Hi, I am trying to REMOVE a wheel bearing with ABS RING, on my 04 plate 206 - I tried to PRESS this out using the old fashioned BOLT and WASHER extractor method, to no avail.
Is it POSSIBLE to REMOVE both the old bearing + ABS RING at the same time ? (to-gether).
The BEARING has a 52mm Outside DIAMETER and the ABS RING has an internal DIAMETER of 49mm so the ABS RING would have to be removed FIRST to get the bearing OUT.
I am reluctant to EXTRACT / DESTROY the ABS RING as they are said to be BRITTLE and prone to BREAKAGE.
I would love to hear from anyone who has REMOVED one of these ABS HUB BEARINGS.
206 REAR DRUM BEARING REMOVAL
- x 8144
Re: 206 REAR DRUM BEARING REMOVAL
Hopefully this video might help you out:
Fergal6816
- x 5
Thank-you,
I did look at this video, but unfortunately this is a disc brake setup, and the ABS RING and wheel bearing are not the same as the DRUM brake setup.
regards
regards
- x 1496
Can you post a pic? Usually by the time the bearing is gone, the drum is also done so you just replace the lot.
- x 2362
With regards to trying not to destroy the ABS ring, normally they are cheap enough to replace.
A very quick look: £7.50 Inc delivery
https://ebay.us/m/VNohnv
Note the dimensions quoted are quite different from the 49mm you've mentioned, so please check to confirm it's correct
Fergal6816
- x 5
Hi, I forgot to mention that the OUTER MAGNETIC part of the ABS RING, is indeed larger than the steel plate which CONNECTS it to the actual drum, so the size is otherwise correct. I saw some for sale on eBay, and these are sold without the steel plate , which gives rise to the disparity and my resulting odd sizes.
There is a brilliant YouTube video showing the EXACT same ABS RING being removed from a FORD FOCUS.
thank-you for your input, it is appreciated,
Fergal6816
- x 5
Somewhat belatedly, a photo of the ABS RING still in - situ.
I was unable to upload this at the time of my original post, there was no indicator icon/logo that I could see, to allow me to do this .
I have now found the link which is only visible in the EDIT / review page silly me !
Steve Walsh
- x 518
that looks like the seal holding the bearing in
- x 1941
Agreed. That's an oil/grease seal. I can't see any evidence of an ABS reluctor ring.
Steve Walsh
- x 518
Most (modern) cars have Reluctor ring in the bearing
- x 2362
Here's a picture of apparently the bit in question (from the eBay link I found above)
