PSA Electrical Diagrams - List of Components 6600 to 9085
x 6948
From 6600 to 7806From 7807 to 9085
6600: Headlamp Height Adjustment Control.7807: Brake Circuit Pressure Sensor 1.
6605: Headlight Height Adjustment Unit.7808: Brake Circuit Pressure Sensor 2.
6610: Left-Hand Headlamp Height Adjustment Motor.8000: Air Conditioning Switch.
6615: Right-Hand Headlamp Height Adjustment Motor.8001: Air Conditioning Compressor Relay Shunt.
6616: Front Body Height Sensor.8004: Air Conditioning Cut-Off Control Unit.
6617: Rear Body Height Sensor.8005: Air Conditioning Compressor Relay.
6620: Vehicle Height Correction Control Fuse.8006: Evaporator Thermistor (If Separated).
6621: Vehicle Height Correction Motor Fuse.8007: Pressostat.
6625: Vehicle High Position Switch.8008: Air Conditioning Engine Coolant Temperature Thermistor.
6630: Parking Brake Information Relay (Vehicle Height Correction).8009: Freon Pressure Sensor.
6631: Brake Pedal Information Relay (Vehicle Height Correction).8010: Coolant Temperature Unit.
6632: Hydraulic Circuit Fluid Pressure Switch.8012: Air Conditioning Cut-Off Pressure Switch.
6635: Vehicle Height Correction Control Unit-Sensor.8014: Idling Stability Solenoid Valve.
6636: Vehicle Height Correction Motor Relay.8015: Compressor Cut-Off Relay Controlled By Coolant Temperature Unit.
6637: Vehicle Height Correction Solenoid Valve Relay.8016: Compressor Cut Off Relay Controlled By The Injection ECU.
6640: Vehicle Height Correction Electric Pump Motor.8020: Air Conditioning Compressor.
6645: Vehicle Height Correction Solenoid Valve.8022: Air Conditioning Coolant Thermal Switch.
6646: Vehicle Height Correction Fluid Level Switch.8025: Heater Panel (If Separated).
6700: Differential Lock Control Switch.8030: Passenger Compartment Air Thermistor.
6701: Differential Lock Control Solenoid Valve (Rear).8031: Coolant Thermistor.
6702: Control Solenoid Valve (Change To 4?4).8032: Outside Air Thermistor.
6703: Control Solenoid Valve (Staying In 4?4).8033: Sunshine Temperature Sender Unit.
6705: Differential Lock Fuse.8034: Air To Footwell Temperature Sender Unit.
6706: Control Relays (Change To 4?4).8035: Passenger Compartment Temperature Electronic Thermostat (If Separated).
6707: Switch (Change To 4?4).8036: Temperature Display Rheostat (If Separated).
6709: Reduction Gear Change Closing Switch.8037: Air Vent Temperature Sender Unit.
6710: Front Differential Lock Position Switch.8038: Luminosity Sensor.
6711: Closing Sensor (Change To 4?4).8040: Blower Speed Rheostat (If Separated).
6712: Differential Lock Opening Sensor (Rear).8043: Right-Hand Blower Control Module.
6715: Rear Differential Lock Position Switch.8044: Left-Hand Blower Control Module.
6720: Differential Lock Control Unit.8045: Blower Control Module (If Separated).
6730: Front Differential Lock Motor.8046: Blower Motor Resistor (If Separated).
6735: Rear Differential Lock Motor.8047: Blower Speed Control (If Separated).
6740: Differential Lock Relay.8048: Blower Relay.
6750: Controlled Differential Control Unit.8049: additional air conditioning blower resistor /
6755: Traction Control Cut-Off Switch.8050: Heater Blower Motor (If Separated).
6760: Controlled Proportional Differential Solenoid.8051: Right-Hand Blower Motor.
6800: Sun Roof Switch.8052: Left-Hand Blower Motor.
