Balancing centreless alloy wheels.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
C'est OK.
Jeux Cocquer wrote:Vous pouvez laisser votre chapeau sur la tête.
Je vais chercher mon manteau, maintenant...
x 8391
Re: Balancing centreless alloy wheels.
handyman wrote:Wot U gonna fit, Jim?
As I said I might, a pair of BFG G-Grips. Finally sent the Fates off to their ultimate fate; they were getting cracked and making the car feel a bit skittish and I no longer trusted them on a run..
I've had the G-Grips on several Xantias over the years and I like them a lot. These are no exception and they have made the car feel much better.
My local mob (also used by Xac) did a fine job of balancing too...
x 1996
Unread post by Stickyfinger »
Agree...mill out the centres.
Or put a few grams of shot gun pellets inside the tyres :)
x 8391
:rofl2:
electronmirror
x 30
Unread post by electronmirror »
Direct injection via the 12 bore or 410 is not recommended........ :lol:
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
x 1996
Mock if you will, but it works :)
x 8391
Stickyfinger wrote:Mock if you will, but it works :)
How? The pellets will be constantly on the move won't they? This is a serious question...
Some cyclists fill their inner tubes with liquid latex to seal punctures automatically in the same manner as blood platelets stop bleeding but many find the latex swishing around really upsets wheel balance...
furriegurrie
x 40
Unread post by furriegurrie »
It has to do with the centrifugal forces. A similar thing happens on a Ds with the grease from the drive shafts on the front wheels. The joints in these driveshafts you need to periodically grease and the excess grease will be pushed out on the inside of the wheel. It helps to remove unbalance....
x 8391
Ahh, thanks for that :) So the weight goes to where it's needed then as a result of centrifugal force...
Makes perfect sense!
x 695
Unread post by Mandrake »
Stickyfinger wrote:Agree...mill out the centres.
I'm assuming that was a reply to the wrong thread since this one had been dead for 4 years ? :-D
x 8391
Old threads never die Simon, they just lie in wait ready to pounce upon you when you least expect it ;)
x 1996
Strange, came up in "New Posts", did not look at the date.
