Rneg Myway to Navidrive
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
goggi10
Unread post by goggi10 »
Hi,
I have rneg system on my c5 can i update it to Navidrive (rt5) becausw i havw found one cheep. Will it be a problem to switch from rneg Myway to navidrive.
Thx
EDC5
x 130
Re: Rneg Myway to Navidrive
Unread post by EDC5 »
I have done this myself and it is a straight swap.
There are several options that need changing in the BSI however as the RT5 also has telematic abilities. Without doing this I had some erratic behaviour from the unit.
You will also need to fit a GSM antenna if you intend to use that feature of the RT5.
goggi10
is it better then rneg Myway and i dont plan to use GSM i will use Bluetooth for phone calls. My question is can i use disply from rneg or i need a special disply for navidrive.
THX
goggi10
and can u tell me what needs to be changed to BSI because here in Serbia anybody who can do me this properly
EDC5
x 130
Yes, the screens are the same for both the Rneg and the navidrive.
I can't remember off the top of my head what I had to change but they are pretty obvious if you go through all of the options in the BSI. Remember to record your initial settings before changing anything in the BSI.
goggi10
Thnks m8 bur now am confused seller sent me this and i dont know is it rt4 or rt5
EDC5
x 130
RT3ev is infact a RT4, so no bluetooth I'm afraid :oops:
goggi10
damm it was just 100 eur :(
EDC5
x 130
That is still very cheap for a RT4, I paid £280 but it did include the screen and wiring loom that I needed at the time.
x 6958
The Difference is that the RT5 can use the high Res screen and has bluetooth. If it's RT4 it will have software version 7.x and RT5 will have software version 8.x. Also, check out the rear of the unit for the other way to identify it.
RT4RT5
EDC5
x 130
Interesting, does the rearrangement of the FM connectors mean that the RT5 has a different FM tuner subsystem? If this is the case I'd like to hear it as I feel the FM side of things lets the RT4 down and isn't a patch on the Harman sourced Rneg in my view.
x 6958
Hard to say Elis without ripping the 2 apart and looking at the guts - but they no doubt had to rearrange some things to fit the Bluetooth module in and the different graphics chip maybe.
FM is a tricky one - sometimes around Cardigan Bay my FM is like listening to LW out at sea, (either that or the Russians are jamming me)! Other times further inland it is crystal clear.
EDC5
x 130
GiveMeABreak wrote: 01 Apr 2018, 18:34 Hard to say Elis without ripping the 2 apart and looking at the guts - but they no doubt had to rearrange some things to fit the Bluetooth module in and the different graphics chip maybe.
Haha, if I were you I'd avoid sushi and people with pointy umbrellas :lol:
My old rneg could change fm channel instantly unlike any other radio I have ever used. I just wish there was a way to play music from SD card as I would have kept it.
