HI,
Does anyone know what is the evaporating temperature of LHM ?
Zoahr
Evaporating temperature of LHM
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 3565
Re: Evaporating temperature of LHM
This doesn't really answer your question, but I think it's the closest you'll get to a meaningful answer. It's taken from the MSDS for Total LHM Plus which contains plenty of information that you never knew you didn't need to know
https://cdn.autodoc.de/uploads/hazard/p ... 2-EN-1.pdf
aerodynamica
- x 215
Just searched evaporating temperature of light mineral oils and this came up.
Graeme M
PaulC5
- x 695
If you wanted the atmospheric pressure boiling point the LHM MSDS above gives it as greater than 316°C. Any liquid will evaporate at lower temperatures though, put some water on your hand and it will gradually evaporate to demonstrate this whereas its boiling point is 100°C at atmospheric pressure. If you lower the pressure the boiling point will reduce.
