Evaporating temperature of LHM
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
HI,
Does anyone know what is the evaporating temperature of LHM ?
Zoahr
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 3565
Re: Evaporating temperature of LHM
This doesn't really answer your question, but I think it's the closest you'll get to a meaningful answer. It's taken from the MSDS for Total LHM Plus which contains plenty of information that you never knew you didn't need to know :lol:
https://cdn.autodoc.de/uploads/hazard/p ... 2-EN-1.pdf
Total LHM Plus MSDS - Total Energies
aerodynamica
x 215
Unread post by aerodynamica »
Just searched evaporating temperature of light mineral oils and this came up.
Graeme M
PaulC5
x 689
Unread post by PaulC5 »
If you wanted the atmospheric pressure boiling point the LHM MSDS above gives it as greater than 316°C. Any liquid will evaporate at lower temperatures though, put some water on your hand and it will gradually evaporate to demonstrate this whereas its boiling point is 100°C at atmospheric pressure. If you lower the pressure the boiling point will reduce.
