Je vais chercher mon manteau, maintenant...Jeux Cocquer wrote:Vous pouvez laisser votre chapeau sur la tête.
Balancing centreless alloy wheels.
addo
- Sara Watson's Stalker
- x 95
- x 8397
Re: Balancing centreless alloy wheels.
As I said I might, a pair of BFG G-Grips. Finally sent the Fates off to their ultimate fate; they were getting cracked and making the car feel a bit skittish and I no longer trusted them on a run..handyman wrote:Wot U gonna fit, Jim?
I've had the G-Grips on several Xantias over the years and I like them a lot. These are no exception and they have made the car feel much better.
My local mob (also used by Xac) did a fine job of balancing too...
- x 1996
Agree...mill out the centres.
Or put a few grams of shot gun pellets inside the tyres
- x 8397
electronmirror
- x 30
Direct injection via the 12 bore or 410 is not recommended........
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
- x 1996
Mock if you will, but it works
- x 8397
How? The pellets will be constantly on the move won't they? This is a serious question...Stickyfinger wrote:Mock if you will, but it works
Some cyclists fill their inner tubes with liquid latex to seal punctures automatically in the same manner as blood platelets stop bleeding but many find the latex swishing around really upsets wheel balance...
furriegurrie
- x 40
It has to do with the centrifugal forces. A similar thing happens on a Ds with the grease from the drive shafts on the front wheels. The joints in these driveshafts you need to periodically grease and the excess grease will be pushed out on the inside of the wheel. It helps to remove unbalance....
- x 8397
Ahh, thanks for that
So the weight goes to where it's needed then as a result of centrifugal force...
Makes perfect sense!
- x 695
I'm assuming that was a reply to the wrong thread since this one had been dead for 4 years ?Stickyfinger wrote:Agree...mill out the centres.
- x 8397
Old threads never die Simon, they just lie in wait ready to pounce upon you when you least expect it
- x 1996
Strange, came up in "New Posts", did not look at the date.
