PSA Electrical Diagrams - List of Components B001 to 2215
x 6945
From B001 To 1233From 1234 To 2215
B001: Mixed Bridge Block 1.1234: Carburettor Damper Solenoid Valve.
B002: Mixed Bridge Block 2.1235: Carburettor Breather Solenoid Valve.
B003: Mixed Bridge Block 3.1236: Overrun Cut-Off Solenoid Valve.
BB00: Battery.1237: Pulsair Solenoid Valve.
BB01: Battery Assembly (Rear).1238: 2 Volume Vasc Solenoid.
BB02: Battery Assembly (Lower Front).1239: Idling Regulation Solenoid Valve.
?B0?: Battery Assembly (Upper Front).1240: Induction Air Temperature Sensor.
BB04: Battery Central Assembly Unit.1241: Pulsair Pump.
BB05: Starter Battery.1242: Pulsair Relay.
BB06: Battery.1243: Variable Solenoid Valve 1.
BB10: Battery + Ve Control Unit.1244: EGR Proportional Solenoid Valve.
BCP3: 3 Relay Protection Switch Unit.1245: Altitude Switch.
BF00: Passenger Compartment Fuse Box.1246: EGR Function Supply Relay.
BF01: Fuse Box Under Bonnet.1247: EGR Coolant Thermal Switch.
BF02: Fuse Box (Luggage Compartment).1248: EGR Calibration Resistor.
BGP0: Centralised Control Unit (Police).1249: Load Lever Potentiometer (EGR).
BH12: 12 Fuse Box (Passenger Compartment).1250: EGR Exhaust Gas Recycling Control Unit.
BH28: 28 Fuse Box (Passenger Compartment).1251: EGR Vacuum Pump.
BMF1: Maxi Fuse Unit.1252: Diesel Advance Corrector Relay.
BMF2: Maxi Fuse Unit.1253: All Or Nothing Solenoid Valve (EGR).
BMF3: Maxi Fuse Unit.1254: EGR Load Lever Switch.
BMF4: Maxi Fuse Unit.1255: Fuel Cut-Off Solenoid Valve.
BM27: Engine Fuse Board With 27 Fuse (S).1256: Advance Solenoid Valve (Diesel).
BM34: Engine Fuse Board With 34 Fuse (S).1257: - Flow Solenoid (Diesel).
BPCB: Battery Cable Protection Unit1258: + Flow Solenoid (Diesel).
BSI1: Built-In Systems Interface.1259: +/- Flow Solenoid (Diesel).
C001: Diagnostic Connector.1260: Injector Needle Lift Sensor.
C002: Breakdown Wire Connector.1261: Accelerator Pedal Position Sensor.
C004: Instrument Panel Diagnostic Connector.1262: Motorised Butterfly.
C1030: Test Connector -Engine Running Information.1263: EGR + Butterfly Solenoid Valve.
C1042: General Circuit Breaker Optional Connector.1264: Swirl Solenoid Valve.
C1100: Ignition Test Connector.1265: Carburettor Heater Thermal Switch.
C1105: Ignition Suppression Connector.1266: Carburettor Heater Relay.
C1110: Ignition Adjustment Connector For Idle.1267: Diesel Butterfly Solenoid Valve (Air Intake).
C1200: Injection Test Connector.1268: Variable Solenoid Valve 2.
C1250: Emission Control Adjustment Connector.1269: Carburettor Heating Resistor Relay.
C1260: Supply Pump Fuse Holder Connector.1270: Carburettor Or Throttle Housing Heater Resistor.
C1265: Carburettor Heating Resistor Fuse-Holder Connector.1271: Cut-Off Solenoid Valve.
C1270: EGR Test Connector.1272: Cut-Off Solenoid Assembly, Carburettor Heater Resistor.
C1300: Injection-Ignition Test Connector.1273: Oil Breather Re-Heat Resistor 1.
C1310: Ignition/Injection Fuse Holder Connector.1274: Oil Breather Re-Heat Resistor 2.
C1360: Oxygen Sensor Heater Fuse Holder Connector.1275: Carburettor.
C1400: Tdc Connector.1276: Diesel Heater.
C1450: System Development Connector.1277: Diesel High Pressure Pump Piston Deactivation Solenoid 3.
C1500: Fan Operation Test Connector.1278: Start Of Compression Sensor.
C1630: Test Connector (Automatic Gearbox).1280: Long 2 Volume Vasc Solenoid.
C1700: Electronic Management Test Connector.1281: Short 2 Volume Vasc Solenoid.
