Citroen C8 webasto Option
Hysiu11
Unread post by Hysiu11 »
Hello Everyone.
I have a Citroen C8 [2007] with oryginal engine auxiliary heater - webasto thermo top c.
heater wont start automatycly with engine start, i doo test in lexia and diagbox and webasto work fine, no one know why wont start. maby some one unplug something or disabled but where?
Please help.
x 6957
Re: Citroen C8 webasto Option
I can't advise on these units, sorry, but are there any fault codes present? Diagbox should provide a fault code if any of the following below. Unfortunately there is no further info on the cause, only the description:
Permanent Fault CodesIntermittent Fault CodesDescription of Fault Code
10012001ECU fault: Not characterised
10022002Fault: no flame during restarting: Not characterised
10032003Flame cut-off fault: Not characterised
10042004Fault: no flame during first operation: Not characterised
10052005Fault: additional burner locked on: Not characterised
10062006Fault: flame without fuel flow: Not characterised
10082008Overheating sensor fault: Open circuit, short circuit to positive, short circuit to earth
10092009Temperature sensor fault: Short circuit to earth
10102010Temperature sensor fault: Open circuit or short circuit to the plus
10112011Fault: combustion air turbine: Mechanical blockage
10122012Fault: combustion air turbine malfunction: Not characterised
10132013Fault: flame cuts off then reappears: Undetermined
10142014Glow trigger fault: Resistance value not constant: Not characterised
10152015Fault: glow trigger resistance value: Value received incorrect
16082608Metering pump fault: Short circuit to earth
16092609Fault: combustion air turbine: Short circuit to earth
160A260AGlow trigger fault: Short circuit to earth
160B260BCoolant pump fault: Short circuit to earth
160C260CVehicle blower fault: Short circuit to earth
18182818Metering pump fault: Open circuit or short circuit to the plus
18192819Fault: combustion air turbine: Open circuit or short circuit to the plus
181A281AGlow trigger fault: Open circuit or short circuit to the plus
181B281BCoolant pump fault: Open circuit or short circuit to the plus
181E281EECU earth supply fault: Not characterised
1A052A05Battery voltage fault: Undervoltage
1C042C04Battery voltage fault: Excess voltage
1C072C07Overheating fault: Not characterised
x 1056
Unread post by wheeler »
If i remember right on these you cant manually switch them on, they trigger themselves depending on how low temperature is.
Hysiu11
no issue/ problem detected with diagbox, in my contry now i 0Celcius,
webasto test in diagbox - perfectly work .
Vic Evans
x 174
Unread post by Vic Evans »
I've got one of these on my 2000 model Pug 806 bought about 23 years ago. I didn't know what it was until I heard it whistling for about 5 mins on switch off when temperature at or below about 10 c. Peugeot dealer said this was normal but I don't think it's ever 'fired up' except for one occasion when 'smoke' was coming from under the engine & I found it was the exhaust from the thing which must have started.
Don't need it here in sunny Brittany :lol: so I just ignore the whistling now which I assume is the combustion air/ purge fan. Maybe one day I'll find out how to unplug the thing.
chris2005
Unread post by chris2005 »
Hi
Did you find a solution with your webasto problem?
I have the same problem which happened after low voltage due to alternator failure
Will work OK through diagbox but wont work automatically, outside temp -4
I have tried disconnecting fuses and resetting BSI but still have the same problem
Hysiu11
no. still dont work. what abaut yours?
