I can’t get it to turn off when ignition is off drained battery
Also I can’t get cambus to do steering wheel controls
Any help please
Thank you
Fitted a android 15 head unit in my Citroen c4 2007
Dizzylizi83
- x 8149
Re: Fitted a android 15 head unit in my Citroen c4 2007
Which model, body style, engine, gearbox and RPO number from the door pillar tyre pressure sticker is the car? With that info I may be able to find the diagram for the audio unit wiring
Dizzylizi83
C4 exclusive auto 2L petrol I will get the rest of info tomorrow thank you for reply
- x 1056
Are you able to upload the installation instructions here?
Sounds like its not been wired up as per the instructions. Just because it has a connector that may match the original doesn't necessarily mean its plug & play.
- x 8149
With the info you have given I've guessed the RPO to be around 11190 and produced this diagram:
In order to interpret the diagram you may find the guide at this link useful:
viewtopic.php?p=782862#p782862
Dizzylizi83
I am an amateur fitted it myself following you tube video.
All works except cambus steering wheel controls and only goes into sleep mode with power button. Switch off completely.
