Diagbox 9.85
gsc1ugs
- x 3
Diagbox 9.85
Does diagbox 9.85 run on windows 10 64bit?
- x 8089
Re: Diagbox 9.85
gsc1ugs
- x 3
Re: Diagbox 9.85
It does seem like they get anywhere and this was 2023
gsc1ugs
- x 3
Re: Diagbox 9.85
Ive tried two laptops, both on win 10 both cannot see the VCI adapter Actia
gsc1ugs
- x 3
Re: Diagbox 9.85
Ive paused at this stage and then i found this thread
https://www.peugeotforums.com/threads/d ... de.360282/
Do i need to is the question??
gsc1ugs
- x 3
Re: Diagbox 9.85
Ive done the above and drivers dont load for VCI
Mihael_M
- x 37
Re: Diagbox 9.85
I have 9.85 running on Windows 10 Pro 64 bit. What device do you have? They mostly use Actia drivers, but there are some who use other drivers.
gsc1ugs
- x 3
Re: Diagbox 9.85
Software runs VCI wont connect even though device manager says ready to use but digging further says requires further installation see pic drivers came with it actia says installed ready to plug device still nothing
- x 1939
Re: Diagbox 9.85
PP2000 operation requires installation of Diagbox in a 32 bit environment. Could this be a reason even inside a VM?
Trickiedickie
- x 14
Re: Diagbox 9.85
I use Diagbox 9.186 on Windows 10 Pro 64bit. It's a proper install not a VM. Works perfectly.
- x 1939
Re: Diagbox 9.85
It will do on vehicles that require Diagbox. It's only if the vehicle is elderly (think Xantia, Mk1/Mk2 C5, Xsara) and needs PP2000, or in these Citroen examples Lexia, that a 64 bit environment is a problem.Trickiedickie wrote: 13 Jun 2026, 10:28 I use Diagbox 9.186 on Windows 10 Pro 64bit. It's a proper install not a VM. Works perfectly.
gsc1ugs
- x 3
Re: Diagbox 9.85
Ive tried everything, VM setup, standard setup, win 10 64bit, nothing, does the device manager pic tell you anything? If anyone could recommend an eBay user selling them that works would be great
Mihael_M
- x 37
Re: Diagbox 9.85
I asked you which device - cable you use. If you have Lexia 3 Full chip then you need to use ACTIA Drivers which are installed when installing diagbox 9.85. If you look in the drivers manager and connect the Hardware (Lexia 3 cable) you will see the ACTIA drivers included (you have a picture). If you don't have the drivers as in the picture, then either you don't have the Hardware Lexia 3 cable or your installation is not good. If you would show which device you have, I might be able to help further.
gsc1ugs
- x 3
Re: Diagbox 9.85
Thxs for helping, its gone back its a bad board, found a seller on ebay who does full chip guarantees working, because nemo is fiat engine also needs box S1279
https://ebay.io/m/O9JHX2
Think that concludes everything thxs