6801: End Of Sun Roof Travel Switch.8053: left-hand additional blower speed switch
6802: End Of Sun Roof Tilting Switch.8054: right-hand additional blower speed switch
6803: Sun Roof Slide Relay Control.8055: first resistor unit control relay /
6804: Sun Roof Half Travel Control Relay.8060: Heater Unit.
6805: Sun Roof Relay.8061: Heating/Air Conditioning Unit Relay.
6806: Sun Roof Zero Point Switch.8062: heating/air conditioning unit shunt
6807: Sunroof Relay In The Sunroof Assembly.8065: Mixing Flap Motor.
6808: Sun Roof Intermediate Position Switch.8067: Air Inlet Flap Control.
6810: Sun Roof Motor.8068: Left-Hand Air Inlet Flap Reduction Motor.
6811: Sun Roof One-Touch Motor.8069: Right-Hand Air Inlet Flap Reduction Motor.
6820: Sun Roof Assembly.8070: Air Inlet Flap Reduction Motor.
6821: Safety Auto-Reverse Sensor.8071: Air Distribution Flap Motor.
6825: Sunroof Infra-Red Transmitter.8072: Ventilation Flap Motor.
6826: Sun-Roof Infra Red Receiver.8073: Footwell/Demisting Flap Motor.
6830: Sunroof Control Unit.8074: Breaker Valve.
6840: Left-Hand Electric Quarter Light Switch.8080: Air Conditioning ECU.
6842: Left-Hand Electric Quarter Light Return Switch.8090: Compressor Protection Diode.
6845: Right-Hand Electric Quarter Light Switch.8096: Additional Heating Operation Information Diode.
6847: Right-Hand Electric Quarter Light Return Switch.8097: Fuel Heating Control Switch.
6850: Left-Hand Electric Quarter Light Motor.8098: Additional Heating.
6855: Right-Hand Electric Quarter Light Motor.8099: Additional Heating Burner.
6860: Electric Hood ECU.8100: Front Cigar Lighter.
6861: Electric Hood Switch.8105: Rear Cigar Lighter.
6862: Electric Hood Electric Pump Motor.8110: Heated Rear Screen Switch.
6863: Rear Section Opening Solenoid.8112: Rear Screen Demisting Sensor.
6864: Rear Section Closing Solenoid.8115: Heated Rear Screen Relay.
6865: Electric Hood Closing Solenoid.8116: Rear Screen Heater Time Switch Relay.
6866: Electric Hood Opening Solenoid.8118: Heated Rear Screen (Left).
6867: Cover Opening Solenoid.8119: Heated Rear Screen (Right).
6868: Cover Closing Solenoid.8120: Heated Rear Screen.
6870: Electric Hood Electric Pump Motor Relay.8121: Rear Screen De-Misting Motor.
6871: Rear Section Ram Switch.8125: Heated Mirror (On The Driver's Side) (If Separated) (Electrical).
6872: Electric Hood Ram Switch.8130: Heated Mirror (Passenger's Side) (If Separated) (Electrical).
6873: Cover Ram Switch.8140: Heated Windscreen.
6874: Electric Hood Switch.8141: Heated Windscreen Switch.
6875: Electric Hood Buzzer.8145: Heated Windscreen Relay.
6876: Electric Hood Buzzer Diode.8146: Heated Windscreen Timer Unit.
6877: Boot Open Diode.8200: Coded Anti-Start Keypad.
7000: Front Left-Hand Anti-Lock Brake Sensor.8201: Coded Anti-Start LED.
7001 Power Steering Fluid Pressure Switch.8203: Relay Circuit Diode Injection Control Unit Supply.
7005: Front Right-Hand Anti-Lock Brake Sensor.8205: Diagnostic Indicator Light Circuit Diode.
7010: Rear Left-Hand Anti-Lock Brake Sensor.8206: Coded Anti-Start Device Door Circuit Diode
7013: Gear Lever Neutral Switch.8207: Immobiliser Relay For Diesel Pump.
