Citroen C5 -05 DMF to "SMF"?
- My Cars: Citroen C5 -05
Peugeot 407 -08 aka Flapeater - x 1
Re: Citroen C5 -05 DMF to "SMF"?
So, the flywheel fitted to this car 4 years ago is named 0532-XF. The clutch is named X 951 835.
Theese are incorrect OEN on my car according to moderator GiveMeABreak. The correct flywheel would be 0532-T0.
Anyone here who know how this would affect the car, fitting a 0532-X7 instead of 0532-T0, like they have done? In the specs I can read that the one fitted has only 7 "teeth"(?) and OEN has 9.
GiveMeABreak wrote: ↑17 Apr 2019, 22:28 None of those are correct. Never use your registration, only 60% reliable at best. Always get the ODM part number and use that to ensure you get the correct parts.
The Flywheel is actually 277 as you can see under part number 11.
The first part numbers are the OEM ones and where there is another > 3 yrs that means an equivalent part for older cars that is generally cheaper. Parts with ‘RP’ in front of them are the later replacement part numbers that have superseded the original part number.
Click images to Zoom:
358BD123-E879-4DED-8A96-59D452D4BBE1.jpeg 2EEBC52F-A774-4653-A48F-05D68F1DB9E8.jpeg
Hello again. Been in contact with Citroen. If you check further on, the LE-2012 means that they have replaced the 0532-T0 with the 0532-X7. That means that the 277mm flywheel has changed.
- white exec
From your VIN, your RPO number is 10581.
Use that to select the correct clutch kit from the several listed by Citroen for the car.
Your 50xxxx numbers should read 05xxxx; just a slip.
white exec wrote: ↑18 Apr 2019, 13:12 From your VIN, your RPO number is 10581.
Thanks. But I'm not seeing that number anywhere on the sites I'm ordering from. Just OEN.
I'm now choosing between the Sachs or LuK, and whether I should go with the 0532-T0 or 0532-X7. Since I've had bad experience with the later one, I'm leaning to get the 0532-T0. Would have been interesting to know the difference between T0 and X7. They're all 235 or 240 mm.
- white exec
From your VIN:
C5 II 5 DOOR ESTATE 2.0 HDi 138 particle emission filter Manual gearbox 6
RPO no.=10581
For the DMF, replacement is 0532T0*** (shown as available): This is dimensioned at 277mm diam.
And for the Clutch Kit, you have a choice of two as shown (and both available): ________________
*** Alternative to this part is listed 0532X7 + 2052P3 : 2052P3, though, shows up as a Clutch Kit, fitted to several vehicles, eg As 0532T0 is shown as available, this looks to be the one to go for, otherwise be guided by your Citroen parts counter.
Cannot vouch for alternative makes or aftermarket units, especially in this case where more than one unit seems to have been fitted over time.
Apologies for any overlap with Marc's information. It's had two of us doing some delving.
Edited to correct 5032X7 to 0532X7
RPO no.=10581
Thank you very much. As said the 0532-X7 is the new replacement for 0532-T0. Somewhere there is a typo, becuse also you wrote 5032X7 now, like I did earlier, and found nothing. But with 0532X7 I find flywheels on various auto-part sites.white exec wrote: ↑18 Apr 2019, 16:27 From your VIN:
RPO no.=10581
________________
*** Alternative to this part is listed 5032X7 + 2052P3 :
I can find no listing for any vehicle for that first number.
but it might need to be twinned with 5032X7 (whatever that is).
Will go with the 0532-T0 RepSet that includes clutch-kit and bolts and everything... Thank you everyone for your help with this.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
I've been away fixing our C3 - but yes replacement part is 0532X7 and that is
£229.49 for a LUK equivalent (without screw set) and £432.01 from Citroen, plus £100 refundable deposit. So the equivalent over where you are.
- white exec
Sorry, my turn for the typo! Have put it right in the post, in case anyone else trips over it.
GiveMeABreak wrote: ↑18 Apr 2019, 17:14 I've been away fixing our C3 - but yes replacement part is 0532X7 and that is
Yeah, I will go with the 0532-T0, not X7, since the first flywheel/clutch (that was T0 when the car was new) lasted 160 000 km. And the replacement 0532-X7 now lasted only 60k km.
I can't tell you for sure that the reason to the faster fail of clutch/flywheel is because of the replacement part. But I can tell you I am not installing a 0532-X7 again
So this story is continuing. The LuK RepSet requires some special LuK tool that I don't think my friend mechanic has. It states in the article info that special LuK tool is required. Price of tool is 500 €. I think it has something to do with the RepSet beeing self-adjusting.
So, been looking at Mapco Set. Can you see from the picture that this is a dual mass flywheel?
https://www.mapco-automotive.co.uk/carp ... lutch-kit/
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
It's because the LUK clutch has an automatic wear adjustment device that requires a special tool for refitting.
(8) Automatic play adjustment mechanism.
(9) Compensation springs.
Your engine code is RHR - so make sure it is compatible if getting something else.
Yeah, I know. Just trying to find out if they're all self adjusting, but only the LuK one states special tool required. I know my mechanic has fitted self adjusting clutches before but is there something special with LuK that requires their own 500 euro LuK-tool? Wouldn't surprise me.
Very little info on the Mapco set, no OEN numbers and no info whether it has dual-mass flywheel or if it is a conversion kit. Nearly half the kits sold to this car are conversions to SMF...
Reason: No need to quote the previous post :)
- white exec
If sold as a multi-part kit that includes flywheel, then likely an SMF conversion kit.
Also has a conventionally sprung friction plate, which is standard for SMF; DMF plates usually unsprung, as the springing (lots of it!) is in the flywheel.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, we can't really comment on third party vendors - that has to be your decision - you have the Citroen part numbers, so just need to search on those.
Genuine DMF:
https://www.ebay.co.uk/itm/NEW-GENUINE- ... 4051399237
Valeo Clutch:
https://www.ebay.co.uk/itm/Clutch-Kit-3 ... ctupt=true
Genuine DMF:
Valeo Clutch:
white exec wrote: ↑22 Apr 2019, 06:24 If sold as a multi-part kit that includes flywheel, then likely an SMF conversion kit.
There are plenty kits including flywheel and clutch that is with a inlcuded DMF, not just SMF. Like 50/50 of both types of kits...
Yeah I'm forgetting the Mapco one I think. Sachs or LuK it will be. Just going to check with the mechanic that he has the proper stuff to install a self adjusting clutch, since both of them are self-adjusting.
