XUD 9 oil leak
boxerbean
x 8
XUD 9 oil leak
Unread post by boxerbean »
She's a squirter!
Weeping oil in the area behind the fuel pump, cleaned it off for a better look, here's the pic I took after a couple of minutes idling.
Any suggestions of possible cause/remedy appreciated.
Thanks.
x 8311
Re: XUD 9 oil leak
There is an oil gallery right by there so it could be a failure of the head gasket causing it... It's not common but I have seen it once before...
Just before you condemn the gasket though, slip off the cambelt covers and check the camshaft oil seal is good and the oil is not coming from these and creeping down and exiting where you see it...
x 1751
Re: XUD 9 oil leak
IIRC, there's an O-ring sitting in the head gasket, right in that corner. It's the high-pressure oilway that takes oil to the camshaft and valvegear. As the HG ages, the O-ring can bake hard and go leaky.
Overheating of the cylinder head doesn't help, which is why coolant level and thorough bleeding are important, to eliminate air pockets (=hotspots) in the head.
If removing the head, get it checked for flatness before refitting.
boxerbean
x 8
Re: XUD 9 oil leak
Urgh, I have a feeling the guys who fitted the engine overheated it - would explain my leaking heater matrix. Better have another cuppa before I go and have a look under the cam cover.
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: XUD 9 oil leak
the structure of the vehicle itself to the left of the second (Overview) pic looks somewhat less than pretty. Just a mention to make sure the van's structurally sound before potentially chucking loads of money at it.
Puxa
x 1484
Re: XUD 9 oil leak
Head gasket, almost certainly 😣
Leak from there was the end of my first Xantia TD.
boxerbean
x 8
Re: XUD 9 oil leak
Just removed the cambelt cover, camshaft oil seal is fine. looks like the head gasket. :(
Keen amateur, thanks for pointing that out, it's the van in my profile pic, I've been working my way around the numerous faults and on a bit of a learning curve to say the least - even old campers go for daft money so I'm sorta stuck with it.
If anyone lives near Brampton and likes swearing you're welcome to come and fix the head for me!
x 8311
Re: XUD 9 oil leak
boxerbean wrote: 28 Apr 2018, 10:49If anyone lives near Brampton and likes swearing you're welcome to come and fix the head for me!
Swearing definitely improves the outcome of the job ;)
x 1484
Re: XUD 9 oil leak
It's not such a bad job... hardest bit is that access to the inlet manifold bolts is nigh on impossible (or at least it is on an engine set up for overhead intercooler) - and this means removing the head complete with the turbo - which is very heavy. I did it on my own on a BX TD, but I would either use 2 people or preferably a hoist of some sort if I was doing it again. If you're not in any rush 2 or 3 evenings to lift the head, a light skim, 2 or 3 evenings to put it back together.
boxerbean
x 8
Re: XUD 9 oil leak
I'm going to have a go at it, thought there might be a thread on here of someone doing one so I could just join the dots.
x 8311
Re: XUD 9 oil leak
There is and plenty of experience of the job on here... Just go ahead and ask any questions you like ;)
boxerbean
x 8
Re: XUD 9 oil leak
Ok, how do I remove the exhaust manifold studs?
MikeT
x 232
Re: XUD 9 oil leak
Unread post by MikeT »
Locknut two nuts on the end of the studs and undo with spanner
ekjdm14
x 257
Re: XUD 9 oil leak
Unread post by ekjdm14 »
Just a note that you'd be well advised to use new head bolts on reassembly, not essential according to the BoL but with White's engine I got a set of Elring ones for £20 and it seemed rude not to at that price... Also used an Elring steel head gasket that was £14 since it's a known good brand & does away with any silicone/Viton O-rings too. (make sure to either fit a gasket with the same number of notches as original, or better still measure piston protrusion to ascertain the thickness needed).
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
boxerbean
x 8
Re: XUD 9 oil leak
Thanks for the advice everyone.
Struggling to remove this, thermostat housing?
Removed 2 6mm Allen bolts it rocks but won't pull out, is it a case of pull harder or am I missing something?
