Original reversing camera for RT6 - Citroen C5 X7 2015
vborovic
- Locked user account
- x 40
Re: Original reversing camera for RT6 - Citroen C5 X7 2015
That's the route I took ... a quite expensive one, those interfaces are roughly 250 €
alx6ths
yeah, iam aware of this video interfaces, but that is the last option if the original camera project fails
I like this one: http://www.carvision.nl/index.php?item= ... 16&lang=EN
Although iam not sure with compatibility with my RT6 in this case. But their camera with adjustable parking lines is briliant
Libor
vborovic
- x 40
It is compatible with the RT6, because the RT4 & RT5 (which are listed as compatible) use the same architecture
alx6ths
Could you share the one you are using and have the experience with? You also have the RT6 right?vborovic wrote:That's the route I took ... a quite expensive one, those interfaces are roughly 250 €
I still hope that I will succeed with original camera, but I already have doubts
Libor
vborovic
- x 40
I got mine from car-solutions.com, you can find it easily by selecting the brand and model on the left side ... and I have the genuine camera ... the picture quality is acceptable, although I get interference (horizontal lines), that worsen with water/mist (especially on rainy days ... something to do with earthing, never managed to improve it)
OnlineHell Razor5543
- x 3298
I wonder what would happen if you used a couple of ferrite cylinders (one at each end) on the cable for the camera? It might help cut down the interference.
Something like this;
http://wonderfulengineering.com/ever-wo ... ry-solved/
http://www.ebay.co.uk/itm/Wholesale-UK- ... SwnNBXYoqM
vborovic
- x 40
Believe me, I've tried almost every know electrical trick in the book (including the magnets), nothing helped ... I've even tried with ground loop isolators, RCA video amplifiers and whatnot (both passive and active) ... the end result was no image displayed ... the only thing I haven't tried is with a higher quality video cable, but since the original camera wires from the connector aren't of higher quality, this wouldn't help one bit ... how they managed to solve the problem with the original wiring, I don't know
alx6ths
Re: Original reversing camera for RT6 - Citroen C5 X7 RT6
Hi, a little update. I have flashed the latest firmware 2.86 B1 with no changes in this matter.GiveMeABreak wrote: I would certainly get your firmware updated first though - always a good idea.
My doubts getting deeper
Libor
- x 6948
As Vab says - it seems there were a few hardware revision to this unit and you obviously must have one of the earlier ones then. Never mind, at least you got the firmware update completed which is a plus.alx6ths wrote:Hi, a little update. I have flashed the latest firmware 2.86 B1 with no changes in this matter.GiveMeABreak wrote: I would certainly get your firmware updated first though - always a good idea.
vborovic
- x 40
The newer RT6 firmware only has impact on the hybrid vehicles I believe, for the additional battery charging/state page, along with some stability issues cured, which in case you didn't have them in the first place, goes unnoticed
nigelrobson
Hi, jumping in a bit later to this thread.
Just bought a C5 estate MkII (2010 ) and have no parking sensors or camera. Finding it hard and have had a few near misses!!
Found this camera system and although expensive looks like it may work, just not sure if I can justify it....
http://www.carcommunications.co.uk/car- ... rse-camera
.... any comments ? I am still a bit confused about RT numbers but think I have RT4. no wiring as far as I can see and the aux inputs in the glove compartment are only audio with no "yellow" AV RCA socket.
Also I wondered if the estate is different for the wiring loom because of the larger hanging down rear door?
Thanks for any hints in advance
Nigel
Nigel
- x 6948
Personally, I wouldn't touch that with the proverbial barge pole! You can buy complete wireless kits for 10% of the silly prices that site is asking. Here's just one example - and at least you see exactly what you are getting in the kit and with instructions - the other site doesn't provide anything.
http://www.ebay.co.uk/itm/WIRELESS-CAR- ... SwwbdWLfpr
You will still need to take a feed from both ends. It is highly unlikely (as per this and other similar threads) that you will be able to just plug the other kit in and expect it to work. Here's a non- wireless one that another member did:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=52248 but prices have come down again since he did this with more options to choose in the marketplace.
Something like this might be an alternative and easier solution.
Regarding the Estate or Tourer version - a bit confusing as you've already said that you have bought the estate, so not sure what you are referring to as a comparison. There may well be a difference in the looms between models as there will be parking sensors, electric tailgate close and lift / camera, tpms aerial etc. that might not be in place. But with regards to a reversing camera - that's another reason why you might consider the monitor over the interior rear view mirror option - as some actually replace the mirror like Ace's setup in the linked post.
nigelrobson
Very good Marc, can't tell you how helpful this is. I see also that going for a mirror video does away with the necessity of rear bleeping sensors too. And you are right , the price difference is amazing.
As for the estate question (was thinking more difference of saloon or estate) I see now elsewhere that the wiring for the camera doesn't need to go to the tailgate but the camera can be bumper mounted and wiring connected to the reverse cabling in the inside the car not needing wires into the tailgate.
The only thing that bothers me about the example you mentioned with auto dimming lcd mirror and camera http://www.frenchcarforum.co.uk/forum/v ... =3&t=52248 , is the fixing bracket. Mine, unlike the example, is already an auto dimming mirror and doesn't seem (as far as I can make out) to have the same bracket fixing. However if I clarify that I am quite tempted by that option - seems stylistically similar to the original but of course the wiring might be challenging.
Thanks a lot for your comments. If you can point me to a resource that might show the fixings for my existing auto dimming mirror I'd be delighted.
best wishes
Nigel
best wishes
Nigel
- x 6948
Hi Nigel - the following pics should give you some idea of the fitting. From what you've said, I'm assuming you have the electrochrome mirror. If that's the case, then it will have a shell in 2 halves as per the picture below that need to be carefully prised apart (the plastic lugs are delicate). After that, you can carefully disconnect the wiring plug for the rain and brightness sensor (but whatever you do don't remove the sensor pad from the windscreen, or you may up with air bubbles behind it, reducing functionality & they're £240+ a pop!) The mirror itself is removed by tilting it forwards (direction 'C') in the second picture. You should be able to see the type of fixing now.
Failing that - you could go for one of the clip-over types which attach to the existing mirror and only activate when you engage the reverse gear; when not in use it provides a larger viewing ange as I think it's a 7" monitor type.
wfdTamar
Old thread, but seems one of the most complete on the subject. I have a 2015 C5 with RT6 which when I got it had a third party camera which works, but has a slightly fuzzy image (possibly water in it). I bought what I thought was the same camera off Aliexpress, but it doesn't work (just black screen when in reverse).
Either the camera is the wrong spec, or you need to tell the car you've changed the camera (would seem unlikely).
So does anyone know what the spec of the camera needs to be or maybe the resolution of the RT6 screen?
I got an AHD B camera which has either AHD 720p or CVBS 600p resolution. They have another which is CVBS CCD 800x600 resolution. I'm wondering if that might work. It might also depend on the box that controls it (I've seen some that have dip switches).
2015 C5 Limited Edition (2.2 HDI) 150 kW 450Nm (Racechip S 179kW 528Nm)
