TIA
Location of DLC/OBD port
Woodford
Greetings all ,
after 40 years as a mechanic I have come up against something that has completely stumped me. I cannot locate the obd port on a 2017 Citroen Berlingo 1.4 manual diesel. Steering wheel on the right- we drive on the left in Australia. It is not in the glovebox. I have removed the glovebox and inspected all the wiring. The glovebox has the cutout for the obd port but there is nothing there. No screw marks etc so that tells me that it has never been used . I have removed most of the plastic panelling across the front of the car and there is no sign of wiring or an obd port. I have looked around the centre console as I know a couple of cars here have their obd ports there. I cannot find it. I have taken it to an auto electrician friend of mine and he cannot find it. Now 2 questions. Does anyone have any suggestions as to where it might be? Where could Citroen have hidden it
And the 2nd question is could it be possible that the van was manufactured without an obd port. I have never heard of that but I guess it’s possible. Anyway if you have any ideas I would really appreciate them.
TIA
TIA
- x 1942
Re: Location of DLC/OBD port
This is a RHD Berlingo in the video. Is yours not where he points it out?
- x 1487
Plenty of vids on you tube, suggests RH side of steering wheel behind a panel.
Woodford
Thanx guys - It’s definitely not where any of the YouTube videos or even the workshop manual suggest
I have removed most of the plastic paneling from the dashboard on both sides and no sign of an obd port.
Has anyone ever experienced the obd port on a Berlingo being in a very unusual position. I have the obd port cutout in the glovebox plastic ( where it should be for this model). But nothing has ever been installed there.
Do you think it possible that a vehicle was manufactured without an obd port
PaulC5
- x 681
Is it where shown on this video, below the right side of the steering wheel ?
- x 1056
On a mk3 (RHD) Berlingo it should be here.
If its not there it may have been removed form the original fitting for a few reasons.
Some people remove & hide or relocate it for security reasons to prevent theft by programming a key.
Did the van previously belong to a fleet company?
Some fleet companies use the OBD port for connecting trackers & telematics systems etc. sometimes they have to relocate the OBD port for this.
There is no chance it was manufactured without one. You say you have had the glove box completely out & had a good look? There isnt a lot of slack on the wiring so it wont be very far.
There’s no sign of any cut wires?
