No doubt someone will be along shortly to confirm one way or the other.
Xantia Airbag Removal
Xantidote
- x 5
Re: Xantia Airbag Removal
No, I don't think you should split it in the middle. If it's the same as on my 1995 1.9TD, then I think (memory's going nowadays
) that you slide a thinnish screwdriver or similar under the connector and gently lever it off. Suggest you do this gingerly in case I'm wrong.
Martin
1995 Xantia TDLX (deceased
- x 8309
Nope. that's the right method... The airbag has a small socket on it's back face in the shape of a 'D' with two pins. The side face of the orange bit in the picture has the reverse. It'll clip out quite easily with the use of a small screwdriver as a lever.
Disconnect the battery and leave disconnected for at least 10 minutes before doing it though...
- x 5652
All these blasted clever connectors with each their own method of dismantling is nothing but a nightmare. So easy to break them if you don't know the trick of releasing the catch and it is always the most crucial ones that disintegrate when the incorrect technique is applied.
- x 8309
That's so true Stevemyglaren wrote: So easy to break them if you don't know the trick of releasing the catch and it is always the most crucial ones that disintegrate when the incorrect technique is applied.![]()
danny13
Cheers guys, I succeeded in removing the bugger, it was plugged into two pins on the back of the airbag plate. Next job is trying to source a replacement part, found an exact match here http://bartebben.com/parts/citroen/xant ... 30480.html weirdly couldn't find it on valeo's website.
None on ebay, so time to start calling round breakers, I hope a new one fixes my airbag light otherwise I think I'll be send my xantia to the scrap yard!
- x 3300
Check with citroenxm, as he is likely to have one. He also charges realistic prices.
danny13
Cheers Hell Razor, I'll drop him a PM
lexi
- x 134
Steve; there is a freaky lil girl on your Avatar. I can feel my fillings getting sore with her treacly warblings
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 5652
I wouldn't describe her as 'freaky'
More 'phenomenal'
Incidentally, RIP Lou Reed
More 'phenomenal'
lexi
- x 134
They are all going Steve. Playing "Berlin" on the old Lenco tonight
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 5652
falling-out-with-my-car
- x 25
danny,
if you can't fix it check your messages,
- x 1987
Or you could put in a resistor until you find the correct part....it would save scrapping it. http://www.ebay.co.uk/bhp/airbag-resistordanny13 wrote: None on ebay, so time to start calling round breakers, I hope a new one fixes my airbag light otherwise I think I'll be send my xantia to the scrap yard!
danny13
Some great advice, thanks gents. Fitted the new switch, but in the process bust one of the damn plugs that connects to the rear of the airbag, The plug was connected onto the pins shown in the arrow:
This is how it was before, assume these are required to have a working airbag circuit?
addo
- Sara Watson's Stalker
- x 95
