Hopefully someone can help with the wiring on my
son’s Citroen C4.1.6Hdi 2007. I couldn’t get the wiring info for this specific model around the internet!
Lost the power Diagbox fault code P0243.
Replaced Turbo pressure electro valve. Checked vacuum lines and the rest including turbo itself.
I believe it is a wiring issue.
Does someone know where is the wiring from the turbo pressure electro valve ends on ECU?
Any info much appreciated!
Citroen C4 1.6Hdi - P0243
- x 6956
Re: Citroen C4 1.6Hdi - P0243
Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Zelbra
Thank you!
Thank you!
- x 6956
This is the descriptor for this fault code as it relates to the EMS on this vehicle and engine:
| Fault Code: | P0243 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
Zelbra
Thank you! Much appreciated!
Mksto
I know this was a long time ago now but did you find the cause ? I have the same fault code
