C4 Picasso outside temperature sensor
Tourer-1950
Unread post by Tourer-1950 »
The outside temperature sensor on my 2010 stopped working I have bought a replacement unit and a new drivers side mirror glass in case of disaster when removing old glass.
Having removed the glass and the coloured mirror back plate still can not see how to remove/replace the sensor !
Cant even see the unit apart from the "nipple" protruding from mirror underside.
Has anyone ever replaced this item on a C4 Picasso ?
Many thanks for any suggestions.
x 2943
Re: C4 Picasso outside temperature sensor
I can't say about the Picasso but the C5 one is just pushed into a plastic slot, if you have the back cover off pushing the 'pimple' up will release it then it's a matter of cutting the wires and re-soldering them into the existing wires, the original wiring is clipped in and routed too much to get out easily.
There's a picture of my broken one in another thread '807 outside temp sensor'
x 6955
Tourer-1950 wrote: 21 Jan 2019, 20:45 The outside temperature sensor on my 2010 stopped working I have bought a replacement unit and a new drivers side mirror glass in case of disaster when removing old glass.
Ok, so I'll need your VIN as this is a different setup entirely on a C4 Picasso from a C5.
The Sensor is in the Driver side Mirror (Right Hand Side), however, subject to VIN confirmation of the exact model, the sensor has to be cut at a specific location and re-joined as it is part of the complete electrical harness that powers the other operations of the mirror - again depending on trim level and options.
Once I have your VIN I'll be able to get you a disassembly guide up.
Tourer-1950
Thank you very much for your replies.
I have been a bit busy lately arranging transport, buying a suit etc. for my daughters upcoming wedding !
Please see VIN number as requested VF7**************[VIN obfuscated, can be read by forum staff].
Many thanks
x 6955
The external temperature sensor is a lot more involved as I thought. The mirror has to be removed, which involves taking the door card off and all the switches to get to the mirror mountings.
The temperature sensor is part of a wiring harness - no separate plug I'm afraid, so the new one has to be spliced to the harness when fitting.
I thought I'd advise you first, but if you still want to attempt it, let me know as It is a fair bit to post up.
Tourer-1950
Thanks for your reply.
Not a problem removing door card armed with some replacement trim fixing ! done that job before to replace central locking actuator.
But what`s puzzling me even if I remove the mirror completely how do you remove the sensor as mentioned in my original post with the glass and coloured back cover removed can not see this unit ! And splicing the wires is not a problem with solder joint butt connectors.
x 6955
Ok, there does seem to be some confusion as to the location of the damned sensor on this model - as parts list this as available on both right and left hand mirrors - which I have to assume is dependent upon whether you have a right or left hand drive vehicle. In the technical notes it refers to the sensor as being on the passenger side. As these are typically written from the European side - they generally work with LHD vehicles. That would indicate it being on the passenger side for a left hand drive.
So it is entirely possible it is on the left hand side for a right hand drive vehicle.... Double check the passenger side for a dimple.
But this is what it should look like as you will know as you have the replacement already:
Now it must be on one of them as the nipple can always be seen from the underside - it's no good if the sensor doesn't protrude out of the casing or it won't be able to do its job.
Tourer-1950
Yes that's what the replacement part looks like and I can confirm the "nipple" protrudes from below the offside driver's mirror.
Many thanks for your response.
x 6955
Ok, so I'll put the guide up for you shortly as that may help you :-D
x 6955
Here's the guide - which contains some extracts from the door disassembly to get the mirror off - I believe I've excluded any non-relevant operations from that - but if you get stuck let me know.
Electric Window Switch Assembly
  • Unclip the window switch assembly (1) (at "a"); Using trim removal tools.
  • Disengage the window switch assembly (1).
  • Disconnect the connectors "b" (according to equipment).
  • Remove the window switch assembly (1).
Door Trim Pad
  • Unclip the interior control handle trim (2) at "c".
  • Remove the interior control handle trim (2).
  • Remove the bolts (3)
  • Remove the screws (4) and (5).
