Both cooler fans needs to run with A/C on, for a Citroen Jumper/Relay III 2016 ?
perfidus
x 6
Unread post by perfidus »
Hi all and glad to meet you as this is my first question asked on the FCF forum.
Since I bought my Jumper(Relay) III campervan (2.0 BlueHDi 120KW from 2016), I've notice that only one engine cooler fan spins when I set the A/C on. Is this normal for a warm engine (coolant temp needle stays in the middle of the scale)? The fan from the right side of the cooler as you look from behind the wheel was never on. First I thought is something broken in the circuits but both the fuses an the relays (F06 and F07, T06 and T07) are OK and both fans start when I bypass the relays contacts.
Who can explain to me how this engine (DW10FUC - AHP) makes the decisions on how to controls the two cooler fans?
Two mechanics told me that it shoud start both fans when A/C is running and engine is warm, but they are not Citroen specialists. This also could be the reason for a higher pressure reading in the A/C system, when engine is rev up, they said, when I checked and adjusted the refrigerant in the system.
Thanks!
Those who don't know history are destined to repeat it!
perfidus
x 6
Re: Both cooler fans needs to run with A/C on, for a Citroen Jumper/Relay III 2016 ?
This is how the two relays for the fans are driven by the p21 and p28 pins in connector 32V NR (BF01 fuse box) but I don't understand the schematics as where do this pins are connected, in wich ECU.
x 6950
One fan will always be on with the A/C, but as for the other one, it probably does not require being on (to save energy) unless the engine temperature is very hot. I'd leave it alone.
perfidus
x 6
Thanks for suggestion Mark. I will leave it for now, maybe will test the fans with diagnose when I'll get one to get it out of my head.
And the issue with the pressure of refrigerant, if it's a real issue, I think it is caused by a bad condenser unit, there are some aluminium fins missing from the cooling tubes and others are very dented by small rocks and other debris. I will probably need to change the unit with a new one.
x 6950
Yes, you can always test it with Diagbox using an actuator test on fans to test operation, which will mean it's working. If there was a pressure issue on the A/C system it will likely go into backup mode and disable it to prevent damage to the system.
perfidus
x 6
Got one Lexia XS Evolution interface (921815/C) and verified the cooling system with DiagBox 7.83.
The fan no.1 is starting somewhere above 80 degrees, fan no. 2 only with A/C on.
Before opening a new thread, I noticed that with my VIN number engine ECU was not recognised and two modules were not comunicating (errors on Airbag ECU and Instrument panel ECU) - this may be an issue with the older 7.83 version?
If I click on the engine ECU i have to choose between three options: DCM62_F?, SID208? and EDC17CP52_UDS?, the later is for a 180HP 3.0HDI engine. Choosing DCM62_F gives another four-five choices and I found my engine code (AHP/AH03) within them.
Readings from the sensors are coherent with this selection. With SID208 (guess it's a Siemens ECU) some readings are not normal.
I will try to install tomorrow a newer version of DiagBox and check if the two modules are comunicating ad ECU is recognised.
EDIT: this morning I've checked with a new version of DiagBox, the 9.68 Free (by Fantomel - thanks FCF). The engine ECU is clearly DCM62_F, but there are still communication errors with a few modules, I will go searching for them and maybe open a new topic.
x 6950
If you don't have a full chip revision C interface (VCI) it won't make any difference what software you use. Later vehicles require a CAN compliant interface and some of the cheaper clones are missing essential hardware from the interfaces which is why they are cheaper.... So this is something to consider and check first of all.
perfidus
x 6
I open the VCI and is full chip rev.C as in pictures, 12 relays etc. I ordered an adapter for newer Jumper/Boxer - S.1279 and wait to see if the VCI can communicate with those ECUs (instrument and airbag). The software version matters to me, because with the newer version it appears to be two more modules that can't communicate. But i doubt that those modules are corect (blind spot monitoring - not sure I have those). It is possible to verify the factory fitted equipment by VIN?
perfidus
x 6
I have the van checked by a friend with an universal tester (tablet with touch screen type - don't remember the model) and the Airbag ECU appears to comunicate with the tool, with no error. This is not good as one seatbelt pretensioner is obviously disconnected from cabling. Of course it may be a resistor placed across the connector but I didn't see one.
The Instrument Panel was not in the list of ECUs, try to test all the lamps but couldn't find the corresponding test page.
