C3 Picasso DV6DTED EGR question
mrjohnson
Unread post by mrjohnson »
Thinking of cleaning the Pierburg EGR on my C3 Picasso 1.6 HDi 90 2012. I had a dry run yesterday, getting as far as loosening the EGR mounting bolts. A couple of questions. Should I change the O ring? If so, what's the spec? Also, what's the black plastic unit with a long thin arm under the electronic bit of the EGR for?
Thanks in advance.
x 6946
Re: C3 Picasso DV6DTED EGR question
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