  • Unclip the door trim pad (6) (at "d").
  • Remove the door trim pad (6).
Exterior Mirror
Remove:
  • The bolts (20)
  • The window front guide (21)
  • Release the harness (22) of the exterior mirror (at "j").
  • Disconnect the connectors (at "k").
  • Detach the outer base cover (23) of the exterior mirror (at "l").
  • Disconnect the connector of the side repeater (24).
  • Remove the assembly of exterior mirror outer base cover (23) and side repeater (24).
Remove:
  • The bolts (25)
  • The exterior mirror (26)
  • Detach the side repeater (1) from the base cover (2) (at "a").
  • Remove the side repeater (1).
  • Detach the shell (3) (at "b").
  • Remove the shell (3).
  • Detach the base interior cover (4) (at "c").
  • Remove the base interior cover (4).
  • Detach the rear exterior shell (5) (at "d").
  • Remove the rear exterior shell (5).
  • Disengage the sensor from the exterior rear view mirror on the passenger side.
  • Tilt the glass of the rear view mirror as low down as possible.
  • Pass your hand behind the exterior rear view mirror glass (6) and detach the fixing lugs "e" from the exterior rear view mirror glass.
  • Disengage the glass from the exterior rear view mirror (6).
  • Disconnect the electrical connections "f" (according to equipment).
  • Remove the exterior rear view mirror glass "f".
  • Detach the front exterior shell (7) (at "g").
  • Remove the front exterior shell (7).
  • Disengage and remove the base seal (8).
  • Remove the bolts (9).
  • Disengage the motor of the exterior rear view mirror glass (10).
  • Disconnect the connector "h", releasing the tabs "j" holding the motor of the exterior mirror glass (10); Using a small screwdriver (according to equipment).
  • Remove the motor of the exterior rear view mirror glass (10).
  • Disengage the harness (11) from the exterior mirror frame.
    N.B.: The outside temperature sensor is located inside the exterior rear view mirror ( right hand side).
  • Cut the black wires of the outside temperature sensor (12) (at "k") (according to equipment).
  • Remove the external temperature sensor (12) (according to equipment).
Re-assembling
  • Restore the electrical connection of the external temperature sensor using soldered sleeves (type RAYCHEM) then insulate with heat-shrink sleeves (according to equipment).
  • Carry out the re-trim operations in the reverse order to the stripping operations.
  • Check the electrical operation of the exterior rear view mirror (according to equipment).
Tourer-1950
Thank you very much for the very impressive illustrated strip down guide much appreciated.
When we have a break in the snow and the temperature goes up a bit I will tackle the job and keep you informed.
Tourer-1950
I finally had some spare time yesterday so got around to dismantling the o/s mirror to replace the sensor.
Following the illustrated guide you supplied the rear exterior shell (item 5) was removed carefully and bingo ! the sensor was there to remove.
Fitted replacement unit using solder type butt connectors which are already heat shrink wrapped there is plenty of room in the mirror shell I just shortened the new cable by a couple of centimetres.
But sad to report still no temperature readings.
The whole job including putting away tools, extension lead ,hot air gun etc. only took about 45 minutes because I only had to remove the rear shell of the mirror not the glass or motor etc.
Once again many thanks and I will update you when the job is tackled again.
x 6955
After all that, what a let down! Was it a genuine sensor or a copy do you know - copies of these, just like parking sensors are very hit and miss and often DOA. If not that, I would re-check wiring connections too.
Tourer-1950
Sorry not been in touch I did remove the sensor again but the wiring snapped somewhere down inside the door and after removing the door card again gave up because of shortage of time I couldn't see how to get at the multi pin plug that needs disconnecting. As stated a while ago my daughter got married on 20th April all went well apart from my father in law passing away on Tuesday 16th April ! Will contact you when I get some time.
ViV
New User
Unread post by ViV »
I would be grateful if you can post me the above direction of how to install the sensor . Is there a specific sensor for the year of the car , or acn one purchase a sensor for this model from ebay
