dpf temperature
dpf temperature
Hi, does anyone can read dpf temperature value for dw10bted4 engine with delphi dcm3.4 ecu euro5 an a cold engine. My is always 98 degrees.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: dpf temperature
Not sure I understand the reason behind this? The exhaust gas temperature will be lower until the engine has warmed up, and that will be different for everyone depending on outside temperature, so not quite sure what you are expecting.
Re: dpf temperature
I'm expecting outer temperature, +/- 5°C. I have on outside temperature of -15°C overnight readings from sensor 98°C.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: dpf temperature
I'm really sorry - it's probably just me, but I really don't understand what you are asking. If you could provide a bit more information / background and be a little more specific, that might help us understand a bit better.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1378
Re: dpf temperature
I think he's saying that even when the engine is cold (i.e. just started up) it's showing 98°C.
Re: dpf temperature
Exactly, on cold engine I have readings of 98°C from sensor.
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
Re: dpf temperature
There's no need to read a cold exhaust temperature so the lower limit probably starts at just under 100, hence the 98 when cold.
Re: dpf temperature
Mine (different engine/ecu) shows <100c from cold.
Re: dpf temperature
Thanks MikeT, i have small wiring damage on sensor that's why I'v asked.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
Re: dpf temperature
On my engine, it reads 98 degrees C until the temperature rises above that. So after a drive to warm everything it reads correctly but from cold it reads 98.
It is not a fault.
It is not a fault.
Re: dpf temperature
