DS3 Service Light on ECO disactivated
patspiercing
x 3
Unread post by patspiercing »
I have a problem with my DS3 2012 1.6 HDi. The SERVICE light is on permanently and the screen says "ECO Deactivated. The ECO light is flashing and I cannot manually reactivate it.
I have reset the service indicator and also done a BSI reset but neither of these has helped.
The car seems to drive fine.
Any ideas as to what the problem may be.
Mick
x 1953
Re: DS3 Service Light on ECO disactivated
Unread post by Paul-R »
You need to get the car read by a decent diagnostic machine (preferably Diagbox) to see what error codes (DTCs) are present.
PaulC5
x 717
Unread post by PaulC5 »
Is this referring to the stop/start system - if so it may be the battery is not fully charged or the ECO stop/start button has been pressed to switch off stop/start.
patspiercing
x 3
Thanks for your responses.
I have just run a global test on Diagbox and come up with the following faults:
P1A9C - Energy Accumulator - State of Health Fault
FD80 - GSM Module Fault
I assume that the P1A9C is the cause of the problem.
I have read on this forum that it probably needs the start/stop capacitor changing.
Anybody know where this is located and a part number for it please.
Mick
patspiercing
x 3
Ever since I have had the car ( since 2015) the stop/start has only worked after a long run. If I do short runs it doesn't work after a day or 2. The battery is good, 12.75V with engine off, and it charges at 14.4V at tickover so I think the alternator is ok.
PaulC5
x 717
Sometimes the capacitor can be under a front wing. The voltage can be high so special care needs to be taken if going near it. Many people including us are probably not bothered that the stop/start does not work for most of the time and if you did replace the capacitor you may find after a while the stop/start still does not work all the time.
This topic covers the FD80 fault viewtopic.php?t=74942
Djandree
x 38
Unread post by Djandree »
patspiercing
x 3
Have got myself a replacement capacitor but cannot undo the electrical heavy duty wires from it. A 12mm socket is too small and a 13mm socket is too big. I have tried AF sockets without success and there is no room to fit an adjustable spanner in.
Is there a special tool for the job?
I have looked at the replacement and an 8mm (13mm spanner size) nut will fit on the terminals so I can fit the new one using these
Any ideas please
patspiercing
x 3
Have checked all the grounds and there is no problem there but thanks for the suggestion.
PaulC5
x 717
A half inch socket might fit, it is between 12 and 13 mm.
patspiercing
x 3
Have tried half inch but that doesn't fit either.
x 8166
This is what you need for that: https://www.ebay.co.uk/itm/404115493557 :)
Djandree
x 38
If you look thru the post you have a tool number in it
patspiercing
x 3
Have got a friend to make me a tool and I have now changed the capacitor.
Unfortunately this has not fixed the problem.
Anybody got any suggestions as to what the problem could be please
Mick
PaulC5
x 717
Have you checked the 12 volt battery yet ? Also, was the replacement capacitor a new one ?
