HELLO
I need the original value of this vehicle at the time of its release. all the 'CONFIGURATION' details of this VIN, such as BSI, ECU, ENGINE WIRING HOUSING, INSTRUMENT PANEL, AUDIO, etc.
And I have made a donation.
Thank you.
configuration
- x 6950
Re: configuration
We can't supply this level of information - only what equipment was fitted at factory if you are referring to a build sheet. BSI variants are not shown, nor the specific details of ECUs, only the part number.
We can provide part numbers for limited occasional requests, once the requisite donation has been made. When this has been done your membership profile will be automatically upgraded to Donor 2024 Status, which, as present it has not.
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
yukijiin
Re: configuration
GiveMeABreak wrote: 16 Jul 2024, 15:21 We can't supply this level of information - only what equipment was fitted at factory if you are referring to a build sheet. BSI variants are not shown, nor the specific details of ECUs, only the part number.
to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum.To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Thank you for your response.
What I need are the details similar to those in the attached photo. I am requesting this because I saw another post where someone received such a response. Additionally, I have made a donation to the email address provided, as shown in the attached file. Please confirm.
Thank you.
- x 6950
Re: configuration
Sorry, but that is not a factory build sheet.
That is an ECU configuration table that I supplied to a previous member because I had this information personally. We cannot supply these as part of the 'Official Part Numbers / Part Diagrams' Service we provide to members because this type of info is part of the technical documentation, that requires a separate subscription which we do not provide.
I have personally checked my own data and can also confirm that I do not have the BSI configuration data for this vehicle of this year.
I can advise you though, that your vehicle has an outstanding recall (after-sales campaign to be more accurate), regarding the Adblue Tank Control unit that needs to be replaced.
Contact your Peugeot Dealer, and quote the reference 'KTN'
KTN - All types - Urea reservoir:
Action: Replace the urea reservoir with this control unit.
KTN
Date of campaign: 17/01/2024
Status: Incomplete
The work should be free of charge to you.
KTN
Status: Incomplete
yukijiin
Re: configuration
GiveMeABreak wrote: 16 Jul 2024, 16:30 Sorry, but that is not a factory build sheet.
KTN
Status: Incomplete
You mentioned that a separate subscription is required; could you let me know the cost?
Thank you.
P.S. Can you confirm if the PayPal donation has been received?
- x 6950
Re: configuration
Hi, please let me clarify what I meant. We (the FCF) cannot provide that info for you here as we do not subscribe to PSA technical subscriptions, as they cost £1000s a year for all the different marques and it is not cost-effective for us to do so at this stage. You would have to create your own account with Peugeot and pay for access to technical documentation (which is timed from first access) yourself.
I take it you did not use the donation link directly to PayPal? This method is the quickest as it instantly upgrades you. I'm just checking with my colleague regarding the other method, but in the meantime, I'm perfectly happy to provide your build sheet for you.
| Vehicle Characteristics | |
| Vehicle family | 308 (T9) |
| AS/RP N° | 14324 89 1 0872 |
| Warranty Start Date | 31/10/2016 |
| Engine serial number | 10 DYZN 4038198 |
| BER | e2*2007/46*0405*11 |
| P4A | 9810542199 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | PEUGEOT |
| VEHICLE FAMILY | 308 (T9) |
| SILHOUETTE | 5 DOOR SALOON |
| TRIM LEVEL | GT LINE |
| ENGINE | DW10FD FAP 110KW DIESEL |
| TRANSMISSION | AUTO GBOX 6-SPEED STT |
| PAINT TYPE | METALLIC LACQUER PAINT |
| BODY COLOUR | KCA - ARTENSE GREY PAINT |
| INTERIOR TRIM TYPE | W&W TEXTILE OXF +PVC PU "0N" |
| UPHOLSTERY COLOUR | "FJ" |
| DEFINITION TO FOLLOW | INITIALE RANGE |
| ENGINE (TYPE) | EW/DW |
| OTHER BADGE, " MISC. " | GT LINE |
| SPEEDOMETER DRIVE | WITHOUT SPEEDOMETER RATIO |
| Fuel Supply-Engine | |
| FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
| DIESEL FILTER WATER DETECTOR | WITH DIESEL FILTER WATER DETECTOR |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| EMISSIONS STANDARD (ENGINE) | EURO 6.1 ENGINE EMISSION CONTROL |
| SPEED SENSOR SIGNAL | FRONT WHEEL SENSOR NON-SIGN RR SIGNED |
| CAPACITY | 2000 CM3 |
| CATALYTIC CONVERTER | CATALYTIC CONVERTER ABOVE 50PPM |
| FUEL TANK | FUEL TANK WITHOUT LOCATING TAB |
| COOLING MOTOR | RADIATOR 28DM2 EP: 28 BRAZED ALU |
| CRANKCASE GAS CIRCUIT HEATING | WITH SUMP GAS CIRCUIT REHEATING |
| SPECIAL POWER TRAIN SOUND | WITHOUT POWER TRAIN ACOUSTICS |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" SELF-DIAGNOSIS |
| DEVICE (ANTIPOLLUTION) | EXHAUST GAS RECYCING "EGR" + EXCHANGER |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| FAN | 1 X 2-SPEED FAN 140W AERO DYNAMIC FLAP |
| INJECTION ASSOCIATED VARIANT | MOUNTING DELPHI |
| DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITH STOP AND START ALTERNATOR STARTER |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | CP 15 X 53 |
| WHEEL STYLE | RUBIS 17" WHEEL |
| CLUTCH | WITHOUT CLUTCH |
| RIM/TYRE SIZE | 17 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 225/45 R17 91V NON REINFORCED TYRE |
| DRIVING WHEELS | 2 DRIVEN WHEELS |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| INFLATION PRESSURE LOSS INDICATOR | INDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION |
| GEARBOX TYPE | AM6 3 TYPE GEARBOX |
| Suspension-Steering-Brakes | |
| REAR ANTI-ROLL BAR | REAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD |
| FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR DIAMETER 21 HOLLOW |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
| STEERING WHEEL ANGLE | WITH STEERING ANGLE SENSOR |
| SUSPENSION | NORMAL SUSPENSION |
| SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| STEERING (OPERATION) | LOW POWER DOUBLE PINION ELECTRIC POWER STEERING |
| PEDAL BRACKET (TYPE) | PEDAL ALUMINIUM |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| HORNS | HORNS-HARMONY |
| AERIAL | SHORT ROOF AERIAL |
| SIDE MOULDINGS (DIMENSION) | WITHOUT SIDE PROTECTORS + PEUGEOT SIDE SILL |
| WHEEL EMBELLISHER (STYLE) | WITHOUT WHEEL CAP |
| UNDERBODY SHIELD | WITHOUT PROTECTION UNDER BODY |
| REVERSING LAMPS | WITH TWO REVERSING LIGHTS |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| EXT. LOAD RETENTION RING (ATTACHMENT) | BOAT EXT LASHING RING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | ELECTRIC FOLDING EXTERIOR MIRROR+DIODE |
| SPLASH SHIELD | FRONT STANDARD MUD GUARD WITH FOAM |
| ENGINE BAY SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN |
| WINDSCREEN GLASS (TYPE) | STANDARD WINDSCREEN GLASS |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| REAR SCREEN WIPER | WITH REAR WIPER |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
| ROOF GLASS | WITH FIXED ROOF GLASS |
| BUMPER | DYNAMIC FRONT BUMPER + STANDARD REAR |
| MUDFLAP | WITH FRONT MUDGUARD |
| NUMBER PLATE | WITHOUT LICENCE PLATE |
| LUGGAGE RACK | MOUNTING WITHOUT ROOF BARS |
| FRONT FOGLAMP | LED FRONT FOGLAMPS |
| PANORAMIC VISUAL AID | WITHOUT PANORAMIC VISUAL AID |
| SPARE WHEEL | SPARE WHEEL ALLOY WHEEL + STANDARD TYRE |
| EXTERIOR ACCESSORIES | CHROME+BODY-COLOURED EXT HANDLE |
| EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) | CURVED EXTERIOR MIRROR GLASS |
| GLASS (APPEARANCE) | WINDOW TINTED |
| WINDOW (TYPE) | ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS |
| HANDS FREE ACCESS AND STARTING | WITH HANDS-FREE ACCESS/STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | WITHOUT THEFT PROTECTION ALARM |
| CIGAR LIGHTER | WITH FRONT LIGHTER |
| BLIND SPOT DETECTION | WITHOUT BLIND SPOT MONITORING |
| REAR SEAT ARMREST | WITH REAR SEAT ARMREST |
| INT. LOAD RETENTION | WITH INTERIOR STORAGE |
| LUGGAGE COVER | SHELF |
| REAR SEATBELT | 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING |
| FRONT SEATBELT | RETRACTOR ALARM DRIVER + PASS S/BELT |
| ASHTRAY | FRONT ASHTRY |
| CLIMATE (AMBIENT TEMP) | HOT OR WIDER TEMPERATE COUNTRY |
| SPEED GRADUATIONS | SPEED GRADUATION IN KM/H |
| GEAR SELECTOR | FLOOR GEAR CONTROL |
| DRIVING POSITION | LEFT-HAND DRIVE |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| MIRROR LINK | WITHOUT MIRROR LINK |
