fried.
Dazzaneal
Thank you just to clarify should there be only one wire from the antenna base on my car?
- x 6948
The MyWay unit has 3 Fakra type connectors from the rear of the unit:
Blue: GPS
Grey: FM2
White: FM1
These are routed through a large cable bundle to the rear of the car. From there they go into an adapter (item 10) on the diagram. The FM aerials are split out from here as on the Tourer (estate), the FM aerials are integrated into the rear quarter panel windows. The GPS cable is the one that goes to the roof mounted aerial.
It might be worth you ahving a read here of another member that had the same issue - he ended up needing a new Head Unit as I suggested to you if the other tests fail. It also conmtains a link in the post to one of those cheaper GPS modules you can use to test it.
So yes, there is one GPS cable to the roof antenna.
Blue: GPS
Grey: FM2
White: FM1
Dazzaneal
Thank you I am getting 2 satellites after factory reset so would suggest that the antenna is at fault
I’ll buy the one you’ve linked to test at first and if that fixes the problem I’ll go for a new roof antenna thank you for your help
- x 6948
Also one important thing I forgot to mention!
You may not be aware of the GPS Week Number Rollover issue that affects the MyWay and some other systems. This occurred on April 6 to April 7, 2019, when the satellites reset to zero. This happens every 20 years and can affect GPS systems in different ways.
The only way to fix this, is to go into the settings for date and time, and unselect the ‘Synchronise time with GPS’ option. This can resolve the incorrect positioning information as a result of the April 2019 change. Check the time, date and year and correct manually, but ensure the ‘Synchronise time with GPS’ setting is not checked.
Give it some time to recalibrate by driving for some time and see if that sorts your issue.
Dazzaneal
I have purchased a unit that connects to the gt5 connector in the roof lining save fetching head unit out if that fixes the problem I’ll order a new antenna from Citroen next week
Thanks very much for your help
