Location of engine speed sensor 2.0hdi RHR
baser2010
Unread post by baser2010 »
Hi.... getting an intermittent error with my speed sensor ( and the odd hiccup on the road).
I think it's just a bad connection to the engine speed sensor.....but having difficulty finding the exact location.
Could anyone help out with a photo pointing me in the right direction.
I have cleaned all the plugs I can find in the engine bay but would like to be sure I've done the culprit of my woes!
Thanking in advance...Adam
2004 307sw 2.0 hi 136ho RHR
x 8166
Re: Location of engine speed sensor 2.0hdi RHR
I think item 1 on this diagram should help you out: :)
viewtopic.php?p=618537#p618537
baser2010
Thanks for that......but it's so confusing from that image where it may be.
Thinking it might be up the top near the battery as this video indicates
x 1060
Unread post by wheeler »
It should be right at the crank pulley around the 8 o’clock position
baser2010
OK...cool...thanks.
The guy in the video might be doing the camshaft sensor....or something??
x 1060
baser2010 wrote: 16 Mar 2026, 23:18
No that video above is a crank sensor however that looks like an RHY/RHZ 8v engine where its fitted on the flywheel side.
x 1060
This is where it is located
baser2010
Yep....got under there today and gave the connections a clean.
Ordered a new one...hopefully the drama will be resolved.
Thanks everyone!
baser2010
Update!
Sensor plug clean seems to have done the trick.
800kms of driving since and it has not come back.
I have the new part in the spares kit but I think I'll just run with the existing as it seems fine.
Thanks for the help.
