Citroen C4 1.6Hdi - P0243
Zelbra
Unread post by Zelbra »
Hopefully someone can help with the wiring on my
son’s Citroen C4.1.6Hdi 2007. I couldn’t get the wiring info for this specific model around the internet!
Lost the power Diagbox fault code P0243.
Replaced Turbo pressure electro valve. Checked vacuum lines and the rest including turbo itself.
I believe it is a wiring issue.
Does someone know where is the wiring from the turbo pressure electro valve ends on ECU?
Any info much appreciated!
x 6956
Re: Citroen C4 1.6Hdi - P0243
Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Zelbra
Thank you!
x 6956
This is the descriptor for this fault code as it relates to the EMS on this vehicle and engine:
Fault Code: P0243
Description of Fault:
  • Turbo pressure regulation electrovalve control: Open circuit. Open circuit or value too high for 1s.
Conditions for Fault to clear:
  • Ignition on
Downgrade Modes whilst Fault is active:
  • Cutting of the EGR butterfly (turbo air cooler), EGR valve and bypass butterfly (inlet air heater) in all operating modes
  • Cutting of the "exhaust heat recovery" function
  • The ECU deactivates the programming cycle of the turbo valve
  • Cut in the programming of the stops of the turbo actuator
Symptoms:
  • Lack of power
Suspect Areas:
  • Electrical harness
  • Connector
  • Fuse F20 on fuse box PSF1
  • Turbocharger control solenoid valve
Zelbra
Thank you! Much appreciated!
Mksto
Unread post by Mksto »
I know this was a long time ago now but did you find the cause ? I have the same fault code
