Hello all,
I have recently changed the manifold and cat on the 2011 C1. The cat had some brackets that looked like they should bolt somewhere to stop it vibrating. These were not on the cracked one that was taken off! Perhaps that is why it cracked?
Anyway. Phoned Citroen parts and they sent a support bracket for the car. Photo attached. Can't for the life of me see where it attached to.
Can anyone help? Thanks Matthew
Manifold and catalytic converter C1 2011
Nickolm
- x 6955
Re: Manifold and catalytic converter C1 2011
That attached to the right side of the cat, just below half way down where there is a bracket on the side of the Cat, to which that part fits and is bolted on and the other end is bolted onto another part. If you need the diagram, please see below:
We can help if you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
- x 1056