| INT. TRIM AND EQUIPMENT VARIATION | WITHOUT ACCESSORIES SOCKET |
| MISC. INT. LAMPS | LC FR/RR LEDS WITHOUT AMB LED WITH AMB LGT |
| LOAD SPACE TRIM | MAT + BACK + SIDES CARPET |
| INSTRUMENT PANEL (CHARACTERISTICS) | INSTRUMENT PANEL WITH MATRIX |
| DOOR TRIM | SATIN CHROME DOOR TRIM DECORATION |
| CHILD SEAT ANCHORING POINTS | WITHOUT CHILD SEAT MOUNTING WITH ISO RR |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS |
| RADIO CONTROLS | REMOTE RADIO CONTROL |
| PASSENGER COMPARTMENT SOUNDPROOFING | SOUNDPROOFING (PASSENGER COMPARTMENT) BULKHEAD 2.8 KG |
| FRONT PASSENGER SEAT HEIGHT CONTROL | PASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT |
| DRIVER SEAT CONTROL | DRIVERS FRT SEAT MANUAL CNTROL |
| DRIVER SEAT ADJUSTMENT | MANUAL DRIVER’S LUMBAR ADJUSTMENT |
| FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER’S LUMBAR SUPPORT |
| FRONT SEAT ARMREST | CENTRAL ARMREST |
| COMPACT DISC | MOUNTING COMPACT DISC |
| SATELLITE NAVIGATION SYSTEM | WITHOUT NAVIGATION SYSTEM |
| HEADLAMP BULBS | LED BULB |
| REAR WINDOW LIFT | SEQENT CONTR RR WINDOW LIFTER |
| TRAFFIC INFORMATION READER | WITHOUT LATERAL TRAJECTORY MONITORING |
| DISPLAY | DIGITAL TOUCH SCREEN |
| COURTESY MIRROR | DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT |
| OIL GAUGE | OIL LEVEL GAUGE |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | HEATED SEAT |
| FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
| FOOTWELL LIGHTING | DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING |
| REAR PASSENGER PROTECTION | W/O RR PASSENGER PROTECTION |
| AIRBAG DEACTIVATION | MANUEL AIRBAG DISARMING |
| REAR LOAD FLOOR | WITHOUT REAR LOAD FLOOR |
| HEADLAMP HEIGHT ADJUSTER | AUTOMATIC HEADLAMP ADJUSTMENT |
| FRONT SEAT GUARD | WITHOUT CAB PROTECTION PANEL |
| FRONT SUN VISOR | DRIVER+PASSENGER SIDE WITH CARD HOLDER+INSCRIP |
| WIFI | WITHOUT WIFI |
| RADIO RECEIVER | SMEG ANALOGUE RADIO RECEIVER |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | CRUISE CONTROL SPEED LIMITER DISTANCE MAINTAINING INHIBITING BY THE CUSTOMER |
| DRIVER’S SEAT HEIGHT CONTROL | PARR+FR DRV HEIGHT ADJ |
| INTERIOR REAR VIEW MIRROR | ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| CARPET COVER | CARPET MAT GT LOGO |
| LOAD SPACE STORAGE | BOOT LATERAL TRIM STRAP |
| TUNER RADIO | MONO RADIO TUNER |
| COOLANT LEVEL WARNING LAMP | NO WATER LEVEL WARNING |
| OBSTACLE DETECTION SYSTEM | FR RR RADAR OBSTACLE DETECTOR + RR CAMERA |
| LATERAL BLINDS | WITHOUT SIDE BLINDS |
| FLOOR MAT | FRONT AND REAR MATS |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| RADIO FREQUENCY | ASIA RADIO FREQUENCY |
| LOCKING CONTROL | NORMAL + AUTOMATIC LOCKING |
| STEERING WHEEL | SPORT LEATHER STEERING WHEEL |
| SEATING ASSOCIATED VARIANT | LOW |
| SEAT LUMBAR SUPPORT (OPERATION) | DRIVER+PASSENGER ELECTRIC LUMBAR SUPPORT |
| AUDIO PACK AUXILIARY SOCKET | 1 JACK SOCKET + USB + PRE-EQUIPMENT |
| TELEMATIC UNIT | WITHOUT TELEMATIC UNIT |
| Electrical | |
| ALTERNATOR | ALTERNATOR ISTT53 |
| BATTERY | BATTERY L3 760 VRLA2 EN AGM |
| STARTER MOTOR | STARTER MOTOR CLASS 6+ |
| SPECIAL LIGHTING | FRONT DAYTIME LIGHTS |
| CEN. LOCKING REM CONTROL FREQUENCY | LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE |
| MULTIPLEXING | FULL ELECTRICAL ARCHITECTURE |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF LIGHTS |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | NORMAL |
| CONDENSER (SPECIFICATIONS) | CONDENSER 19,3DM2 THICKNESS 12 |
| ATMOSPHERIC CONDITIONS | DUSTY ATMOSPHERE |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| LABEL | WITHOUT LABEL |
| AIR CONDITIONING PIPES | STANDARD AIR CONDITIONING PIPES |
| RADIO HEADPHONE SOCKET | 220V ACCESSORIES SOCKET + DOUBLE ACCESSORY |
| TRAFFIC SIDE | DRIVING ON THE RIGHT-HAND SIDE |
| SIDE IMPACTS | DOOR WITHOUT REINFORCEMENT |
| SET OF KEYS | SET OF BADGE KEYS + BACK-UP KEY |
| DOOR SEAL | IMPROVED DIRT SEAL + FR DOOR FR |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | W/O HELP EQUIPMENT |
| SURFACE CONDITIONS | GOOD TERRAIN |
| SPEED MONITORING | WITHOUT SPEED CHECK |
| SLAVE CONTROL UNIT | BSI + COM 2008 + POLY SOUND |
yukijiin
Re: configuration
Thakyou for all. and.. english...
- x 6950
Re: configuration
No problem, changed the build sheet to English for you.