x 6950
Hi, no you don't have parking assistance and no blind spot monitoring, and as you asked here's your factory build sheet:
Vehicle Characteristics
Vehicle familyRELAY III
AS/RP N°14483
Warranty Start Date02/09/2016
Engine serial number10 DYZZ 4012521
OPBJ0ZI
BERe3*2007/46*0046*11
General Information
PRODUCT TYPECOMMERCIAL VEHICLE
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYRELAY III
SILHOUETTEEXTENDED VAN H3 TYPE 16H
TRIM LEVELSTANDARD
ENGINEDW10FUC FAP DIESEL
TRANSMISSIONBVM6
PAINT TYPENON-METALLIC PAINT
BODY COLOUREWP - BANQUISE WHITE PAINT
INTERIOR TRIM TYPECLOTH DARKO + TWILL "35"
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)BVM6 MLGUC14
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWMID-LIFE
ENGINE (TYPE)EW/DW
TRIM LEVELSTANDARD
STEERINGVARIABLE POWER STEERING
SPEEDOMETER DRIVETACHO TORQUE 18X14
Fuel supply-Engine
FUELDIESEL GRADE DA/DE/DE+
ENGINE (TYPE)EW/DW
CAPACITY2000 CM3
VEHICLE EMISSIONS STANDARD (TYPE APPROVAL)DEPOLLUTION EURO6 (HOMOLOGATION)
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
TRANSMISSIONBVM6
FINAL DRIVE RATIOCP 14 X 75
WHEEL (TYPE)STEEL WHEELS
INFLATION PRESSURE LOSS INDICATORWITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPEMLGU6 MANUAL GEARBOX
Suspension-Steering-Brakes
TRACTION CONTROLANTISLIPPING
SUSPENSIONDOUBLE-LEAF RR HEAVY DUTY SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
EMERGENCY BRAKING ASSISTANCEWITH EMERGENCY BRAKING ASSISTANCE
Body Fittings
TOWBARWITHOUT TOWBAR
AERIALLONG ROOF AERIAL
SKIPW/O FLAT HAMPER
CABINCLOSED SINGLE CAB
CHASSISSTANDARD CHASSIS
PAYLOADHEAVY PAYLOAD 16Q
SIDE MOULDINGS (TYPE)LATERAL PROTECTOR MASS TINTED
EXHAUST TAILPIPELEFT-HAND SIDE
INDICATORSLONG VEHICLE SIGNALLING LIGHT
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR MANUAL-FOLD BACK
OPENING OF MOVING PANELDOOR OPENING AT 270 DEGREES
WINDSCREEN WIPERFRONT WIPER BLADE W/O RAIN SENSOR
HEADLAMP WIPERW/O HEADLAMP WIPER
SIDE LOAD DOORRH SLIDING SIDE METAL DOOR
BUMPERDYED FRONT/REAR BUMPER
MUDFLAPWITHOUT MUDGUARD
ROOFSTANDARD ROOF PNL
LUGGAGE RACKWITHOUT ROOF BARS
FRONT FOGLAMPNO FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)PASSENGER ELECTRIC DOOR MIRROR
SPARE WHEEL MOUNTINGSTANDARD SPARE-WHEEL CARRIER
WHEEL EMBELLISHER (TYPE)WHEEL TRIM WITHOUT CUSTOMER CHOICE
BODY CONVERSIONWITHOUT
REAR WINDOW (TYPE)WITHOUT REAR WINDOW
GLASS (APPEARANCE)TINTED
WINDOW (TYPE)LAM W/SCREEN + SIDE + RR TOUGHENED
SIDE WINDOW (COMM. VEH. ONLY)WITHOUT SIDE WINDOW
ROW 3 SIDE WINDOWWITHOUT SIDE WINDOW 3ND ROW
HANDS FREE ACCESS AND STARTINGNO ACCES AND HANDSFREE STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
REAR SEATWITHOUT REAR SEAT POSITION
SUPPLEMENTARY SEATWITHOUT SUPPLEMENTARY SEAT POSITN
CABIN SEAT2 PLACES PASSENGER BENCH
CIRCUIT BREAKERWITHOUT BATTERY CUT-OFF
CLIMATE (AMBIENT TEMP)COLD COUNTRIES
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
DRIVING POSITIONLEFT-HAND DRIVE
REMOTE CONTROLREMOTE CONTROL ASSEMBLY
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
FRONT HEAD RESTRAINT (STYLE)OPEN FRONT HEAD RESTRAINT
TIMERWITHOUT TACHOGRAPH
RADIO CONTROLSWITHOUT REMOTE RADIO CONTROL
SIDE DOOR CONTROL MECHANISMNON-MOTORIZED, ELECTRIC LOCKING SIDE DOOR
FRONT PASSENGER SEAT HEIGHT CONTROLWITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROLDRIVER SEAT MANUAL CONTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
FRONT SEATWITH DRIVER’S SEAT
DRIVER SEAT ADJUSTMENTDRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENTWITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT
FRONT SEAT ARMRESTFITTING WITH DRIVER’S FRONT ARMREST
STOWAGE BINWITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
MISC. INT. ACCESSORYDOCUMENT HOLDER TABLE
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGWITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAGNO PASSENGER AIRBAG
ADDITIONAL AIR CONDITIONINGWITHOUT ADDITIONAL AIR CONDITIONING
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED DOOR MIRROR
REAR MOVING PANEL2 REAR HINGED METAL DOORS
COURTESY LAMPFR+RE DOORS CONT - FR+RE INTERIOR LAMP
FRONT SEAT GUARDREMOVABLE CAB PROTECTION PANEL
RADIO RECEIVER4 SPEAKERS WITHOUT RADIO RECEIVER
REFRIGERATIONSINGLE AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLFR + RR DRIVER HEIGHT ADJ
REAR VIEW MIRRORSSTANDARD REAR VISION
DRIVER AIRBAGDRIVERS AIR BAG
INTERIOR PROTECTIONMID-HEIGHT INTERIOR WALLS PROTECTOR
OBSTACLE DETECTION SYSTEMWITHOUT OBSTACLE DETECTOR
LOCKING CONTROLNORMAL + AUTOMATIC LOCKING
STEERING WHEELSTANDARD STEERING WHEEL
PASSENGER SEAT PACKBENCHSEAT WITH 3-POINT CENTRAL BELT
SUPPLEMENTARY HEATERWITHOUT ADDITIONAL HEATING
AUDIO PACK AUXILIARY SOCKETWITHOUT AUDIO PACK AUXILIARY SOCKET
Electrical
BATTERY (FITTING)UPPER BATTERY
STARTER MOTORCLASS 6 STARTER MOTOR
SPECIAL LIGHTINGFRONT DAY RUNNING LIGHT (DRL)
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
RADIO HEADPHONE SOCKETWITH ACCESSORIES SOCKET
PLATEWITHOUT PLATFORM FLOOR
SET OF KEYS1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
COUNTRY ADAPTATIONWITHOUT
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
