NG4 Android radio replacement
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
Stratoblaster
Unread post by Stratoblaster »
I have a 2010 Citroen C5 V6 3.0 Break. It has the original Harman-Becker 2 din head unit and the about 7” display. It has developed a habit to shut itself down after driving some 40-50 km and again and again…
So, I bought a Junsun 10” Android radio replacement. I have now tested it and seems like GPS is working, WIFI is working, BT is working. However I can’t get the audio working.
I began to explore the connections and found out that the 4x2 connection (purple, green, grey, white) that usually carries the speaker signals (FL, FR, RL, RR) and has of course 8 wires coming from the back of the Android radio, connects to a connector that has only four wires? Still the original radio could control left and right as well as front and back because there are 4 speakers.
Then I remembered that there is a subwoofer on the right of the trunk. Ok, the same 4 wires (2 yellowish, orange and grey) attach to the subwoofer unit. My guess is that they must be line level and there is an amplifier (in the box with the sub speaker) delivering the speaker level signals to door speakers. I just wonder how is that done with 4 wires only coming in? I mean how can it handle both panning L and R and Front and Back?
What should I do? Rewire 8 (or at least 4 extra wires if use the existing 4) speaker wires (plus an RCA cable for the sub amp) to the sub box in the back so I can use the power amp of the new Android unit.
The Android unit of course has got RCA-line outs but I don’t know the pinout of the 4 original wires or what kind of signal is it feeding? What would be the easiest way? The Front / Back adjustment is not so necessary if I could only get a L / R signal through.
And one more thing… The steering wheel button support was not working either when test used the Android unit.
Thanks in advance!
See the attached photos.
Back of the NG4
Back of the NG4
Canbus of the Android Radio
Connector of the Android Radio
I guess this is only valid if there is no sub?
Big connectors attached
Citroen C5 connector with 4 leads that feed the sub box
Sub box
Sub box
x 6950
Re: NG4Android radio replacement
I know a little late now as you've bought it, but you could of just done the CF card replacement of the hard drive and you'd be back to normal most likely, unless there was a hardware fault of course.
It's a different kettle of fish with a) the HiFi Amplifier option and b) if you have the services module fitted, which also uses at least on of the speakers for emergency services connection when airbags have been triggered - along with geolocation in a crash.
That wiring diagram is for an RT4 not an NG4 with HiFi and possible services module.
If you provide your VIN I'll get a wiring diagram up of the NG4 for you. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Stratoblaster
Yeah, I know that I could have installed a CF-card. I actually ordered an exact replacement Toshiba disk for it if I have to re-install the old system. I guess it is possible without any troubles, re-coding etc?
You mean the VF7**************[VIN obfuscated, can be read by forum staff]… as a VIN?
Stratoblaster
x 6950
Yes, the only drives I'm aware of apart from new (if you can still get them) are old used ones from old servers and are probably near end of life too!
Here's the HiFi Connections in case it helps.
"a" 16-way blue connector.
"b" 16-way black connector.
"c" Bonnet locking 16.
Note: The speaker cables are twisted in positive and negative pairs and bear the same name.
Role
The audio amplifier amplifies the 4 audio outputs from the audio system and distributes them over 8 amplified outputs:
  • 2 outputs for the front woofers
  • 2 outputs for the front tweeters
  • 2 for the rear tweeters and woofers connected in parallel
  • 2 outputs for the bass box
Electrical features
The connection to the audio amplifier is by means of 3 connectors (The 3 connectors are of the SICMA 16-way type):
  • The black connector transmits the low power information and the supplies
  • The blue connector transmits the power information to the right-hand speakers
  • The white connector transmits the power information to the left-hand speakers
Channel numberDesignation
1Front right tweeter +
2+ front door right-hand bass speaker
3Unused
4+ rear door right-hand speaker
5Unused
6Right-hand bass module +
7Unused
8Right-hand central channel +
9Front right tweeter -
10- front door right-hand bass speaker
11Unused
12- rear door right-hand speaker
13Unused
14Right-hand bass module -
15Unused
16Right-hand central channel -
1Unused
2CAN +
3Unused
4Right-hand audio system + input
5Right-hand audio system - input
6Unused
7CAN High
8Unused
9Permanent +
10Unused
11Left-hand audio system - input
12Left-hand audio system + input
13Unused
14VAN Low
15Unused
16Earth
1Front left tweeter +
2+ front door left-hand bass speaker
3Unused
4+ rear door left-hand speaker
5Unused
6Left-hand bass module +
7Unused
8Left-hand central channel +
9Front left tweeter -
10- front door left-hand bass speaker
11Unused
12- rear door left-hand speaker
13Unused
14Left-hand bass module -
15Unused
16Left-hand central channel -
Stratoblaster
Re: NG4 Android radio replacement
Oh, that is not easy! Where is that box located?
x 6950
On a left hand drive, it's hidden behind the right side (passenger) of the dashboard, so the glovebox need to come off to get access to it.
Stratoblaster
Thanks a lot!
If I solder an RCA connector both to pins 4/5 and 11/12 of the black box and feed there a line-out signal from Android unit, should it do the trick? Propably not since the NG4 is not guiding the system anymore? Or is the HiFi amp totally indipendent from the head unit I have disassembled?
x 6950
The HiFi was an optional extra - and NG4 was supplied with and without the amp and with or without the services module.
