Hello Everyone.
I have a Citroen C8 [2007] with oryginal engine auxiliary heater - webasto thermo top c.
heater wont start automatycly with engine start, i doo test in lexia and diagbox and webasto work fine, no one know why wont start. maby some one unplug something or disabled but where?
Please help.
Citroen C8 webasto Option
- x 6957
Re: Citroen C8 webasto Option
I can't advise on these units, sorry, but are there any fault codes present? Diagbox should provide a fault code if any of the following below. Unfortunately there is no further info on the cause, only the description:
| Permanent Fault Codes | Intermittent Fault Codes | Description of Fault Code |
| 1001 | 2001 | ECU fault: Not characterised |
| 1002 | 2002 | Fault: no flame during restarting: Not characterised |
| 1003 | 2003 | Flame cut-off fault: Not characterised |
| 1004 | 2004 | Fault: no flame during first operation: Not characterised |
| 1005 | 2005 | Fault: additional burner locked on: Not characterised |
| 1006 | 2006 | Fault: flame without fuel flow: Not characterised |
| 1008 | 2008 | Overheating sensor fault: Open circuit, short circuit to positive, short circuit to earth |
| 1009 | 2009 | Temperature sensor fault: Short circuit to earth |
| 1010 | 2010 | Temperature sensor fault: Open circuit or short circuit to the plus |
| 1011 | 2011 | Fault: combustion air turbine: Mechanical blockage |
| 1012 | 2012 | Fault: combustion air turbine malfunction: Not characterised |
| 1013 | 2013 | Fault: flame cuts off then reappears: Undetermined |
| 1014 | 2014 | Glow trigger fault: Resistance value not constant: Not characterised |
| 1015 | 2015 | Fault: glow trigger resistance value: Value received incorrect |
| 1608 | 2608 | Metering pump fault: Short circuit to earth |
| 1609 | 2609 | Fault: combustion air turbine: Short circuit to earth |
| 160A | 260A | Glow trigger fault: Short circuit to earth |
| 160B | 260B | Coolant pump fault: Short circuit to earth |
| 160C | 260C | Vehicle blower fault: Short circuit to earth |
| 1818 | 2818 | Metering pump fault: Open circuit or short circuit to the plus |
| 1819 | 2819 | Fault: combustion air turbine: Open circuit or short circuit to the plus |
| 181A | 281A | Glow trigger fault: Open circuit or short circuit to the plus |
| 181B | 281B | Coolant pump fault: Open circuit or short circuit to the plus |
| 181E | 281E | ECU earth supply fault: Not characterised |
| 1A05 | 2A05 | Battery voltage fault: Undervoltage |
| 1C04 | 2C04 | Battery voltage fault: Excess voltage |
| 1C07 | 2C07 | Overheating fault: Not characterised |
- x 1056
If i remember right on these you cant manually switch them on, they trigger themselves depending on how low temperature is.
Hysiu11
no issue/ problem detected with diagbox, in my contry now i 0Celcius,
webasto test in diagbox - perfectly work .
Vic Evans
- x 173
I've got one of these on my 2000 model Pug 806 bought about 23 years ago. I didn't know what it was until I heard it whistling for about 5 mins on switch off when temperature at or below about 10 c. Peugeot dealer said this was normal but I don't think it's ever 'fired up' except for one occasion when 'smoke' was coming from under the engine & I found it was the exhaust from the thing which must have started.
Don't need it here in sunny Brittany
so I just ignore the whistling now which I assume is the combustion air/ purge fan. Maybe one day I'll find out how to unplug the thing.
chris2005
Hi
Did you find a solution with your webasto problem?
I have the same problem which happened after low voltage due to alternator failure
Will work OK through diagbox but wont work automatically, outside temp -4
I have tried disconnecting fuses and resetting BSI but still have the same problem
Hysiu11
no. still dont work. what abaut yours?