7014: Rear Wheel ABS Sensor.8208: Immobiliser Control Unit/Transponder.
7015: Rear Right-Hand Anti-Lock Brake Sensor.8209: Transponder Coil.
7016: ABS Acceleration Sensor.8210: Transponder Relay Shunt.
7017: ABS Control Unit Fuse.8220: Analogue Module Transponder.
7018: ABS Control Unit Relay.8221: Control Module Transponder.
7019: Idle Maintaining Simulation Resistor.8300: Driver's Heated Seat Switch.
7020: Anti-Lock Brake Control Unit.8301: Electrically Heated Seats Control Unit.
7025: ABS Hydraulic Unit (GPF).8302: Driver's Heated Seat Rheostat.
7026: Brake Assistance Electric Pump.8303: Passenger's Heated Seat Rheostat.
7027: ABS Solenoids Fuse.8305: Passenger's Heated Seat Switch.
7028: Anti-Lock Braking System Shunt.8306: Left-Hand Rear Heated Seat Switch.
7029: ABS Pump Fuse.8307: Right-Hand Rear Heated Seat Switch.
7030: Electric Pump Unit.8308: Heated Seat Relay.
7031: Electric Pump Unit Relay.8310: Heated Seat (On The Driver's Side).
7040: Additional Regulation Unit (ARU).8311: Heated Seat Thermostat.
7041: Additional Regulation Unit Electrical Board.8315: Heated Seat (Passenger's Side).
7045: Clutch Pedal Information Switch.8320: Heated Rear Seat.
7046: Clutch Position Potentiometer.8321: Heated Seat Timer Relay (Driver).
7048: Piloted Brake Servo.8322: Heated Seat Timer Relay (Passenger).
7049: Controlled Brake Servo Control Unit.8323: Heated Seat Timer Relay (Rear LH).
7050: Traction Control ECU.8324: Heated Seat Timer Relay (Rear RH).
7055: Traction Control Hydraulic Unit.8325: Left Rear Heated Seat.
7060: Traction Control Throttle Actuator.8326: Right Rear Heated Seat.
7065: Traction Control Throttle Potentiometer.8327: Driver's Seat Cushion Heating Element.
7075: Traction Control Cut-Off Switch.8328: Driver's Seat Backrest Heating Element.
7076: ABS Switch Indicator Light Relay.8329: Passenger's Seat Cushion Heating Element.
7077: Hill Holder Cut-Off Switch.8330: Passenger's Seat Backrest Heating Element.
7078: Hill Holder Buzzer.8331: Driver's Heated Seat Control Unit.
7080: Brake Fluid Level Information Diode.8332: Passenger's Heated Seat Control Unit.
7090: Brake Servo Vacuum Pump.8333: Driver's Heated Seat Sensor.
7100: Power Steering Servo-Regulator.8334: Passenger's Heated Seat Sensor.
7105: Variable Power Assisted Steering Control Unit.8401: Impedance Adaptor.
7110: Power Steering Servo.8402: Aerial Lead.
7111: Proportional Solenoid Variable Power-Assisted Steering.8403: Aerial Filter.
7112: Power Steering Pressure Sensor.8404: Aerial.
7113: Power Steering Stop Sensor.8405: Electric Aerial.
7115: Power Steering Control Relay.8406: Electric Aerial Module.
7120: Power Steering Pump Electric Motor.8407: Duplexer.
7121: Electric Pump Diode Power-Assisted Steering.8408: Radio Amplifier.
7125: Power Steering Power Relay.8409: Heated Rear Screen Aerial Assembly.
7200: Trip Computer-Cruise Control Information Relay.8410: Radio.
7201: Colour Display Control Unit.8411: Radio Balance Front Left/Right.
7205: Trip Computer Display Switch.8412: Radio Balance Front/Rear.
7210: Trip Computer.8413: Radio Control.