C1800: Lpg Diagnostic Connector.1283: Fuel Additive Pump
1291: Degassing Water Solenoid valve /
C200: Caravan Socket Connector.1297: Electric EGR valve
C2310: Driving School Dual Control Connector.1301: Automatic Transmission Information Relay (Injection).
C2600: Front Fog-Lamp Fuse Holder Connector.1302: Injection And Supply Relay.
C310: Caravan Lighting Battery Positive Supply Connector.1303: Injection And Ignition Supply Relay.
C4640: Fuse-Holder Connector For Supply To Chronograph.1304: Engine Management Multi-Function Double Relay.
C6235: Door Locking Test Connector.1305: Mixture Potentiometer.
C6301: Test Connector (Storing In Memory - Seat).1306: Automatic Gearbox Relay Shunt.
C6540: Pre-Tensioning Seat Belts Test Connector.1307: Power Multifunction Double Relay.
C6560: Air Bag Test Connector.1308: Engine Oil Pressure Sensor.
C6570: Air Bag Test Connector + Pre-Tensioner.1309: Turbocharger Air Thermistor.
C6640: Ride Height Circuit Bleeding Connector.1310: Air Flow Sensor.
C6860: Electric Hood Test Connector.1311: Turbo Pressure Sensor.
C7000: Anti-Lock Brake Test Connector.1312: Induction Air Pressure Sensor.
C7001: Abs Power Fuse Holder Connector.1313: Engine Speed Sensor.
C7050: Traction Control Test Connector.1314: Altitude Sensor.
C7100: Variable Power Steering Test Connector.1315: Injection Resistor.
C7215: Multifunction Screen Diagnostic Connector.1316: Throttle Position Sensor.
C7710: Suspension Test Connector.1317: Diesel Pump Lever Position Sensor.
C8000: Heater Test Connector.1318: Throttle Switch Unit.
C8201: Immobiliser Test Connector.1319: Injection Coding Resistor.
C8400: Radio Battery + Ve Connector.1320: Engine Management Control Unit.
C8600: Alarm Test Connector.1321: Diesel High Pressure Sensor.
C861: Alarm Supply Connector.1322: Diesel High Pressure Regulator.
C8630: Protection Unit Diagnostic Connector.1323: High Temperature Sensor (Exhaust Gas).
CA00: Ignition Switch.1324: Proportional Dosing Solenoid Valve.
CCS1: Signalling Central Control Assembly (Police).1325: Petrol High Pressure Sensor.
CP00: Rear 12 V Socket.1326: Injection Unit Supply Fuse.
CPc0: Sliding Door Contact Assembly (Left).1327: Cam Position Sensor (Diesel Pump).
CPC1: Sliding Door Contact Assembly (Right).1328: Rotor Position Sensor (Diesel Pump).
CP01: Front 12 V Socket.1329: Slide Position Sensor (Diesel Pump).
CT00: Steering Wheel Rotary Connector.1330: Injector.
CV00: Switch Unit Under Steering Wheel (??? 2000).1331: Injector Cylinder No.1.
Drag: Shielded Earth.1332: Injector Cylinder No.2.
DRA1: Shielded Earth 1.1333: Injector Cylinder No.3.
ECV0: Control Assembly On Steering Wheel.1334: Injector Cylinder No.4.
MF00: Starter Battery Maxi-Fuse.1335: Injector Cylinder No.5.
MF01: Alternator Maxi Fuse.1336: Injector Cylinder No.6.
MF175: Mega-Engine Compartment Fuse 175 A.1337: Injector Cylinder No.7.
PS00: Connector Board.1338: Injector Cylinder No.8.
PSF0: Connection Board - Fuse Box (Passenger Compartment).1339: Injector Cylinder No.9.
PSF1: Connection Board - Fuse Box (Under The Bonnet).1340: Injector Cylinder No.10.
PSF2: Connection Board - Fuse Box (Luggage Compartment).1341: Particle Filter Differential Pressure Sensor /
V0004: Stop Warning Lamp.1342: Motor Multi-Function Control Unit.
V100: Load Warning Lamp.1343: Downstream Exhaust Gas High Temperature Sensor /
V101: Traction Batteries Correct Charge Lamp.1344: Upstream Exhaust Gas High Temperature Sensor /
V102: Traction Batteries Discharged Warning Lamp.1345: Oxygen Sensor Heater Relay.
V117: 12 V Converter Fault Warning Lamp.1346: Air Flow Sensor A
V110: Ignition Test Warning Lamp.1347: Air Flow Sensor B
V115: Pre-Heat Warning Lamp.1348: Oxygen Sensor Heater Fuse.