These are the NG4 Speaker connections:
"e" 3-part connector
Part "A": 16 way connector
Channel numberAllocation of channels of connector
1signal: Right hand rear speaker
2signal: Front right hand speaker
3signal: Front left hand speaker
4signal: Rear left loudspeaker
5Earth : Right hand rear speaker
6Earth : Front right hand speaker
7Earth : Front left hand speaker
8Earth : Rear left loudspeaker
9Supply : Screen DG4
10Comfort CAN High
11Channel not allocated
12Battery + supply
13Comfort CAN Low
14Channel not allocated
15Earth : Screen DG4
16Earth
Part "B": 12 way connector
1Video input no 1 +
2Channel not allocated
3Earth : Microphone
4Right-hand audio auxiliary
5LIN bus for screen DG4
6Video input no 2 +
7Video n°1 -
8Channel not allocated
9Input : Microphone signal
10Left-hand audio auxiliary
11Audio earth
12Video n°2 -
Part "C" : 12-way black connector (*)
(*) Only with CD changer (Not available on hybrid vehicles)
1Earth : CD changer
2VAN Low : CD changer
3Permanent + : CD changer
4Right audio system: CD changer
5Rear socket LH audio output signal
6Channel not allocated
7CAN High : CD changer
8Earth : CD changer
9Rear socket RH audio output signal
10Left audio system: CD changer
12Rear socket audio output earth
DHallworth
x 171
Unread post by DHallworth »
Sorry to hijack your thread. I might be interested in buying your old NG4 as half of the buttons on the front of mine don't work and the joystick is hanging off. Would be good to make 1 out of the 2.
Let me know if you do decide to sell it please.
David.
'98 Xantia Activa V6 :-D
'13 Renault Zoe - Broken
'15 C4 BlueHDi Feel - For Sale
Stratoblaster
DHallworth wrote: 10 Apr 2024, 15:36 Sorry to hijack your thread. I might be interested in buying your old NG4 as half of the buttons on the front of mine don't work and the joystick is hanging off. Would be good to make 1 out of the 2.
David.
Sorry but I decided to keep the original unit because it is too complicated to try to replace it with a modern Android unit.
I have now tested how to install the Android unit as a second unit and feed the audio signal from its RCA-outs to the AUX ins of the original unit. It works fine. The new 10” diaplay goes to the place of the old display and the old display goes on top of the dashboard in a housing (which I have to custom build). Sounds easy, eh!
Stratoblaster
Is there an ”ignition 12V” somewhere available in those wires that come to the back of the NG4? I need that to wake up the Android unit.
GiveMeABreak wrote: 09 Apr 2024, 15:28 The HiFi was an optional extra - and NG4 was supplied with and without the amp and with or without the services module.
10Comfort CAN High
12Battery + supply
13Comfort CAN Low
16Earth
1Video input no 1 +
3Earth : Microphone
6Video input no 2 +
7Video n°1 -
11Audio earth
12Video n°2 -
1Earth : CD changer
8Earth : CD changer
x 6950
No, because these original telematics units in the vehicle have to use a permanent live all the time, hence Pin 12 on Part A.
Kreoshoc
Unread post by Kreoshoc »
Ok, you are lucky, because I had the same issue while replacing my NG4 (also with HiFi sound). A head unit fully controls the amplifier: volume is set by the can bus (hu provides a constant level of output), equalizer, balance, and fader - all controlled by can packages sent from the head unit to the amplifier by the can bus. And Chinese can bus adapters don't support that functionality. So the solution is to develop a custom can bus adapter that will push missed or broken can packages into the can bus.
I've developed a can bus adapter based on Arduino, here is a sketch: https://github.com/lozynskiy/citroen_ca ... ceiver.ino and here is described a development process (divided into 3 parts, don't miss them all, please use google translator): https://driver.top/exp/498635/
Also, it allows mapping wheel buttons using the SWC application.
Feel free to ask any questions.
sonny7
Unread post by sonny7 »
Kreoshoc wrote: 23 Sep 2024, 07:06 Ok, you are lucky, because I had the same issue while replacing my NG4 (also with HiFi sound). A head unit fully controls the amplifier: volume is set by the can bus (hu provides a constant level of output), equalizer, balance, and fader - all controlled by can packages sent from the head unit to the amplifier by the can bus. And Chinese can bus adapters don't support that functionality. So the solution is to develop a custom can bus adapter that will push missed or broken can packages into the can bus.
Omg! I'm reading this and it seems that you have exactly explained my problem!! :shock:
I have a C5 (X7) with the HiFi option - and therefore the Amp - but it doesn't work with the Junsun chinese unit I bought.
The sound is horrible and does not work with some speakers, if I put the fader all the way to the rear speaker I get not sound at all. I even bought another CanBus "RZ-PSA15" but it's the same thing..
So yeah what you explained seem to solve the problem we would all encounter with these chinese Android units.
However, I'm very very bad with electronics, just fitting that Junsun unit was a big headache for me, so really I don't how I could reprogram a CanBus or something, seems totally impossible to me :cry:
But..! there could be a solution, maybe you would be willing to sell that to me? :-D
Just let me know, your help would be welcome
Cheers from Tallinn, Estonia! ??
