configuration
yukijiin
configuration
Unread post by yukijiin »
HELLO
I need the original value of this vehicle at the time of its release. all the 'CONFIGURATION' details of this VIN, such as BSI, ECU, ENGINE WIRING HOUSING, INSTRUMENT PANEL, AUDIO, etc.
And I have made a donation.
Thank you.
x 6955
Re: configuration
We can't supply this level of information - only what equipment was fitted at factory if you are referring to a build sheet. BSI variants are not shown, nor the specific details of ECUs, only the part number.
We can provide part numbers for limited occasional requests, once the requisite donation has been made. When this has been done your membership profile will be automatically upgraded to Donor 2024 Status, which, as present it has not.
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
yukijiin
Re: configuration
GiveMeABreak wrote: 16 Jul 2024, 15:21 We can't supply this level of information - only what equipment was fitted at factory if you are referring to a build sheet. BSI variants are not shown, nor the specific details of ECUs, only the part number.
Thank you for your response.
What I need are the details similar to those in the attached photo. I am requesting this because I saw another post where someone received such a response. Additionally, I have made a donation to the email address provided, as shown in the attached file. Please confirm.
Thank you.
x 6955
Re: configuration
Sorry, but that is not a factory build sheet.
That is an ECU configuration table that I supplied to a previous member because I had this information personally. We cannot supply these as part of the 'Official Part Numbers / Part Diagrams' Service we provide to members because this type of info is part of the technical documentation, that requires a separate subscription which we do not provide.
I have personally checked my own data and can also confirm that I do not have the BSI configuration data for this vehicle of this year.
I can advise you though, that your vehicle has an outstanding recall (after-sales campaign to be more accurate), regarding the Adblue Tank Control unit that needs to be replaced.
Contact your Peugeot Dealer, and quote the reference 'KTN'
KTN - All types - Urea reservoir:
Action: Replace the urea reservoir with this control unit.
KTN
Date of campaign: 17/01/2024
Status: Incomplete
The work should be free of charge to you.
yukijiin
Re: configuration
GiveMeABreak wrote: 16 Jul 2024, 16:30 Sorry, but that is not a factory build sheet.
KTN
Status: Incomplete
You mentioned that a separate subscription is required; could you let me know the cost?
Thank you.
P.S. Can you confirm if the PayPal donation has been received?
x 6955
Re: configuration
Hi, please let me clarify what I meant. We (the FCF) cannot provide that info for you here as we do not subscribe to PSA technical subscriptions, as they cost £1000s a year for all the different marques and it is not cost-effective for us to do so at this stage. You would have to create your own account with Peugeot and pay for access to technical documentation (which is timed from first access) yourself.
I take it you did not use the donation link directly to PayPal? This method is the quickest as it instantly upgrades you. I'm just checking with my colleague regarding the other method, but in the meantime, I'm perfectly happy to provide your build sheet for you.
Vehicle Characteristics
Vehicle family308 (T9)
AS/RP N°14324 89 1 0872
Warranty Start Date31/10/2016
Engine serial number10 DYZN 4038198
BERe2*2007/46*0405*11
P4A9810542199
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEPEUGEOT
VEHICLE FAMILY308 (T9)
SILHOUETTE5 DOOR SALOON
TRIM LEVELGT LINE
ENGINEDW10FD FAP 110KW DIESEL
TRANSMISSIONAUTO GBOX 6-SPEED STT
PAINT TYPEMETALLIC LACQUER PAINT
BODY COLOURKCA - ARTENSE GREY PAINT
INTERIOR TRIM TYPEW&W TEXTILE OXF +PVC PU "0N"
UPHOLSTERY COLOUR"FJ"
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)EW/DW
OTHER BADGE, " MISC. "GT LINE
TRIM LEVELGT LINE
SPEEDOMETER DRIVEWITHOUT SPEEDOMETER RATIO
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITH DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.1 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNALFRONT WHEEL SENSOR NON-SIGN RR SIGNED
ENGINE (TYPE)EW/DW
CAPACITY2000 CM3
CATALYTIC CONVERTERCATALYTIC CONVERTER ABOVE 50PPM
FUEL TANKFUEL TANK WITHOUT LOCATING TAB
COOLING MOTORRADIATOR 28DM2 EP: 28 BRAZED ALU
CRANKCASE GAS CIRCUIT HEATINGWITH SUMP GAS CIRCUIT REHEATING
SPECIAL POWER TRAIN SOUNDWITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION)EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1 X 2-SPEED FAN 140W AERO DYNAMIC FLAP
INJECTION ASSOCIATED VARIANTMOUNTING DELPHI
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITH STOP AND START ALTERNATOR STARTER
Gearbox Transmission
FINAL DRIVE RATIOCP 15 X 53
WHEEL STYLERUBIS 17" WHEEL
CLUTCHWITHOUT CLUTCH
RIM/TYRE SIZE17 INCH TYRE FITMENT
TYRE (SIZE, TYPE)225/45 R17 91V NON REINFORCED TYRE
DRIVING WHEELS2 DRIVEN WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
GEARBOX TYPEAM6 3 TYPE GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR DIAMETER 21 HOLLOW
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLEWITH STEERING ANGLE SENSOR
SUSPENSIONNORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