V120: Injection Test Warning Lamp.1350: Oxygen Sensor (Front).
V123: Pump Cut-Off Light.1351: Oxygen Sensor (Rear).
V130: Engine Diagnosis Warning Lamp.1352: Front Downstream Oxygen Sensor.
V170: Temporary Fault Warning Lamp.1353: Front Upstream Oxygen Sensor.
V171: Forward Drive Warning Lamp.1354: Rear Downstream Oxygen Sensor.
V172: Reverse Drive Warning Lamp.1355: Rear Upstream Oxygen Sensor.
V173: Insulation Fault Warning Lamp.1356: Braking Circuit Vacuum Sensor /
V180: Gas Supply Warning Lamp.1357: Proportional Oxygen Sensor
V200: Rear Fog Lamp Warning Lamp.1358: Catalytic Converter
V201: Front Fog Lamp Warning Light.1363: Electric Control Turbo And Local Check B
V230: Hazard Warning Lamp.1364: Cat. Conv. Upstream Exhaust Gas High Temperature Sensor B
V231: Right Or Left Flasher Indicator Lamp.1367: Electric Control Turbo And Local Check A
V232: Lh Direction Indicator Warning Lamp.1369: Diesel Fuel Volumetric Regulator
V233: Rh Direction Indicator Warning Lamp.1375: Vertical Rod Electrovalve 1
V260: Sidelamp Warning Lamp.1376: Turbo Pressure Sensor
V261: Dipped Beam Warning Lamp.1377: Electric EGR Electrovalve A
V262: Main Beam Warning Lamp.1378: Electric EGR Electrovalve B
V266: Front Fog Lamp Warning Lamp.1379: Vertical Rod Electrovalve 2
V401: Coolant Low Level Warning Lamp.1380: Controlled Thermostat (S2RE)
V417: Battery Electrolyte Level Warning Lamp.1383: Upstream exhaust gas high temperature sensor FAP
V402: Engine Coolant Maximum Temperature Warning Lamp.1384: Catalytic converter with exhaust gas high temperature sensor downstream of the precatalyst A
V404: Screen Wash Fluid Low Level Warning Lamp.1385: Catalytic Converter / Exhaust Gas High Temperature Sensor Upstream Of The Pre-Catalyst /
V405: Water In Diesel Fuel Warning Lamp.1400: Tdc Sensor. 1500: Fan Relay.
V411: Engine Oil Low Pressure Warning Lamp.1501: Cooling Fan Fuse.
V412: Engine Oil Low Level Warning Lamp.1502: Left Hand Fan Supply Relay.
V413: Maximum Engine Oil Temperature Warning Light.1503: Right Hand Fan Supply Relay.
V420: Choke Warning Lamp.1504: Left And Right Hand Fan Series Supply Relay.
V425: Air Cleaner Blocked Warning Light.1505: Cooling Fan Thermal Switch.
V430: Low Fuel Level Warning Lamp.1506: Two-Speed Cooling Fan Resistor.
V432: Tank Cap Open Warning Lamp.1507: Fan Control (Coolant) Temperature Sender Unit Via Ecu.
V440: Parking Brake Warning Lamp.1508: Low Speed Fan Supply Relay.
V441: Brake Fluid Low Level Warning Lamp.1509: High Speed Fan Supply Relay.
V442: Handbrake/Low Brake Fluid Level Warning Lamp.1510: Fan.
V443: Brake Pad Wear Warning Lamp.1511: Right-Hand Fan.
V444: Blown Bulb Warning Lamp.1512: Left-Hand Fan.
V460: Gear Lever Position Warning Lamp.1513: Cooling Fan Electronic Chopper.
V461: Gearbox Oil Temperature Warning Lamp.1515: Left-Hand Interference Suppression Filter.
V470: Door Open Warning Lamp.1516: Right-Hand Interference Suppression Filter.
V473: Seat Belt Not Buckled Warning Lamp.1517: Cooling Fan Controlled Flap.
V480: Catalytic Converter Overheating Warning Lamp.1518: Cooling Fan Three Speed Resistor.
V625: Deadlocking Pilot Light.1520: Engine Post-Cooling Thermal Switch.
V656: Air Bag Warning Light (Front).1525: Engine Post-Cooling Relay.
V657: Side Air Bag Warning Lamp.1526: Engine Post-Cooling Time Switch.
V664: Ride Height Correction Fluid Low Level Warning Lamp.1530: Post-Cooling Device Shunt.
V670: Differential Lock Test Warning Lamp.1550: Turbo Coolant Pump.
