One reader of one of my recent columns in the Citroenian magazine spotted these wheel jacks/dollies in use on a project AX...
Her's keen to acquire some of them. I must admit they do look very useful and practical.
All his (and my) Internet searches have drawn a blank as to any further details.
Can anyone help find a potential source of them?
Thanks!
Elevating Wheel Jacks/Dollies...
- x 8386
- x 3565
Re: Elevating Wheel Jacks/Dollies...
CJ Autos do them...
https://cjautosheywood.co.uk/product/hy ... ty-cr012d/
Might also be worth looking at their car lifters for a cheaper alternative.
https://cjautosheywood.co.uk/product-ca ... car-lifts/
- x 8386
bobins wrote: 27 Jun 2026, 08:01 CJ Autos do them...
Thanks Bobins that's awesome and much appreciated
- x 2341
There's also this type of thing:
https://ebay.io/m/N1Ahfa
Ramp with integral bottle jack (and telescopic 'pinned' supports) section.
Have been discussed on the forum previously (will see if I can find it in a bit) - a video, Project Farm was also posted questioning their integrity (though from the comments there was some uncertainty as to if the pinned supports had been missed)
EDIT - here:
viewtopic.php?p=831871#p831871
Including the video
EDIT - here:
Including the video
- x 1996
Ramps = all very good however with "most" cars transverse engined, many many jobs need the wheel removed to work on brakes, suspension, engine components/belts/tensioners/radiator/intercooler-hoses/etc, bumper removal/arch liners. Large (long) ramps also restrict access bloody awkward !
Other than direct down engine work not much happens between the wheels that often.
Ramps, = can be a hindrance rather than a help. Really good quality stands with a wide base, a good head and a good jack is a better investment. Get some sheets of good quality ply and some weight spreader planks if you need to work on gravel.
- x 8119
I fully agree with Alasdair on the jack and stands v ramps debate. The only problem I had was that as I got older I found it harder and harder to pump the trolley jack to get the stands in place. So I came up with this solution:
Now the rattle gun takes care of the actual lifting and I don't get knackered before I start!!
- x 2341
Yep agreed, unless, say dealing with rust in close proximity to jacking (axle stand ) position, or putting front end up for an oil change or under tray re fixing, then ramps are less versatile/less likely to be useful
John Pankhurst
- (Donor 2026)
- x 44
I bought a set of CJ Autos hydraulic ramps many years ago and used them occasionally to lift my Commer campers to inspect and weld underneath. Also used to change the gear box on my Minor traveller. It's a bit scary when they're on full lift but secure once lowered onto the locking bar, not used them for a while as a jack and stands usually does for what I need so they've been gathering dust for a couple of years. I do fancy a decent scissor lift though but pushing £3k for a decent one is a bit much for me. I've also got a small pit in my garage but that is full of Commer engines and other chunks of old iron
A clean pit with a scissor lift placed over it would be just fantastic.
- x 1996
Did they just fall out on their own John ?a small pit in my garage but that is full of Commer engines and other chunks of old iron
John Pankhurst
- (Donor 2026)
- x 44
They sort of sidled over, lifted the boards and made themselves comfortable, must have happened over night. I'm very grateful to them for freeing up some floor space
- x 8386
Stickyfinger wrote: 28 Jun 2026, 23:12Did they just fall out on their own John ?a small pit in my garage but that is full of Commer engines and other chunks of old iron
An interesting discussion. Thanks all
- x 5671
Just seen this on autoshite, may be of use to some of the members here.
Second post.
https://autoshite.com/topic/30877-what- ... nt-3521661
Second post.
- x 8386
Yea, but it's a C1, a child can lift one of those up
Got to be ever so careful undoing hubnuts on those with a rattlegun - so easy to flip the car on its roof...