7215: Multifunction Screen.8415: Compact Disc Player.
7216: Multifunction Screen Key Pad.8416: Compact Disc Interface.
7220: Clock.8420: Front Door Speakers (On The Driver's Side).
7222: Outside Temperature Sensor.8421: Front Speakers.
7225: Clock + Exterior Temperature Display.8422: Front Door Speakers (Left).
7226: Exterior Temperature Display.8423: Front Door Speakers (Right).
7300: Cruise Control Switch.8424: Audio Amplifier.
7305: Cruise Control Switch.8425: Front Door Speakers (Passenger's Side).
7306: Cruise Control Override Switch (Clutch).8426: Bass Acoustic Speaker Enclosure.
7307: Cruise Control Override Relay.8430: Speaker (Rear LH).
7308: Cruise Control Safety Switch (Brakes).8435: Speaker (Rear RH).
7309: Cruise Control Circuit Shunt - Engine Check.8440: Left-Hand Front Tweeter Speaker.
7310: Cruise Control Control Unit.8442: Front Left-Hand Mid Range Speaker.
7311: Cruise Control Fuse.8443: Speaker : Boomer (Front LH).
7312: Cruise Control Switch Indicator Light Circuit Diode.8445: Right-Hand Front Tweeter Speaker.
7315: Cruise Control Vacuum Pump-Breather Assembly.8447: Front Right-Hand Mid Range Speaker.
7320: Cruise Control Override Solenoid Valve.8448: Speaker : Boomer (Front RH).
7400: External Temperature Display.8450: Left-Hand Rear Tweeter Speaker.
7500: Parking Aid ECU.8452: Rear Left-Hand Mid Range Speaker.
7501: Laser Distance Guide.8453: Speaker : Boomer (Rear LH).
7502: Laser Rangefinder Switch.8455: Right-Hand Rear Tweeter Speaker.
7503: Speaker (Parking Aid).8457: Rear Right-Hand Mid Range Speaker.
7504: Rear Speakers (Parking Aid).8458: Speaker : Boomer (Rear RH).
7505: Parking Aid Cut-Off Switch.8460: Headphone Socket Left-Hand Rear.
7506: Proximity Sensor (Front LH - Exterior).8465: Headphone Socket Right-Hand Rear.
7507: Proximity Sensor (Front LH - Interior).8470: Police Radio Electrical Supply (Front).
7508: Proximity Sensor (Front RH - Exterior).8471: Rear Police Radio Supply 1.
7509: Proximity Sensor (Front RH - Interior).8472: Rear Police Radio Supply 2.
7510: Proximity Sensor (Rear LH - Exterior).8475: Radio Telephone Instrument Panel.
7511: Proximity Sensor (Rear LH - Interior).8480: Radio Telephone Transmitter-Receiver.
7512: Proximity Sensor (Rear RH - Exterior).8481: Car-Phone Loudspeaker.
7513: Proximity Sensor (Rear RH - Interior).8482: Car-Phone Microphone.
7514: Buzzer (Parking Aid).8483: Car-Phone On Warning Buzzer.
7600: Under-Inflation Detector Control Unit.8484: Car Phone Aerial.
7605: Under-Inflation Detector Re-Initialisation Switch.8485: Car-Phone Key Pad.
7700: Steering Wheel Angle Sensor.8486: External Audio-Video Input Unit.
7702: Front Body Height Sensor.8500: Navigation Control Unit.
7703: Rear Body Height Sensor.8501: GPS Aerial.
7704: Body Height Potentiometer.8502: On-Board Navigation System Speaker.
7705: Body Height Sensor.8503: Control Key Pad.
7706: Brake Pressure Sensor.8504: Traffic Information Unit.
7707: Accelerator Pedal Position Sensor.8505: Traffic Information Switch.
7708: Front Wheel Movement Sensor.8600: Alarm Unit.