V679: Reduction Gear Change Warning Lamp.1551: Turbo Coolant Pump Fuse.
V700: Abs Diagnostic Warning Lamp.1555: Turbo Coolant Pump Control Relay.
V701: Abs Operational Indicator Light.1600: Selector Lever Position Switch.
V705: Traction Control Diagnostic Warning Lamp.1601: One-Touch Control Lever Sensor.
V706: Traction Control Operation Lamp.1602: One-Touch Control Switch.
V731: Cruise Control Indicator Lamp.1603: Assembly (Automatic Gearbox Control).
V770: Suspension Diagnostic Warning Lamp.1606: Parking Position Buzzer Supply Relay.
V780: Stability Check Diagnostic Warning Light.1607: Auto Transmission Selector And Display Lamp Supply Relay.
V818: Additional Heating Low Fuel Level Warning Lamp.1613: Auto Transmission Engine Speed Sensor.
V811: Heated Rear Screen Indicator Lamp.1615: Pressure Sensor (Automatic Gearbox).
V822: Transponder Warning Lamp.1620: Vehicle Speed Sensor.
1000: Starting Safety Switch.1621: Vehicle Speed Sensor (Automatic Gearbox).
1005: Starter Inhibitor Relay.1622: Automatic Gearbox Output Speed Sensor.
1010: Starter.1625: Vehicle Speed Interface Module.
1020: Alternator.1630: Automatic Transmission Control Unit.
1025: Dual Battery Unit.1631: Torque Reduction Solenoid Valve.
1030: Engine Running Signal Relay.1632: Pedal Position Contact.
1040: General Maintenance Relay.1635: Automatic Gearbox Electrohydraulic Block.
1041: Emergency Stop Switch.1636: Auto Transmission Position Sensor.
1042: General Relay.1637: Automatic Gearbox Kickdown Switch.
1043: Re-Setting Push Button.1638: Auto Transmission Lever Blocking Actuator.
1044: Diode Unit.1639: Accelerator Pedal Foot Off Contact.
1045: Auxiliary Re-Arming Push Button.1640: Automatic Transmission Programme Selector.
1086: Alarm Starter Cut-Off Relay.1642: Gear Lever Blocking Actuator Control Relay.
1100: Distributor.1643: Key Blocking Actuator Control Relay.
1101: Engine Coolant Thermistor For Advance Module.1644: Key Blocking Actuator.
1102: Advance Module.1645: Automatic Gearbox Electronic Piloting.
1104: Advance Correction Solenoid.1646: Automatic Gearbox Solenoid Valve Block.
1105: Ignition Amplifier Module.1700: Electric Management Control Unit.
1110: Ignition Distributor.1701: Temperature Monitoring Module -Lower Front Battery Voltage.
1115: Cylinder Reference Sensor.1702: Temperature Monitoring Module -Upper Front Battery Voltage.
1116: Cylinder Reference Sensor 1.1703: Temperature Monitoring Module -Rear Battery Voltage.
1117: Cylinder Reference Sensor 2.1704: Relay Housing.
1120: Knock Sensor.1705: Electronic Tool Kit.
1121: Knock Sensor 1.1713: Accelerator Potentiometer.
1122: Knock Sensor 2.1714: Energy Gauge.
1125: Accelerator Pedal Switch.1718: Electric Motor Cooling Fan Control Thermistor.
1127: Ignition Supply Relay.1722: Battery Electrolyte Cooling Fan Control Thermistor.
1130: Ignition Control Unit.1724: Additional Heating Switch.
1131: Cylinder 1 Ignition Coil.1725: Additional Heating.
1132: Cylinder 2 Ignition Coil.1726: Additional Heating Fuel Pump.
1133: Cylinder 3 Ignition Coil.1727: Traction Battery Coolant Pump.
1134: Cylinder 4 Ignition Coil.1728: Electronic Management Control Unit Coolant Pump.
1135: Ignition Coil.1729: Electric Vehicle Coded Anti-Start Relay.
1136: Ignition Coil Capacitor.1730: Coded Anti-Theft Shunt.
1137: Cylinder 5 Ignition Coil.1732: Battery Heating Relay.
1138: Cylinder 6 Ignition Coil.1733: Battery Heating Resistor.
1140: Emission Control Module For Carburettor.1740: Electric Traction Motor.
1141: Coolant Heating Plugs Supply Relay 1.1746: Electric Motor Cooling Fan.
1142: Coolant Heating Plugs Supply Relay 2.1747: Charging Socket.
