2026 (modded?) maps
SterkeYerke
- x 7
2026 (modded?) maps
Hi everyone, I just came across this website:
https://maps.gpsmyway.com/en/map-update ... g-smegiv2/
It claims to have 2026 maps for the RT6 and SMEG units, but sadly I can't download them because you need a premium account on 01files.me. Does anyone know if these maps are legit? And if so, are they available anywhere else? The other map updates on that website seem to be the more well-known modded maps for the RNEG and NG4 units, which afaik have been proven to work.
- x 1940
Re: 2026 (modded?) maps
This was mentioned a week or so ago but no-one's sprung the money to find out. I've searched around and not found anything.
viewtopic.php?p=866262#p866262
SterkeYerke
- x 7
Sadly I don't have a car with a compatible satnav system around anymore to try these. Otherwise I might've tried. However, I haven't given up yet on getting RT6 maps to work on the RT5 in my 607, so I might try them at some point (though I'll probably test the 2023 maps first).
- x 1940
Modified BMW maps are available for RNEG systems. Is that not the same? I will send you a PM about this.
Please let us know how this goes.
SterkeYerke
- x 7
They're completely different. The RNEG was made by Harman Becker (which is why BMW maps work, just like on the NG4) while the RT6 was made by Magneti Marelli. As far as I can tell, they don't share anything except the way they look.
- x 1940
Of course they are. Just having a little senior moment there. Glad you caught my, err, deliberate mistake.
Solarriors
- x 7
So I was summoned. How do the RNEG and NG4 work on SMEG ?
Looking at file types and file structure it's quite different. I don't know how to convert. What pm @Paul ?
Solarriors
- x 7
But do you mean you're able to get the files ?SterkeYerke wrote: 04 May 2026, 23:33 Sadly I don't have a car with a compatible satnav system around anymore to try these. Otherwise I might've tried. However, I haven't given up yet on getting RT6 maps to work on the RT5 in my 607, so I might try them at some point (though I'll probably test the 2023 maps first).
- x 1940
They don't work. As I've repeatedly said, RNEG and NG4 are from a different manufacturer.Solarriors wrote: 07 May 2026, 05:02 So I was summoned. How do the RNEG and NG4 work on SMEG ?
Solarriors
- x 7
I understood they wanted to make it work on RT6/5 and SMEG, my bad
- x 1940
RT6 and RT5 may be from the same company but I believe RT6 is a development of the earlier system.
Those 2026 RT6 maps may well work but no-one has posted about it.
connellyg
- x 3
Afternoon, Evening or Good Morning
if anyone wants to try them feel free
RNEG https://1drv.ms/u/c/20f3f14d28f17890/IQ ... 4?e=WwgxGS
SMEG https://1drv.ms/u/c/20f3f14d28f17890/IQ ... 0?e=w6Il5I
Java Gen https://1drv.ms/u/c/20f3f14d28f17890/IQ ... k?e=zv0kc9
- x 1940
Have you personally used either of the two map update files?
connellyg
- x 3
Yes last night i gave rneg it worked and is 2026-1, put them on last night
pitchou
"Hi, thanks for sharing the RNEG 2026-1 maps. They work perfectly on my WIP Nav, but the POI menu no longer opens and searching for POIs does nothing. Did you experience the same issue, or are your POIs working normally?connellyg wrote: 12 Jun 2026, 09:02 Yes last night i gave rneg it worked and is 2026-1, put them on last night