STEERING (OPERATION)LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE)PEDAL ALUMINIUM
Body Fittings
TOWBARWITHOUT TOWBAR
HORNSHORNS-HARMONY
AERIALSHORT ROOF AERIAL
SIDE MOULDINGS (DIMENSION)WITHOUT SIDE PROTECTORS + PEUGEOT SIDE SILL
WHEEL EMBELLISHER (STYLE)WITHOUT WHEEL CAP
UNDERBODY SHIELDWITHOUT PROTECTION UNDER BODY
REVERSING LAMPSWITH TWO REVERSING LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT)BOAT EXT LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONELECTRIC FOLDING EXTERIOR MIRROR+DIODE
SPLASH SHIELDFRONT STANDARD MUD GUARD WITH FOAM
ENGINE BAY SOUNDPROOFINGSOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPERWITH REAR WIPER
HEADLAMP WIPERW/O HEADLAMP WIPER
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITH FIXED ROOF GLASS
BUMPERDYNAMIC FRONT BUMPER + STANDARD REAR
MUDFLAPWITH FRONT MUDGUARD
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKMOUNTING WITHOUT ROOF BARS
FRONT FOGLAMPLED FRONT FOGLAMPS
PANORAMIC VISUAL AIDWITHOUT PANORAMIC VISUAL AID
SPARE WHEELSPARE WHEEL ALLOY WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIESCHROME+BODY-COLOURED EXT HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
GLASS (APPEARANCE)WINDOW TINTED
WINDOW (TYPE)ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
HANDS FREE ACCESS AND STARTINGWITH HANDS-FREE ACCESS/STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTERWITH FRONT LIGHTER
BLIND SPOT DETECTIONWITHOUT BLIND SPOT MONITORING
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
INT. LOAD RETENTIONWITH INTERIOR STORAGE
LUGGAGE COVERSHELF
REAR SEATBELT3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELTRETRACTOR ALARM DRIVER + PASS S/BELT
ASHTRAYFRONT ASHTRY
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
GEAR SELECTORFLOOR GEAR CONTROL
DRIVING POSITIONLEFT-HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
MIRROR LINKWITHOUT MIRROR LINK
INT. TRIM AND EQUIPMENT VARIATIONWITHOUT ACCESSORIES SOCKET
MISC. INT. LAMPSLC FR/RR LEDS WITHOUT AMB LED WITH AMB LGT
LOAD SPACE TRIMMAT + BACK + SIDES CARPET
INSTRUMENT PANEL (CHARACTERISTICS)INSTRUMENT PANEL WITH MATRIX
DOOR TRIMSATIN CHROME DOOR TRIM DECORATION
CHILD SEAT ANCHORING POINTSWITHOUT CHILD SEAT MOUNTING WITH ISO RR
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
RADIO CONTROLSREMOTE RADIO CONTROL
PASSENGER COMPARTMENT SOUNDPROOFINGSOUNDPROOFING (PASSENGER COMPARTMENT) BULKHEAD 2.8 KG
FRONT PASSENGER SEAT HEIGHT CONTROLPASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT
DRIVER SEAT CONTROLDRIVERS FRT SEAT MANUAL CNTROL
DRIVER SEAT ADJUSTMENTMANUAL DRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER’S LUMBAR SUPPORT
FRONT SEAT ARMRESTCENTRAL ARMREST
COMPACT DISCMOUNTING COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
HEADLAMP BULBSLED BULB
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
DISPLAYDIGITAL TOUCH SCREEN
COURTESY MIRRORDRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
OIL GAUGEOIL LEVEL GAUGE
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTHEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATIONMANUEL AIRBAG DISARMING
REAR LOAD FLOORWITHOUT REAR LOAD FLOOR
HEADLAMP HEIGHT ADJUSTERAUTOMATIC HEADLAMP ADJUSTMENT
FRONT SEAT GUARDWITHOUT CAB PROTECTION PANEL
FRONT SUN VISORDRIVER+PASSENGER SIDE WITH CARD HOLDER+INSCRIP
WIFIWITHOUT WIFI
RADIO RECEIVERSMEG ANALOGUE RADIO RECEIVER
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLCRUISE CONTROL SPEED LIMITER DISTANCE MAINTAINING INHIBITING BY THE CUSTOMER
DRIVER’S SEAT HEIGHT CONTROLPARR+FR DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
CARPET COVERCARPET MAT GT LOGO
LOAD SPACE STORAGEBOOT LATERAL TRIM STRAP
TUNER RADIOMONO RADIO TUNER
COOLANT LEVEL WARNING LAMPNO WATER LEVEL WARNING
OBSTACLE DETECTION SYSTEMFR RR RADAR OBSTACLE DETECTOR + RR CAMERA
LATERAL BLINDSWITHOUT SIDE BLINDS
FLOOR MATFRONT AND REAR MATS
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYASIA RADIO FREQUENCY
LOCKING CONTROLNORMAL + AUTOMATIC LOCKING
STEERING WHEELSPORT LEATHER STEERING WHEEL
SEATING ASSOCIATED VARIANTLOW
SEAT LUMBAR SUPPORT (OPERATION)DRIVER+PASSENGER ELECTRIC LUMBAR SUPPORT
AUDIO PACK AUXILIARY SOCKET1 JACK SOCKET + USB + PRE-EQUIPMENT
TELEMATIC UNITWITHOUT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR ISTT53
HORNSHORNS-HARMONY
BATTERYBATTERY L3 760 VRLA2 EN AGM
STARTER MOTORSTARTER MOTOR CLASS 6+
SPECIAL LIGHTINGFRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCYLOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
MULTIPLEXINGFULL ELECTRICAL ARCHITECTURE
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONNORMAL
CONDENSER (SPECIFICATIONS)CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONSDUSTY ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESSTANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET220V ACCESSORIES SOCKET + DOUBLE ACCESSORY
TRAFFIC SIDEDRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTSDOOR WITHOUT REINFORCEMENT
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
DOOR SEALIMPROVED DIRT SEAL + FR DOOR FR
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
SLAVE CONTROL UNITBSI + COM 2008 + POLY SOUND
yukijiin
Re: configuration
Thakyou for all. and.. english...
x 6955
Re: configuration
No problem, changed the build sheet to English for you.