1143: Coolant Heating Plugs Supply Relay 3.1748: Battery Charging Socket Unit.
1145: Throttle Opening Solenoid Valve.1800: Gas Control Unit.
1146: Coolant Heating Plugs Supply Relay 1-2.1801: Absolute Pressure Sensor.
1147: Coolant Heating Plugs Supply Relay 3-4.1802: Dosing Solenoid Valve.
1148: Coolant Heater Relay 1.1803: Tank Solenoid Valve.
1149: Coolant Heater Relay 2.1804: Vapour Pressure Relief Solenoid Valve.
1150: Pre-Heat Control Unit.1805: 3 Relay Housing.
1155: Pre-Heat Relay.1806: Oxygen Sensor Relay.
1156: Post-Heat Relay.1807: Diode Bridge.
1157: Post-Heat Thermal Switch.1808: Gas Supply Unit.
1158: Pre-Post Heating Control Unit.1809: Linear Actuator.
1160: Glow Plugs.1810: Petrol-Gas Switch.
1161: No. 1 Cylinder Glow Plug.1811: Petrol/Gas Timer Relay.
1162: No. 2 Cylinder Glow Plug.1812: Gas Supply Fuse Unit.
1163: No. 3 Cylinder Glow Plug.1813: Diagnostic Warning Light Cut-Off Relay.
1164: No. 4 Cylinder Glow Plug.1814: Gas Pressure Gauge.
1190: Water Circuit Heater.1815: Lpg/Petrol Dialogue Double Relay.
1200: Fuel Pump Relay.1816:12v/5v Voltage Adaptor Fitting.
1201: Injection Pump Relay.1817: Lpg Gauge.
1202: Tachymetric Relay.1818: Coolant Thermistor (15°).
1203: Inertia Switch.1819: Lpg Gauge Damping Unit.
1204: Impact Safety Relay.1820: Gas Distribution Motor.
1205: Fuel Pump Fuse.1821: Lpg Solenoid Valve + Gauge.
1206: Decanting Pump Control Unit.1822: Adaption Fitting Diode 12v/5v.
1207: Decanting Pump.1823: Adaption Fitting Resistor 12v/5v.
1208: Diesel Injection Pump (Advance Corrector, Fuel Cut-Off Solenoid).1824: Inlet Air Flap Solenoid Valve.
1209: Scavenge Pump.1825: Gas Supply Solenoid Valve.
1210: Fuel Pump.1826: Fuel Pump Cut-Off Relay.
1211: Fuel Gauge Pump.0002: Lighting And Signalling Switch.
1212: Air Tank Solenoid.2000: Rear Fog Lamp Switch.
1213: Air Pump Relay.2001: Lighting/Wiping Stalk.
1214: Econoscope.2002: Driving School Buzzer (Germany).
1215: Purge Canister Solenoid Valve.2003: Driving School Instructor's Control Unit.
1216: Canister Simulation Resistor.2004: Driving School Jack Socket (Germany).
1217: Canister Bleed Cut-Off Solenoid.2005: Rear Fog Lamp Relay.
1218: Ignition Advance Cut-Off Solenoid.2006: Driving School Switch (Germany).
1219: Throttle Potentiometer (Injection, Automatic Transmission).2007: Driving School Footwell Lighting (Germany).
1220: Coolant Temperature Sensor.2010: Rear Fog Lamps (Left Side).
1221: Diesel Thermistor. 1222: Accelerometer.2011: Rear Fog Lamps (Centre).
1223: Injection Air Solenoid Valve.2015: Rear Fog Lamps (Right Side).
1224: Absorber Closing Solenoid Valve.2016: Rear Fog Lights Control Unit.
1225: Idle Regulation Stepper Motor (MMBA).2100: Stop Lamp Switch.
1226: Idle Regulation Motor And Idle Switch.2101: Redundant Brake Switch.
1227: Fuel Tank Pressure Sensor.2110: Additional Stop Lamps.
1228: Idle Regulation Motor And Idle Switch + Hall Effect Sensor.2111: Additional Stop Lamps (Left Side).
1229: Turbo Regulator Solenoid With Variable Resistance.2112: Additional Stop Lamps (Right Side).
1230: Supplementary Air Device.2200: Reverse Lamp Switch.
1231: Automatic Transmission Idling Speed Solenoid Unit.2202: Reverse Drive Control Switch.
1232: Idle Maintaining Solenoid Valve.2210: Left-Hand Reverse Lamp Switch.
1233: Turbocharger Pressure Regulation Solenoid Valve.2215: Right-Hand Reverse Lamp Switch.
