Xantia Airbag Removal
Xantidote
x 5
Re: Xantia Airbag Removal
Unread post by Xantidote »
No, I don't think you should split it in the middle. If it's the same as on my 1995 1.9TD, then I think (memory's going nowadays :( ) that you slide a thinnish screwdriver or similar under the connector and gently lever it off. Suggest you do this gingerly in case I'm wrong.
No doubt someone will be along shortly to confirm one way or the other.
Martin
x 8309
Nope. that's the right method... The airbag has a small socket on it's back face in the shape of a 'D' with two pins. The side face of the orange bit in the picture has the reverse. It'll clip out quite easily with the use of a small screwdriver as a lever.
Disconnect the battery and leave disconnected for at least 10 minutes before doing it though...
x 5654
All these blasted clever connectors with each their own method of dismantling is nothing but a nightmare. So easy to break them if you don't know the trick of releasing the catch and it is always the most crucial ones that disintegrate when the incorrect technique is applied. :evil: :evil: :evil: :evil:
x 8309
myglaren wrote: So easy to break them if you don't know the trick of releasing the catch and it is always the most crucial ones that disintegrate when the incorrect technique is applied. :evil: :evil: :evil: :evil:
That's so true Steve :twisted:
danny13
Unread post by danny13 »
Cheers guys, I succeeded in removing the bugger, it was plugged into two pins on the back of the airbag plate. Next job is trying to source a replacement part, found an exact match here http://bartebben.com/parts/citroen/xant ... 30480.html weirdly couldn't find it on valeo's website.
None on ebay, so time to start calling round breakers, I hope a new one fixes my airbag light otherwise I think I'll be send my xantia to the scrap yard!
x 3300
Check with citroenxm, as he is likely to have one. He also charges realistic prices.
danny13
Cheers Hell Razor, I'll drop him a PM
lexi
x 134
Unread post by lexi »
Steve; there is a freaky lil girl on your Avatar. I can feel my fillings getting sore with her treacly warblings :lol:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 5654
I wouldn't describe her as 'freaky'
More 'phenomenal' :)
Incidentally, RIP Lou Reed :(
lexi
x 134
They are all going Steve. Playing "Berlin" on the old Lenco tonight :cry:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 5654
Snap!
falling-out-with-my-car
x 25
danny,
if you can't fix it check your messages,
x 1987
Unread post by Stickyfinger »
danny13 wrote: None on ebay, so time to start calling round breakers, I hope a new one fixes my airbag light otherwise I think I'll be send my xantia to the scrap yard!
Or you could put in a resistor until you find the correct part....it would save scrapping it. http://www.ebay.co.uk/bhp/airbag-resistor
danny13
Some great advice, thanks gents. Fitted the new switch, but in the process bust one of the damn plugs that connects to the rear of the airbag, The plug was connected onto the pins shown in the arrow:
This is how it was before, assume these are required to have a working airbag circuit?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
They look like the horn wiring pair to me.