7709: Rear Wheel Movement Sensor.8601: Anti-Theft Alarm Key Switch.
7710: Suspension Switch.8602: Interior Protection Unit (Anti-Theft Alarm).
7711: Front Right-Hand Wheel Movement Sensor.8603: Anti-Theft Alarm Switch.
7712: Front Left-Hand Wheel Movement Sensor.8604: Ultrasonic Sensor.
7713: Rear Right-Hand Wheel Movement Sensor.8605: Alarm Siren.
7714: Rear Left-Hand Wheel Movement Sensor.8606: Alarm LED.
7715: Suspension Control Unit.8607: Ultrasonic Transmitter.
7716: Suspension Solenoid Valve (Single Or Front).8608: Ultrasonic Receiver.
7717: Rear Suspension Solenoid Valve.8609: Ultrasonic Transmitter + Alarm LED.
7718: Roll Correction Solenoid Valve.8610: Luggage Compartment Alarm Contact.
7719: ADAC Electro-Hydraulic Unit (Active Anti-Roll).8611: Anti-Theft Alarm System Bonnet Switch.
7720: Front Left-Hand Damper Actuator.8612: Right-Hand Rear Hinged Door Alarm Switch.
7721: Shock Absorber Auto Anti-Interference -Front LH.8613: Alarm Rear Left-Hand Door Switch.
7722: Control Unit (Citroen Active Roll Control System).8614: Alarm Rear Right-Hand Door Switch.
7723: Accelerometer (Citroen Active Roll Control System).8615: Dipped Beam Supply Relay For Alarm.
7724: Variable Damping Accelerometer.8616: Alarm Relay.
7725: Front Right-Hand Damper Actuator.8617: Anti-Theft Alarm Warning Relay.
7726: Damper Auto Anti-Interference - Front RH.8618: Anti-Lifting Contact.
7730: Rear Left-Hand Damper Actuator.8630: Passenger Compartment Protection Unit.
7731: Shock Absorber Auto Anti-Interference (Rearlh).8700: Electric Sun-Blind Motor.
7735: Rear Right-Hand Damper Actuator.8701: Electric Blind Switch.
7736: Shock Absorber Auto Anti-Interference (Rearrh).8702: Rear Electric Blind Switch.
7739: Centralised Electronic Unit Motor.9000: Central Unit.
7740: Suspension Electro-Hydraulic Unit.9005: Left Front Side Lamp Station.
7741: Front Right-Hand Suspension Solenoid Valve Unit.9010: Fan Unit Station.
7742: Front Left-Hand Suspension Solenoid Valve Unit.9015: Right Front Side Lamp Station.
7743: Rear Right-Hand Suspension Solenoid Valve Unit.9020: Wipe/Wash Station.
7744: Rear Left-Hand Suspension Solenoid Valve Unit.9025: Sensor Information Station.
7745: Vehicle Height Selector.9030: Left Front Door Station.
7746: Piloted Rear Suspension Pad Solenoid Valve.9031: Seat Unit.
7747: Front Suspension Solenoid Valve.9035: Instrument Panel Station.
7748: Rear Suspension Solenoid Valve.9040: Display Station.
7750: Suspension Control Board.9045: Passenger Compartment Station.
7760: CAN Interface.9050: Right Front Door Station.
7770: Hydraulic Fluid Level And/ Or Pressure Warning Buzzer.9055: Signalling Switch Station.
7800: Stability Checking ECU.9056: Automatic Lighting Unit.
7801: Stability Check Cut-Off Switch.9060: Wiper Switch Station.
7802: Stability Check Relay.9065: Console Station.
7803: Stability Check Steering Wheel Angle Sensor.9070: Towing Station.
7804: Accelerometer Gyro Stability Check.9075: Left Tail Lamp Station.
7805: Pre-Load Pump Stability Check.9080: Tailgate Station.
7806: Hydraulic Unit Stability Check.9085: Right Tail Lamp Station.
