I've noticed since MOT'ing my XM that the front passengers side window doesn't work, nor does the electric wing mirror adjustment.
The central locking on the door does work though.
Does anybody have a wiring diagram that I could use to try and work out what is common between the window and the mirror? The VIN for my car is VF7**************[VIN obfuscated, can be read by forum staff].
Thanks,
David.
2000 XM Front Window not working
- Donor 2023
- x 133
'98 Xantia Activa V6 ![Big Grin :-D](./images/smilies/icon_e_biggrin.gif)
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 24
Re: 2000 XM Front Window not working
I think, you have to look at the connector at the A style there will be some contact with corrosion.
Greetings,
Kees .
Greetings,
Kees .
- x 246
Have you posted on Club XM? I know it's pretty much only Dieselman actually answering questions ATM, but they do have online documentation libraries - Gabor's (djg) Circuit Diagram Project spring to mind...
- x 6065
Just seen this David, but just to confirm I don't have any XM diagrams personally, sorryDHallworth wrote: ↑02 May 2024, 22:15 Does anybody have a wiring diagram that I could use to try and work out what is common between the window and the mirror? The VIN for my car is VF7**************[VIN obfuscated, can be read by forum staff].
Thanks,
David.
![Sad :(](./images/smilies/icon_sad.gif)
- x 880
I probably have these diagrams, I will look tonight.
- x 880
Here are the diagrams for front windows (one-touch) and mirrors a late Series 2 XM. I believe them to be correct for RHD.
Good luck!
Good luck!
- Donor 2023
- x 133
Thank you very much ![Smile :)](./images/smilies/icon_smile.gif)
You don't happen to have the key for the diagrams showing what things are, do you?
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6065
David
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
The main index tables link directly to the relevant section as described
Each page has a link at the top to take you back to the main index.
All the diagrams and images can be zoomed by clicking on them
Hopefully these will cover most areas.
- x 880
Here are some general pages on the XM wiring diagrams. The general format is I think similar to earlier cars, but different from the Xantia and different again to anything later.
- Donor 2023
- x 133
Brilliant. Thanks so much.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- Donor 2023
- x 133
Just wanted to say thanks for these diagrams.
I didn't want to take the door card off so knowing where to test for power at the switches and test for continuity between the drivers door and the passengers door was a huge help.
In the end I took the passengers door card off and checked for power at the motor plug, there was power there so I cleaned the contacts with some contact cleaner and a tiny screwdriver and after putting it back together the window is now working.
Really appreciate everyones help as always.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
